Abrupt Lunge
Discussion in '2nd Gen Tundras (2007-2013)' started by BigDave75, Oct 10, 2021.
  1. Oct 10, 2021 at 6:35 PM
    BigDave75
    BigDave75 [OP] New Member
    David
    Nebraska
    2012 Toyota Tundra
    Hey everyone, got a question on my ‘12 Tundra with 83kish miles. Our driveway is steep and while slowly going up the driveway, making sure not to hit the camper at the top, most of the time I’m going slow and the vehicle will accelerate forward for whatever reason, when I’m not accelerating or barely stepping on the gas pedal, it does have the 5.7L Iforce V8, is this normal for the Tundras, something to do with the variable transmission? Thanks for all the info.
  2. Oct 10, 2021 at 6:51 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    Would you describe the acceleration as a surge? My parents had a Ford ltd that would surge forward suddenly. It would only do it for a second or two but was unpredictable enough that no one wanted to drive it. Never did figure it out. Even the dealer was stumped. I suspect it is the relationship between intake sensors and the computer
  3. Oct 10, 2021 at 7:02 PM
    BigDave75
    David
    Nebraska
    2012 Toyota Tundra
    Yes, I’d consider it a surge, only does it while very slowly driving up my driveway.
  4. Oct 10, 2021 at 7:13 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Try turning the A/C off and see if it still happens. Some cars get an idle up command when the compressor A/C engages.
    BigDave75[OP] likes this.
  5. Oct 10, 2021 at 7:47 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I haven't seen that in mine, but I don't have inch along very often.
  6. Oct 10, 2021 at 8:36 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    let me know how the AC thing works out.
    if it doesn't I'll do write up on things to do first to eliminate areas an get down to the bottom of it. Also if its constantly repeatable in that scenario , A video of both the "out side" and "gauges" would help.
  7. Oct 11, 2021 at 2:17 AM
    CMikeB
    CMikeB New Member
    I wonder if downshifting into 1 st gear going up the grade is the cause? I realize it's a pretty foreign concept for many Tundra owner's but next time, shift into 1st gear at the base of the hill. By choosing the gear yourself, the transmission won't have a chance to "change it's mind" suddenly!:thumbsup:
  8. Oct 11, 2021 at 4:41 AM
    PJR202
    PJR202 New Member
    My 07 TacomaV6 did this. I didn't get too worked up about it, but finally searched around and found out.
  9. Oct 11, 2021 at 4:42 AM
    PJR202
    PJR202 New Member
    OP are you sure it isn't just changing gears? Or are you going really, really slow? Then I woukd go back to the suggestion made about the AC compressor.
  10. Oct 11, 2021 at 5:19 PM
    BigDave75
    David
    Nebraska
    2012 Toyota Tundra
    Ooo, good idea, I’ll try that, thanks.
  11. Oct 11, 2021 at 5:21 PM
    BigDave75
    David
    Nebraska
    2012 Toyota Tundra
    Yes, I’m going super slow uphill, does it just before I brake.
  12. Oct 11, 2021 at 5:22 PM
    BigDave75
    David
    Nebraska
    2012 Toyota Tundra
    A/C wasn’t on today and still did it.
  13. Oct 11, 2021 at 6:55 PM
    Willard
    Willard New Member
    2024 F250
    I park on an inclined driveway and mine does the same thing. It’s the transmission shifting while crawling under load.
    To prevent it I shift into first gear before coming up the driveway.
    My wife’s highlander does the same thing, and we used to have a Lexus gs300 that did it as well. All six speed auto transmissions.
  14. Oct 11, 2021 at 7:06 PM
    BigDave75
    David
    Nebraska
    2012 Toyota Tundra
    Awesome, well thank you very much, is it bad for the trans to do this repeatedly?
  15. Oct 12, 2021 at 3:08 AM
    CMikeB
    CMikeB New Member
    Automakers have had to include software in the transmissions to downshift with a brake-tap, when descending hills if the grade is steep enough. Today's drivers will do anything to avoid touching the shifter on their automatic transmissions. Toyota's Sequential or "S' Mode totally eliminates "shifting issues." Instead of needless heat building shifts with an unlocked Torque Converter,depending on speed and load, we have the option of choosing a gear that prevents it.
  16. Oct 16, 2021 at 1:55 PM
    BigDave75
    David
    Nebraska
    2012 Toyota Tundra
    Hey all, just wanted to update everyone on this topic, Willard informed me I should shift the vehicle into 1st which did actually solve the issue of abruptly accelerating forward/(shifting). So thanks for all the input.
    NueveTundra likes this.
  17. Oct 25, 2021 at 4:47 AM
    PJR202
    PJR202 New Member
    There was one specific red-light I used to sit at often. That's where I noticed the lunge. I would be creeping forward and it would suddenly push ahead a tiny bit. I didn't know what it was either, but eventually searched around online. I rarely noticed it any other time or place.
