A different fix for AGM charging
Discussion in '2.5 Gen Tundras (2014-2021)' started by JINKSTER17, May 1, 2023.
  1. Nov 28, 2023 at 3:03 PM
    #61
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Does this automatically start charging at the correct setting once it's plugged into power or do you have to press buttons to select, for example, AGM each time? In other words, does it remember your settings?
    coTony and FrenchToasty like this.
  2. Nov 28, 2023 at 5:02 PM
    #62
    coTony
    Tony
    Montrose, CO
    If it is like mine (different model) the first time to attach it you need to make sure it does select the proper one and it usually does quickly and from there it has a memory of sorts of last use. I always double check each time to make sure and always works automatically.
  3. Dec 1, 2023 at 7:07 AM
    #63
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    You plug it in after hooking up the charging cables and select the type battery you are charging (AGM, etc.) by pushing the mode button. It is all automatic from there.
    coTony likes this.
