Abs booster goes off at low speed stops
Discussion in '1st Gen Tundras (2000-2006)' started by Wideopenpilots, Oct 11, 2020.
  1. Feb 8, 2022 at 3:23 PM
    #61
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does it look like this?
  2. Feb 8, 2022 at 3:27 PM
    #62
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    It does not...let me see if I can find a picture off the internet...I am not currently able to take pictures. Something is up with my phone. I could try with my computer though. Here is something very close to what mine looks like-
  3. Feb 8, 2022 at 3:29 PM
    #63
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Can you find this part on yours?
  4. Feb 8, 2022 at 3:32 PM
    #64
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Yep, I've got that tube.
  5. Feb 8, 2022 at 3:34 PM
    #65
    des2mtn
    SW
    Tonto cover
    Disconnect the tube and pull out the part which the tube was connected to, then try to blow through the part. You might need a flat head screw driver to help get the valve off the booster.
  6. Feb 8, 2022 at 3:35 PM
    #66
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Will I lose any brake pressure with it off?
  7. Feb 8, 2022 at 3:36 PM
    #67
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Sorry, I just realized the the picture @des2mtn sent me at first would have worked :l
  8. Feb 8, 2022 at 3:37 PM
    #68
    des2mtn
    SW
    Tonto cover
    As long as your engine is off, you're fine.
  9. Feb 8, 2022 at 3:50 PM
    #69
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I pulled the hose off and there is a black tube...do I blow into the black tube or is there a piece that comes out for me to blow into?
  10. Feb 8, 2022 at 3:53 PM
    #70
    des2mtn
    SW
    Tonto cover
    Pull that black tube out or twist it out, then blow into it. You might need to use something like a screwdriver to pry it out. If I'm remembering right, it comes out pretty easily.
  11. Feb 8, 2022 at 3:56 PM
    #71
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Doesn't sound like it. I'm on the vacuum bandwagon for this new issu3.
  12. Feb 8, 2022 at 4:02 PM
    #72
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    It did come out easily. I will go do that real quick.
    des2mtn[QUOTED] likes this.
  13. Feb 8, 2022 at 4:03 PM
    #73
    des2mtn
    SW
    Tonto cover
    Found it.
    MS22, shifty`[QUOTED] and bmf4069 like this.
  14. Feb 8, 2022 at 4:04 PM
    #74
    des2mtn
    SW
    Tonto cover
    Blow into it on both sides, you should only be able to blow air through one of the sides.
  15. Feb 8, 2022 at 4:22 PM
    #75
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Okay, I blew into it. I can only blow into one side...I think it's tight like it's supposed to be.
    FrenchToasty and des2mtn like this.
  16. Feb 8, 2022 at 4:25 PM
    #76
    des2mtn
    SW
    Tonto cover
    Alright cool, go ahead and re-install it and the hose, then I'd try following the troubleshooting from the manual above.
  17. Feb 8, 2022 at 4:31 PM
    #77
    shifty` Ten EV 12's so you know I raise hell
    Thanks for grabbing that FSM page!
    1stgentundradriver likes this.
  18. Feb 8, 2022 at 4:55 PM
    #78
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Sounds good! Thank you. I will update with results.
  19. Feb 8, 2022 at 5:36 PM
    #79
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I could not get the brakes to fail any of these tests...
  20. Feb 8, 2022 at 6:02 PM
    #80
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Would the guys working on brakes had in any reason to mess with the brake pedal return spring or is it worn out ?
    If as you said you can pull it back up then it might be spring :notsure:
    from 06 FSM....
  21. Feb 8, 2022 at 10:32 PM
    #81
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I had new brakes put on in December...and nothing was wrong with the brakes afterwards...reason for new brakes was because of both front rotors being warped. It did not have the problem when the shop had it in, and then I got it back and the problem developed. I don't know how it could have worn out the spring, as it worked fine when I dropped it off. I got it back and the pedal wouldn't come back up. I'm thinking that it could be the spring though as the shop was working under the dash (I presume) with their scanner. How easy is it to replace the spring?
  22. Feb 9, 2022 at 3:14 AM
    #82
    First thing I'd do is do a visual inspection of the spring.
    Do you see it installed?
    Is it attached at both ends?
    When attached, if you push in the down no more than 1"-2", does it seem to act properly?
    When detached, if you can easily detach it, does it appear stretched or worn?
    If the answers here are YES, YES, YES and NO, then I doubt the spring is your issue.
    I'll be honest, without actually seeing this w/my own eyes, I'm having a hard time visualizing and giving suggestions.
  23. Feb 9, 2022 at 8:01 AM
    #83
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Let me go do that check. I am able to take pictures now…let me know if you need me to take any pictures and I can do that. I appreciate your efforts a ton @Shifty !
  24. Feb 9, 2022 at 1:24 PM
    #84
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I doubt the spring is my issue. There is no issues with the pedal returning after 1-2 inches of travel. Here is a picture of the underside.907490A8-0809-447C-AC3A-405A35A3F33E.jpg
  25. Oct 30, 2024 at 6:53 AM
    #85
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    I'm not seeing the spring, am i blind or is it missing?I see it on e-brake, shouldn't it go into empty hole on upper brake pedal and back up in towards dash?
