A/C Noise When Turning On
Discussion in 'General Tundra Discussion' started by kralc8954, Jan 31, 2019.
  1. Jul 23, 2021 at 8:38 PM
    #181
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I'm pretty sure that the effects on the starter are pretty much negligible since the A/C clutch would be switching on while cranking/starting anyway.
  2. Jul 23, 2021 at 11:23 PM
    #182
    PinnacleX
    PinnacleX New Member
    Bart
    2020 TRD Off Road
    We shouldn't have to find a workaround my new 2021 4Runner is dead silent, Ive tried it at 1300 rpm when first on and its like there isnt an AC turning on, not sure what Toyota did with the new Trucks?
  3. Aug 4, 2021 at 5:02 PM
    #183
    Firecapt1
    Firecapt1 New Member
    Just bought a 2021 Tundra Crewmax Limited (7/9/21) and with less than 200 miles on the truck it is making the same noise as described by all the posters. It's freaky since it's loud and sounds like it might be causing major damage. I get the exact same thing everyone else does, when cold or having sat for a couple of days the noise occurs when turning on the A/C. It only happens once and just for a couple of seconds, then no problem the rest of the day. A/C works as it should. Haven't taken it in yet, but I put the provided video on my phone and will play it for the service writer and see what they say. I'll post back with an update.
  4. Aug 4, 2021 at 5:12 PM
    #184
    Elduder
    Elduder New Member
    Just some personal history on this, my FJ, 4runner and Tundra have all done this exact same thing. I havent read the entire thread but yes if the clutch engages after sitting for some time it can make a loud groan or noise, I swear its been bad enough at times to feel like it shift the motor a bit.
    Here's the thing, the FJ had a good 80k+ miles on it, the 4Runner has 30k and both my Tundras have had it. None of them have had any actual issue though. A noise, albeit annoying, isn't always a sign of impending failure.
    Tundra805 likes this.
  5. Aug 4, 2021 at 5:43 PM
    #185
    Firecapt1
    Elduder,
    Of course you're right, not all noises portend a catastrophe. I'm still getting used to it because it's so new and this particular noise sounds bad; I hope it turns out to be just an idiosyncrasy with Tundras:fingerscrossed:.
    Thanks for your reply!
    Elduder likes this.
  6. Aug 4, 2021 at 5:46 PM
    #186
    Elduder
    Elduder New Member
    I understand the initial concern, took me a while to even figure out what was happening since it only happens once in a while. Now, Ive just been hearing it for years and am used to it. It actually happened last week and was pretty loud, I just chuckled.
  7. Aug 14, 2021 at 5:39 PM
    #187
    ricardo1979
    ricardo1979 New Member
    Rick
    2021 Tundra SR5 crewmax TRDsport
    Stock
    My 2021 crewmax has been making this ac noise too when it sits for a day or two. I actually caught it on camera. Dealer can’t do anything without it being recreated. Of course it won’t do it for them.
  8. Aug 14, 2021 at 5:46 PM
    #188
    TILLY
    Massachusetts
    Did you show them the vid?
  9. Aug 15, 2021 at 6:53 AM
    #189
    ricardo1979
    Rick
    Stock
    The video does not show the source of the noise. I set my phone on the engine bay while I turned the ac on. It does however capture the sound and the engine jolting when the ac is engaged. The tech thinks it might be the ac clutch.
  10. Aug 15, 2021 at 7:13 AM
    #190
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I have a 2019 Platinum, mine did the same thing yesterday. We have had the truck for 3 months or so and this is the first time it was noticed.
  11. Aug 26, 2021 at 3:31 PM
    #191
    Randy F
    Randy F New Member
    2021 Voodoo blue tundra sport premium
    Add me to the list. 21 with 4700km. Does it when starting up and leaving it in auto or turning the ac on after starting it. Only happens after it sits awhile.
  12. Aug 26, 2021 at 3:38 PM
    #192
    zach_attack4
    zach_attack4 New Member
    Zach
    York, PA
    21 Army Green CM
    Purchased mine new in December and it makes the same noise under the same circumstances as everyone else. Only 3k on it.
  13. Sep 14, 2021 at 4:19 PM
    #193
    Firecapt1
    Has anyone gotten a definite answer or a fix from Toyota for this? It's driving me crazy and the noise is bad enough that eventually (a day, a month, a year) something is going to self destruct and send metal flying all over the engine compartment. I too believe that it has something to do with the A/C compressor clutch.
  14. Sep 17, 2021 at 6:30 PM
    #194
    Calvary_Blue~Baby!
    Calvary_Blue~Baby! New Member
    2021 Calvary Blue Tundra TRD Sport
    Rough Country 3.5 lift, front coilovers, V2 rear shocks. Fuel Siege wheels 20x9 1 offset. Atturo Blade XT 33x12.5 tires. Go Rhino RB20 running boards.
    Unfortunately "Big Blue" has the same problem. I have an appointment on wed 9/22. I plan to park it at the dealership on Monday to allow proper sitting time. I will let everyone know if a solution is reached. Lord willing not a big issue.
    God bless.
    OHwendTrd and Firecapt1 like this.
  15. Sep 23, 2021 at 4:31 PM
    #195
    Calvary_Blue~Baby!
