Abs connection issues
Discussion in '1st Gen Tundras (2000-2006)' started by Drewskisabum, Dec 25, 2024.
  1. Dec 25, 2024 at 9:30 AM
    Drewskisabum
    Drewskisabum [OP] New Member
    Arizona
    2005 limited 4x4 DC
    Merry Christmas everyone,
    Recently I had 6 abs dtcs pop up
    C1223-
    ABS Control System Malfunction
    U0073-
    Control Module Communication Bus Off
    U0100-
    Lost Communication With ECM/PCM A
    U0123-
    Lost Communication With Yaw Rate Sensor Module
    U0124-
    Lost Communication With Lateral
    Acceleration Sensor Module
    U0126-
    Lost Communication With Steering Angle Sensor Module
    Clearly it’s some sort of connection issue. My initial thought was a bad battery, so I had it checked at autozone and they told me my battery was good but I had a bad starter…. I have no issues starting my truck whatsoever so I’m having a hard time believing that. I found my negative terminal harness was a little loose so I tightened it and the codes went away for a little less then a day but then they popped back on. Just looking for any advice on what I should check for next and if it could be caused by my starter going bad or possibly my alternator?
  2. Dec 25, 2024 at 9:36 AM
    Questions for you:
    Did you check all your fuses in the dash and the engine bay to ensure nothing tied to ABS is popped?
    Does your horn work? If you have steering wheel controls, do those work? Asking with the angle that your clockspring may be FUBAR, or someone maybe replaced it with aftermarket garbage, which is often problematic.
    Drewskisabum[OP] likes this.
  3. Dec 25, 2024 at 10:13 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Since you already had an issue with that ground cable, i’d be looking much closer in that vicinity again.
  4. Dec 25, 2024 at 10:17 AM
    Or corrosion inside the negative cable, given how common corrosion inside the cables is on our trucks.
  5. Dec 29, 2024 at 7:54 AM
    Drewskisabum
    Arizona
    2005 limited 4x4 DC
    Horn still works, going through the rest of my connections this morning hopefully will find the problem. I’ll also have to check for corrosion inside the cable, I didn’t even think of that thanks for the tip!
  6. Jan 17, 2025 at 9:31 PM
    Drewskisabum
    Arizona
    2005 limited 4x4 DC
    Realized I never came back with an update but it ended up being my battery, guess those autozone battery checks are bs
    shifty` and The Black Mamba like this.
  7. Jan 17, 2025 at 9:36 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    @BroHon are you trolling us? :rofl:
    BroHon and whodatschrome like this.
  8. Jan 18, 2025 at 4:55 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    No Sir :hattip::rofl:
    Several factors in my no start post:
    I'm old, and 2.5 yrs seems like a year maybe?
    So i'm like ffs I just put that thing in there:eek2:
    Never had one die in less than 5-6yrs
    I'm old and forget what I said 30 seconds ago.
    update
    No more "zing" failures to engage, it's been just that one hiccup.
    Cold lower teens and she cranks faster than she ever has since day one!
    I'm old and forget what I said 30 seconds ago. :rofl:
  9. Jan 18, 2025 at 6:39 AM
    After this reply from @BubbaW, I’m actually not surprised by it being batt/charging related.
    Batt checks… depends on what unit they use. I have the same handheld unit most of the parts store chains use. When used in the wrong hands, they can give bad info. Some techs don’t know how to read the output properly. And how tou attach the leads matters greatly in how it is able to scan.
