A/C Noise When Turning On
Discussion in 'General Tundra Discussion' started by kralc8954, Jan 31, 2019.
  1. Feb 1, 2022 at 1:03 PM
    #211
    Firecapt1
    Firecapt1 New Member
    Has anyone gotten an answer from Toyota on this problem? The noise sounds bad enough that it seems only a matter of time before something is going to self destruct causing major damage to the components involved not to mention the surrounding parts. I was hoping to hear something here before taking my 2021 Tundra Crewmax Limited into Toyota and going through the usual service dept hassle.
  2. Feb 1, 2022 at 8:18 PM
    #212
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    I'm quoting this excellent post from Elduder as evidence of why I'm not worrying about the noise which I hear every so often.
    Elduder[QUOTED] likes this.
  3. Apr 14, 2022 at 10:04 PM
    #213
    45to472024
    45to472024 New Member
    Sal
    2020 Tundra platinum
    Hey just joined and glad I'm not the only one hearing this noise. I have a 2020 Tundra platinum. Same noise and condition. I'm in sunny southern communist California so I don't think weather is affecting it, it's a Toyota deal and they need to resolve it.
  4. May 18, 2022 at 10:36 AM
    #214
    Tundra ron
    Tundra ron New Member
    Just took 2019 tundra in for same problem with sitting a couple of days .Doesn't happen that frequently but I'm getting documentation on problem because my factory warranty is almost out .Talked to mechanic and we assumed that possibly the reason that some people weren't hearing noise if they had ac on during starting was the initial cranking could have drowned it out maybe ?
  5. May 18, 2022 at 10:39 AM
    #215
    Tundra ron
    Forgot to mention that I had also had taken it in 11/2 years ago and they couldn't duplicate.
  6. May 18, 2022 at 10:42 AM
    #216
    Tundra ron
    Forgot to mention again that it's in shop right now will post outcome.
  7. May 18, 2022 at 10:52 AM
    #217
    Tundra ron
    Another quick note I haven't been driving it that much lately so it's been sitting more and the issue has been occurring more when I do start it. I wonder could it be compressor oil settling and I've read about this new freon but I can't see how that would affect it. Just guessing.
  8. May 20, 2022 at 1:35 AM
    #218
    Tundra ron
    Following up after getting truck back was told couldn't duplicate.Which I told them that morning because it had to sit a couple of days usually. I showed my videos of issue but claiming basically inconclusive. All I know is I've got documentation of my concerns and that I have informed them of issue in depth with audio and video so we will see what happens .
  9. May 20, 2022 at 3:42 AM
    #219
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    everyone; it's fine
    I_Am_Thee_Walrus and ATV25 like this.
  10. May 20, 2022 at 5:29 AM
    #220
    Tundra ron
    Until your warranty runs out.
  11. Jun 26, 2022 at 2:36 PM
    #221
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    There is TSB out on this noise. Toyota said oil accumulated in the compressor after sitting for days. When you start the compressor it has to clear the oil, or what I interpret as instantaneous hydraulocking the compressor. I found if I start the truck with the AC off and drive until idle reaches normal range and turn on AC no noise is present. Toyota races the rpm when engine first starts, which makes no sense but they do...
    denon28 likes this.
  12. Jun 26, 2022 at 2:37 PM
    #222
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    TOYOTA TSB #T-TT-0661-21
    denon28 likes this.
  13. Jun 26, 2022 at 2:39 PM
    #223
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Thanks for the info
  14. Jun 26, 2022 at 3:43 PM
    #224
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Awesome! Nice to see they acknowledged and assessed it. One less thing to worry about. It's seems like a generic issue which explains why I've had other vehicles do it.
    coldcanuk likes this.
  15. Jul 26, 2022 at 2:19 PM
    #225
    iloqin
    iloqin New Member
    2021 Cement Limited Crew Cab
    What does this mean? Will I get a fix for it or do I have to inquire about it? If the truck sits for a few days and I start it without the AC button on. Then press it after it starts up. I definitely hear that grind
  16. Jul 26, 2022 at 2:25 PM
    #226
    MadMaxCanon
    According to the TSB above it is normal, there is no fix since it would be normal operation. Maybe if you parked it on a steep hill it would stop the oil accumulation, would have to try it. Can either have the ac on when you start it or wait for the truck to warm up before you turn the ac on, both of those seem to work for me. my truck usually sits for 3-4 days at a time.
  17. Jul 28, 2022 at 9:54 PM
    #227
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    To avoid this noise, just don't turn the AC on as soon as you start driving. Problem solved.
  18. Jul 28, 2022 at 10:13 PM
    #228
    eagleguy
    eagleguy New Member
    If you leave the AC on low when turning the vehicle off I have found you will not hear the noise on next startup.
    Cpl_Punishment likes this.
  19. Aug 27, 2022 at 7:09 AM
    #229
    mpj76a
    mpj76a New Member
    What do you mean by "low"? My compressor is either on or off when I'm running it. Is it possible that maybe you caught it and turned the truck off while the AC compressor happened to be either engaged or disengaged? I've also found that I don't notice it if I leave the AC on at turn off and then start the truck the next day while knobs are still in on position. Perhaps during the few cranks it sort of clears out the settled stuff and allows it to ramp up whereas when it engages on a running engine it hits it full force???
    Mine does this as well almost every time if I turn on AC right after start up. Since I'm in FL, that's pretty much every time.
    21' with 3k mi.
  20. Aug 27, 2022 at 7:36 AM
    #230
    eagleguy
    eagleguy New Member
    When I shut the vehicle down I leave the AC on with the fan on low speed. In my case this stops the unit from making that noise that happens at startup when "everything" is turned off at shutdown. I am in Florida so this "was" a daily thing. Last time I was at the dealer for service I asked if what I was doing would cause any harm and they said no.
    denon28 likes this.
  21. May 13, 2023 at 6:45 AM
    #231
    p1ayn
    p1ayn New Member
    2021 TrdPro Tundra
    I'm new to this thread an ironically just noticed this in my 2021 trd pro tundra. My tundra is parked for 3 to 4 days at times every week at an airport. The last two weeks, which have been very hot, I noticed after starting the vehicle, (normal) Then ac I get a loud whoosh like noise.
    Everything works after an it did not do it again.
    That was two weeks ago. Then again, this week, it did again, so I checked in here. I'm glad to know it's a common problem. I recorded yesterday's altho it's hard to hear. I will try an upload. After the 4th beep u will hear the noise..it's brief an much louder in person. I tried to upload butsays unable due to extension?
  22. May 14, 2023 at 7:01 AM
    #232
    45to472024
    Sal
    You should take it to your dealer and have them check it, so when a solution is made you already have it documented with a dealer.
  23. May 14, 2023 at 11:09 AM
    #233
    p1ayn
    p1ayn New Member
    2021 TrdPro Tundra
    Will try again, after the 4th beep I turn ac on an u hear the grind.
  24. May 14, 2023 at 12:06 PM
    #234
    45to472024
    Sal
    Yup, same sound my truck makes.
