A/C Noise When Turning On
Discussion in 'General Tundra Discussion' started by kralc8954, Jan 31, 2019.
  1. Aug 13, 2019 at 8:09 AM
    Hogman9507
    Hogman9507 New Member
    Charles
    2019 Tundra Ltd.
    FreonJohn,
    You got a good point.
    My truck sat 2 days and before I started it up, I went underneath and turned the compressor pulley to see if it showed resistance. It was extremely hard to turn.I waited until I ran the truck and AC, later that day when the engine cooled.The compressor rotated easily by hand
    SomeGuy4 likes this.
  2. Aug 19, 2019 at 5:54 PM
    KEG89
    KEG89 Proud American
    Kyle
    Ohio
    2019 White TRD Pro
    Ok I’m throwing my truck in the ring. 2019 TRD Pro owned since new, currently has 9.2k miles. After the truck sits a day or more and is started and A/C engaged I too get a loud unhealthy clunk. Someone has to have had luck with a diagnosis:fingerscrossed::annoyed:
  3. Aug 21, 2019 at 3:18 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    My 2014 just started doing this yesterday. To me, it sounds like it might be tensioner related. Only after it sits for awhile, and the sound goes away quickly. I wonder if it's related to humidity and the fact that lately my ac has been run to death cause it's SO miserable right now in central VA. Or, something is about to break. Guess I'll wait and see.:boom:
    Tundyfundy likes this.
  4. Sep 17, 2019 at 6:35 PM
    AdamB5280
    AdamB5280 New Member
    2018 Tundra Platinum
    Minor
    Same here 18 Platinum 25k miles. Getting a sound from the a/c. Thinking it might be the fan motor? It comes and goes, definitely annoying! Can't believe Toyota doesn't have a diagnosis with how common this issue seems to be.
  5. Nov 3, 2019 at 2:45 PM
    Cghuser
    Cghuser New Member
    I own a 2019 5.7 has about 33k on it and owner since brand new. I hope this comes to resolution soon as I am almost out of factory warranty. Has anyone heard anything? Mine does exactly what everyone else has explained, once while coasting it actually shuddered the gas pedal and motor and once while at idle after starting. It’s got to be the clutch or tensioner but it’s not very smooth whatever it is.
  6. Nov 4, 2019 at 5:42 PM
    Mr Badwrench
    Mr Badwrench New Member
    Mine does it. It sounds terrible. Only happens after leaving it parked over night, or when it is cold outside. When I push the AC, button "CLUNK".
    Can't wait to replace the AC compressor, it is so conveniently located!
  7. Nov 4, 2019 at 6:55 PM
    bigandtall
    bigandtall New Member
    Indianapolis Motor Speedway
    On mine it sounds like a large metallic mid range chirp.
  8. Nov 4, 2019 at 8:02 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Please let us know if you hear back.
  9. Nov 7, 2019 at 10:34 AM
    mi4
    mi4 New Member
    I guess my 19' CrewMax with 1200 miles has same issue. To confirm, I took a short clip https://youtu.be/MM7pPGatitQ Since I lost my key (probably when working on the truck), now I always think I dropped the key under the hood and relate any suspicious noise to it. :(
    SomeGuy4 and El Cucuy like this.
  10. Nov 7, 2019 at 10:41 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    YUP, that’s the noise!
    El Cucuy likes this.
  11. Nov 7, 2019 at 10:52 AM
    mi4
    mi4 New Member
    Thanks for confirming that. I am surprised and disappointed that Toyota can't figure out what this noise is after so many people experience it.
  12. Nov 7, 2019 at 11:08 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    We all feel the same way, sounds like shit and I’m embarrassed when it happens and others around me hear it.
  13. Nov 11, 2019 at 7:13 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
  14. Feb 1, 2020 at 3:30 PM
    Charlo75
    Charlo75 New Member
    Joe
    2019 Tundra Crewmax
    Same here on my 2019 Crewmax with 10.7K miles. It's done it periodically since I got it in July of 2019. Happened again today for the first time in a while. Temp outside was 63°. Low last night was 35°. It was not humid. Luckily I had my dash cam on and pressed the AC button after it was recording. I'll use that at my dealer the next time I take it in.
