A/C...not as cold as others???
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXRailRoadBandit73, Jul 29, 2019.
  1. Jul 29, 2019 at 8:00 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Have a 2014 I bought used with 26,000 now I'm at 70+, I drove our middle boys dodge the other day to airport, his is a 2016 with 30,000 miles and a diesel, I noticed that his A/C right off the bat at start up was super cold and stayed that way, with mine, it takes a minute or two to get cold but it's not as cold as his, wife's car, 2010 Buick Lacrosse just hit 100,000, her A/C blows just a lil colder than mine, what gives??? My a/c button is on, the recirculate button is on as well, temp control all the way cold, I mean it is cold but NOT as cold as is if Tundra was brand new, anyone else going through this? Should I take to a a/c service?
    Rica25 likes this.
  2. Jul 29, 2019 at 8:05 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    It might not hurt to get the Freon checked, if low more Freon might help. Also you mention "Recirc" is on, can you tell a noticeable difference when turned off? Just another something to verify, if not maybe issue there.
    Good Luck!!!
    Rica25 likes this.
  3. Jul 29, 2019 at 8:06 AM
    Grumpy Uncle
    Pat
    CO
    Might need a service. I need to take my boys Tacoma in for a/c service. His takes about 30 minutes to get cool.
    My truck gets cool pretty fast, even on hot days.
    Rica25 likes this.
  4. Jul 29, 2019 at 8:08 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    My 18 Tundra and the wife’s 18 Highlander have the same issue. The highlander is actually worse than the Tundra... I have no idea why. We just moved from San Diego to Clovis and the heat makes the AC performance (or lack thereof) a lot more noticeable.
    Rica25 likes this.
  5. Jul 29, 2019 at 8:11 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    IMG_4667.jpg Here's my 2014 in the hot ass Nevada desert.
    Black Wolf and Rica25 like this.
  6. Jul 29, 2019 at 8:13 AM
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    I'm on my second Tundra and I can confirm that both have pretty sad AC systems.
    Rica25 and bdpeelgren like this.
  7. Jul 29, 2019 at 8:13 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
  8. Jul 29, 2019 at 9:38 AM
    TUNDRA65
    TUNDRA65 New Member
    2019 Tundra TRD Sport
    I'm on my fourth toyota truck. Three tacomas and now a 2019 tundra with 1600 m. I can add that all had weak heaters and ac units.
    If my new tundra sits in 80deg. sun for an hour or better it takes awhile before it gets cold, and that's on max air. Fan power seems weak also.
    I've been in many vehicles and they all seem to be colder(faster) and blow stronger..
  9. Jul 29, 2019 at 9:49 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    New vehicle styling seems to favor black for the interiors. Black might be fast, but it's definitely hotter'n hell in Texas. It takes awhile for your AC to get all the absorbed heat out of everything inside the cabin.
  10. Jul 29, 2019 at 12:32 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    My brand new 2018 Tundra Crew has horrible AC. I came out of a 2016 Chevy Tahoe with amazing AC.
    Field Walker likes this.
  11. Jul 29, 2019 at 12:45 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    My first Tundra (2015) had a weak A/C system, I had to keep it on max cool. But, my 2017 I traded it in for has an amazing A/C. I leave it set at 72 and it gets cold quick.
    SiberianTundra likes this.
  12. Jul 29, 2019 at 12:49 PM
    Dos Cylindros
    Dos Cylindros New Member
    2022 1794 Edition Smoked Mesquite
    My 2019 Pro is super cold. Drove it yesterday in 106 degree heat and it works great.
    Trunk Monkey, realtorblake and RBDTx like this.
  13. Jul 29, 2019 at 2:18 PM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    No problem with mine even in 100+ temperatures down here in south Texas.
  14. Jul 29, 2019 at 2:25 PM
    Where south Texas?
  15. Jul 29, 2019 at 2:30 PM
    toyoboyo
    toyoboyo New Member
    American cars always have top notch AC systems.
    Twinky and SiberianTundra like this.
  16. Jul 29, 2019 at 2:54 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Mine's the opposite. My wife's 14 Highlander has way better A/C than my '16 Tundra Crewmax. It gets cold much quicker.
    This is in Florida. The truck is much larger to cool down however. I feel like it's always on near max. It takes awhile to get cold. My buddies Chevy and Ford always cooled much quicker.
  17. Jul 29, 2019 at 3:00 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    If your running the recirc as soon as you get in the hot truck, the air you are pulling from cab is going to be hotter than the air outside for a few minutes. Don't hit recirc until you get underway. My 19 will freeze you out.
  18. Jul 29, 2019 at 3:05 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    The A/C in my 05 Tundra is better then my 04 Mercedes.
    Watt maker likes this.
  19. Jul 29, 2019 at 4:03 PM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    My 2018 is amazing so long as I make sure to pull outside air first for a few minutes. It will freeze me in 10 -15 minutes from sitting in the lot all day.
  20. Jul 29, 2019 at 4:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    @ARamirez73 have you checked / replaced the cab air filter? A restricted filter makes a HUGE difference in HVAC performance.
  21. Jul 29, 2019 at 4:18 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    First check the cabin filter. If its dirty it will raise the suction pressure and discharge temperature and will take a lot longer to cool the cab. Make sure the recirculate button is on. If you have the fresh air on outside heat and humidity will enter the cab. Check the condenser is clean. If possible check the evaporator is clean, it may not be so easy to get to. Their is a foam cleaner that is sprayed up the condensate drain line to help clean the evaporator coil. Check belt tension and the ac clutch are not slipping. Put gauges to check pressures and last check the refrigerant charge. Hope this helps.
    Rex Kramer and SiberianTundra like this.
  22. Jul 29, 2019 at 4:22 PM
    Bout 2 months ago
    landphil[QUOTED] likes this.
  23. Jul 29, 2019 at 4:28 PM
    realtorblake
    Silver Sky's are 20 degrees cooler right off the lot. :headbang:
    PermaFrostTRD and landphil like this.
  24. Jul 29, 2019 at 4:29 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    Mine is weak, My Tacoma was weak too...The older 90s lexus/ toyotas had some of the best ac systems out there, they would blow snowballs. It works, but not that well, and the fan is weak too.
  25. Jul 29, 2019 at 4:36 PM
    SiberianTundra
    Greg
    War Machine
    I wonder if ours needs recharging or something?
  26. Jul 29, 2019 at 4:39 PM
    SiberianTundra
    Greg
    War Machine
    also can it be a blower motor resistor ?
    Ajkkane likes this.
  27. Jul 29, 2019 at 4:39 PM
    I'll be looking around town for an a/c shop and see if I'm low on freon
  28. Jul 29, 2019 at 5:29 PM
    SiberianTundra
    Greg
    War Machine
    All good points!
  29. Jul 29, 2019 at 9:27 PM
    realtorblake
    If you run recirc right off the bat in summertime air in South Texas, you are trying to cool 120 degeree air in the cab versus 90 degree air outside the cab. It about 5 minutes longer to get the cab cooled to comfortable.
  30. Jul 29, 2019 at 9:44 PM
    Rica25
    Ricardo
    Tulare
    I had never serviced my A/c and its 2008 ...but about 2 weeks ago I drove a 2012 or 2013 Rock warrior with only 40k and was colder almost instantly......so I told one of my master techs and he said A/C should be serviced every 2 yrs....so he told me he would check it out for me ......about 2 hrs later he told me it was only half full so he put it to max spec and now my A/C is much colder and gets colder much faster