    Went to dealership today. The noise did not recreate. Mechanic explained that the ambient temperature today being only 65 and low humidity may have something to do with it not happening. He said the pressure in the system on hot humid days may cause the ac clutch to engage hard on first use after sitting. They noted and would check if Toyota has any info about it. They said I could bring it back or record it with the hood up and someone else turning on the ac. Will update any news
  16. Sep 23, 2021 at 4:44 PM
    #196
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    So just curious. I noticed on first start in the mornings my truck will give this "vvrrrrrmmm" sound a few times as I'm pulling out. It sounds like a vibration but can't feel it. It then stops after just a few seconds. Is this similar to what is being discussed in here?
  17. Sep 29, 2021 at 1:34 PM
    #197
    Calvary_Blue~Baby!
    It's 83 today and truck sat for two days. Made noise when started ac. Got it an video. Trying to upload, won't let me
  18. Sep 29, 2021 at 2:05 PM
    #198
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Upload it to YouTube then post a link here.
  19. Sep 29, 2021 at 2:37 PM
    #199
    GatorBodine
    GatorBodine New Member
    21' Limited here.....my A/C also makes the hard clunk sound, seems it does it when the the AC system is shut off at last engine shutdown and when turning on the AC after starting the engine...... "CLUNK"
  20. Sep 29, 2021 at 5:00 PM
    #200
    Calvary_Blue~Baby!
  21. Oct 1, 2021 at 1:19 PM
    #201
    Randy F
    Randy F New Member
    Hey all. Took my truck in this week. Left it for a day but of coarse it was not long enough and it didn't happen. Met up with the shop forman and had a good chat explaining what the noise was and how embarrassing it is on a new truck. To my surprise they agreed and replaced the ac compressor and clutch. Time will tell now if it still does it and if it comes back. Will keep everyone updated.
  22. Oct 1, 2021 at 3:04 PM
    #202
    Randy F
    Randy F New Member
    Well..... Its still there with all new stuff. Guess I'll carry on
    Cpl_Punishment likes this.
  23. Oct 1, 2021 at 6:57 PM
    #203
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sorry to hear that but it's honestly about what I was expecting. No way every single Tundra has a bad compressor and clutch.
  24. Oct 7, 2021 at 2:37 PM
    #204
    Calvary_Blue~Baby!
    Dang sorry to hear that
  25. Oct 7, 2021 at 2:59 PM
    #205
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Exact same here, but I have had other cars do it so im not too worried at this point.
  26. Oct 7, 2021 at 3:55 PM
    #206
    Calvary_Blue~Baby!
    The service advisor showed the video to the manager and he said it has to be the compressor. They are looking into if there is multiple part numbers for a replacement. I also sent them a link to this thread.
  27. Nov 18, 2021 at 5:04 PM
    #207
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Same issue here on my 2016. I hadn't noticed it happening till this summer. I was driving down a steep hill and had downshifted to use engine braking so the engine was turning at probably 3K RPM and I turned the A/C on. It sounded like someone running their fingers up and down wooden louvers, a flap flap flap flap sound, that didn't quit until I turned off the A/C. Turning it back on, it was fine. :(
    Then a few times I would turn the A/C on after turning out of my neighborhood and it makes a heck of a racket if I'm accelerating (engine at 2000-3000RPM) and will actually cause the engine to bog/stumble but only lasts a second, like what others have posted in videos.
    Once when I left the engine running and got out to do something, I noticed when the compressor would cycle on, there would be a rattle, kinda like shaking a golf ball in a coffee can for a second. I had my kid turn the A/C on and off while I watched under the hood and saw the tensioner pulley closest to the compressor wobble fore and aft so I think that's the source of the rattle sound. That makes me wonder if, when the compressor first turns on, the belt is trying to find another path of least resistance and slams that tensioner.
    Mine did it again today when the outside temperature was 37deg F. I let the truck warm up for about 2-3 minutes with just the heater fan running. Realized I'd fogged up the windshield and so I switched it over to defrost and bang. So it's not only warm temps.
    The video a few posts above was taken on the driver's side but I can't quite see the compressor and tensioner that is on the passenger side. I'll see if I can get a video of mine and see if my hunch on the tensioner slamming around is the culprit.
    2WD likes this.
  28. Nov 19, 2021 at 7:51 PM
    #208
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Great post. Really looking forward to seeing your video on the tensioner.
    Mine does this sometimes. I can’t quite replicate it but maybe with your video I can try to duplicate.
  29. Jan 31, 2022 at 9:56 PM
    #209
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    So has my 2021. It happens if the truck sits for a day or two or more then you turn the AC on. Its a grinding loud noise. Only does it when first turned on. After that, there is no noise. Its only if it sits for a while.
  30. Feb 1, 2022 at 9:28 AM
    #210
    Tundra805
    Tundra805 Quality. Durability. Reliability.
    Tennessee
    2020 CrewMax SR5 TRD 4x4 5.7 Cement
    On my 2020 SR5 I have the same loud, clunking, metal on metal sound on start up with AC already on (from when I shut it off). Only happens after truck has sat for 24+ hours. Has been that way since day one. My previous 2017 did the same thing. Never had any issues. Like another poster said, our Tundras make lots of noises. I actually like all the mechanical noise, with the reliability also of course.
