A/C "Surge" with 05 DC
Discussion in '1st Gen Tundras (2000-2006)' started by jberkut4, Jun 8, 2020.
  1. Jun 8, 2020 at 5:22 PM
    jberkut4
    jberkut4 [OP] Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Whenever I decide to turn AC on, the truck seems to barely surge while driving. It isnt very noticeable, not sure if I only notice it since I am the only one that drives it all the time when this happens. While going highway speeds, you can sort of feel it "nosedive" when it surges, or kind of like the power is being cut. None of my other vehicles do this, so wondering if this is somewhat normal, and if anyone else has had this issue.
    Pucks18 likes this.
  2. Jun 9, 2020 at 7:39 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    My 01 tundra does the same thing, my 01 camry also does the same thing. Yours does it too, so its either a very common problem, or very normal. I'm Gonna go with normal.
    YardBird likes this.
  3. Jun 25, 2020 at 12:30 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    My truck also never really seems to get cold, and takes forever for it to get "cold" at all. Could it be just low on frion/bad AC compressor?
  4. Jun 25, 2020 at 12:47 PM
    chester
    chester best member
    2005 Double Cab SR5
    Sounds like spinning your compressor is taking a lot of torque. That would explain the power cut. I think your compressor may be bad.
    Now I really think your compressor is bad.
  5. Jun 25, 2020 at 12:59 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    I started to think that more in the past couple weeks when I started to use AC more. 90% of the time i drive windows down. Feels like it 10 minutes for it to get remotely cold, but never "ice" cold. Especially if its over 75 degrees
  6. Jun 25, 2020 at 1:05 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    First stick a meat thermometer in your vent to get a true reading. I think a properly charged and working system is supposed to register around 40-45 degrees at the vent.
    Hooptytrix and Wynnded like this.
  7. Jun 25, 2020 at 2:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The compressor cycles on and off, they don't run continuously. This is what you're noticing.
  8. Jun 25, 2020 at 2:48 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    It is normal to feel a little bit of power loss when the AC kicks on but if it is like you say "nose dive" and you are loosing power then you have a problem with the compressor. I would say try and get a look at it, any rust, grease or something that should not be there is step 1. Leaking fluids can build up anywhere and if you don't use the ac for extended periods of time that grease can turn to sludge
    Tundra2 likes this.
  9. Jun 25, 2020 at 3:07 PM
    Pucks18
    Mine takes around 1 minute to get to its coldest
  10. Jun 25, 2020 at 3:23 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I can't speak for everyone else's Tundra ~ only mine. It's done this since I took it over and the A/C system is fully charged and not leaking.
    The vehicle had 20K on the clock when I bought it used and it now has 40K miles total.
    The A/C was really weak from day one ~ it still is. It would only get cold in the cab (it's a RCLB) on a day that wasn't that hot to begin with.
    Someone recommended running the A/C in the re-circulation mode ~ they were right ~ it seems to help immensely.
    As far as doing a "nose dive" at freeway speeds ~ my Tundra does not exhibit this malady but I had an old Ford pickup truck that did exactly that.
    The engine in the Ford was pretty weak (smog era engine tune) and the A/C pump took a lot of power from the engine to work while cycling on and off.
  11. Jun 25, 2020 at 5:16 PM
    remington351
    2006 SR5 DoubleCab
    Not all trucks are the same, but my double cab will freeze me out on a 95 degree day after 15-20 minutes. I couldn't imagine having a regular cab with marginal a/c. That would be like having a big screen tv that only shows in black and white. Do 1st gens have a cabin air filter that could be part of the problem?
  12. Jun 25, 2020 at 5:25 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Both my RC Tundra trucks get ice cold with the AC on, the 2002 gets cold & stays cold now that the windshield has ceramic tint. I feel the compressor cycling on and off in the '02, but not in the '07... I guess the 5.7L has more power to spare.
  13. Jun 25, 2020 at 9:45 PM
    Hooptytrix
    Dirty South
    That ceramic tint on the windshield is the best upgrade I've done.
    YardBird and Rex Kramer[QUOTED] like this.
  14. Jun 26, 2020 at 5:19 AM
    Professional Hand Model
    Hand Protectors
    It is amazing. I had it done on another vehicle during high summer and right away could feel the heat reduction. Made an appointment immediately after and had the Tundra sides fronts done with plans of doing the front windshield in clear later, but after a year don’t think its needed because the UV heat is reduced so greatly.
  15. Jun 26, 2020 at 6:48 AM
    Hooptytrix
    Dirty South
    The UV's are what fade and crack the dashboard
  16. Jun 26, 2020 at 8:24 AM
    Hand Protectors
    I use UV protection juice on the dash.
    Hooptytrix[QUOTED] likes this.
  17. Jun 26, 2020 at 8:26 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    AKA, sunscreen? ;):rofl:
  18. Jul 6, 2020 at 11:39 AM
    remington351
    2006 SR5 DoubleCab
    Just for reference, it was 95 with high humidity this weekend in Maryland. The food thermometer in my dash said 40 degrees with the recirculate button on fan on 3.