  15. Feb 1, 2020 at 3:34 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Having issues myself. Compressor is loud when activating and regardless of settings - compressor is always engaged. Turns out my AC amplifier is being replaced.
  16. Apr 2, 2020 at 6:39 PM
    lev
    lev New Member
    Hi all I have a 2014 tundra 5.7 40k Noisy a/c compressor, noise is available al the time when on. At idle sound as though it rattles at speed or when accelerating it sounds like a super charger. I have never heard of an a/c amplifier! has anyone fixed their problem. I am pricing a/c compressors as we speak.
  17. Apr 2, 2020 at 7:22 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Let it sit for a few days. Then video outside while someone turns it on. Try the catch the clutch and the belt. Mine does this too. I believe it is the refrigerant and oil has settled in the compressor and shocks the belt when engaging the compressor. I have experienced this in other vehicles. I have worked with other refrigerants but not the R1234YF yet.
  18. Apr 10, 2020 at 6:50 PM
    Mamba
    Mamba New Member
    Manny
    2020 Tundra Limited 4x4
    None
    same issue here on a 2020 1794 with 2k miles. This sucks
  19. Apr 13, 2020 at 12:51 PM
    #49
    Chris31909
    Chris31909 New Member
    2020 Tundra TRD Pro
    None
    Mine does the same thing, probably another normal noise the truck makes along with the others
  20. May 8, 2020 at 3:15 PM
    #50
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    My 2019 does it too with 13,000 miles on it. Anyone heard of a fix? The sound is pretty intense to ignore.
  21. May 8, 2020 at 3:27 PM
    #51
    lev
    lev New Member
    This noise is a bad compressor just replaced the one on my 2014. I did not notice the noise till just after the warranty was out. If you are under warranty get it taken care of and get a rental on the house.
  22. May 11, 2020 at 8:50 AM
    #52
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    @lev Typical new gen toyota junk
  23. May 19, 2020 at 11:31 AM
    #53
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I have this same noise on my 2019.
  24. May 19, 2020 at 12:21 PM
    #54
    Hogman9507
    Charles
    2019 Tundra Ltd.
    Anyone found a fix for this AC noise yet
    I think FreonJohn was spot on
  25. May 19, 2020 at 12:27 PM
    #55
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Add another. 2020 SR5 w/1200 miles. Done it since I brought it home.
    I think the worst part is trying to explain to the wife how it appears to be "normal". And yes, Toyota, the noise is bad enough our wives are even noticing it! :rofl:
  26. Jun 11, 2020 at 3:37 AM
    #56
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    Add one more. I have a 2020 with 3,000 miles. I've noticed the noise twice but after two times I searched this site and of course I found others had documented it. Once yesterday afternoon (95 degrees and sunny) and once two afternoons ago (90 degrees and sunny). Both times it happened, the AC was already on and the noise happened during start-up. Both times, the truck had sat for 24 hours. Today I'm going to start it with the AC off and then turn it on after it's running. The noise that @mi4 has in the video is the exact noise I hear.
    Doxiedad likes this.
  27. Jun 11, 2020 at 4:42 AM
    #57
    Freonjohn
    Freonjohn New Member
    If I had to take a guess I think it’s because a Suction accumulator is no longer used but instead has been replaced with a liquid to suction heat exchanger.
    The accumulator is to prevent liquid refrigerant from making its way to compressor
    the heat exchanger won’t, its there for efficiency purposes
    Just my opinion as a 29 year commercial refrigeration technician
  28. Jun 11, 2020 at 5:04 AM
    #58
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Isn't liquid to a compressor a very bad thing? How do you keep it from tearing itself apart without a suction accumulator?
  29. Jun 24, 2020 at 9:59 PM
    #59
    jvt3
    jvt3 New Member
    Mine has that very strong "clunk" sound too when turning the AC on for the first time each day......on a fairly new truck. There's no
    way to know how common this is among Tundra owners though....I hope it's considered "normal".
  30. Jun 25, 2020 at 7:11 AM
    #60
    co2owen
    co2owen New Member
    VA
    I've not had the AC noise since my last post. Not sure why it came and went. No noise now when starting truck up with AC already on or starting truck up and then turning AC on. It'll probably come back, but for now it's gone.
