A Gun Trust?
Discussion in 'Guns & Hunting' started by Rngr188, Nov 30, 2018.
  1. Dec 29, 2018 at 9:25 AM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I already have a 16" Colt, if I bought a sbr upper first in my build process and have not assembled my lower with a pistol buffer tube and brace then am I technically pushing constructive posession? Even though I would never mount the sbr upper to my Colt lower I could.
  2. Dec 29, 2018 at 1:46 PM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    From what my friends in the gun industry had told me, they changed the law a few years ago and once a lower is built into a rifle it can't be converted to a pistol, only a sbr. For that reason of you don't have a dedicated pistol lower, you can't have a pistol upper in the house until you have your sbr approved.
  3. Dec 29, 2018 at 2:50 PM
    Rngr188
    Chad
    Harrison AR
    My lower is assembled minus the pistol buffer tube and brace, should be in next week, my upper only has a forward assist and dust cover. I don't plan on ordering a short barrel until the lower is complete as a pistol lower so I should be ok yea? Thinking of keeping it a pistol unless I decide to give Uncle Sam my particulars to be imputed into the "beast". At that point I will add a carbine buffer and stock if I decide to get a stamp. Am I on the right track here?
  4. Dec 29, 2018 at 4:02 PM
    chadjamesr
    Chad
    Atlanta
    If you purchased a new lower that has never been built and then add the pistol buffer tube on it and then order the pistol barrel or pistol barrel upper, then you would be fine. That is the same thing I did when I did my first SBR. The good news is that if you efile for the Form 1 to make a SBR, the wait times are only like a month now. If you don't efile, the I think the waits are around 6 months or longer. Don't forget to have the lower engraved. If you are setting up a trust and having set it up yet, then I suggest using the shortest trust name you can as you will need to have the trust name engraved on the lower.
