A/C clunk
Discussion in '2.5 Gen Tundras (2014-2021)' started by netranger6, Jul 20, 2018.
  1. Jul 20, 2018 at 4:22 PM
    netranger6
    netranger6 [OP] New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    My truck sits. 5 days of the week. 4600 miles since November. 2 PCS repairs. Started it tonight. Hit ac, and it sounded like a clunk or grind. Did it last week too. Temps are 100 or so and high humidity here in South Texas. AC works fine and doesn't seem to repeat the clunk grind after cycling it in and off again. Ideas??
  2. Jul 20, 2018 at 4:27 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Mine does the same after a week of sitting. My Tacoma did it also. I think the clutch gets a little hung up. Good news is they both always worked and no compressor replacements. If you wait a little bit it doesn’t seem to happen. Only right after starting.
    GNTundra likes this.
  3. Jul 20, 2018 at 5:12 PM
    netranger6
    Jeremy
    Yeah. That's it my 14 and my 12 didnt do it. Nor did my 05 taco
  4. Jul 20, 2018 at 5:13 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Similar experience on my 2014 tacoma.
  5. Jul 20, 2018 at 5:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Mine does it occasionally when it’s really hot. No way I’m going to get the dealer to replicate it so haven’t done anything about it. Kinda relieved to hear it’s semi normal.
  6. Jul 20, 2018 at 6:32 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I guess just let it run for a few minutes before hoping in to take off. Try that and report back?
  7. Jul 21, 2018 at 6:13 AM
    netranger6
    Jeremy
    Normally I let engine fully warm.
  8. May 4, 2019 at 8:12 PM
    wsrookie
    wsrookie New Member
    Anthony
    2019 Tundra 4X4
    Netranger6, I have the same issue, my truck sits all week and I use it on the weekend. My 2010 never had an issue but this one makes a lot of noise when I turn on the AC after sitting. Sounds even worse it the AC is on when I start it. Have you had any additional issues with your AC? Anything replaced?
  9. May 6, 2019 at 6:15 PM
    netranger6
    Jeremy
    No. Just live with it for now. Like I said, only hppens afer it sits for a while.
  10. May 6, 2019 at 6:17 PM
    Where in South Texas are you?
  11. May 6, 2019 at 7:48 PM
    Jeremylee
    Jeremylee New Member
    Jeremy
    Tundra limited TRD
    Mine makes the same fuss....
  12. May 8, 2019 at 11:24 AM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Mine does this as well. Has done it since day 1. Got it brand new off the lot and it's only once every now and then and has never impacted performance. Seems to be impossible to duplicate so I never took it to the dealer. Just every now and then on really hot days on the first start and first time I turn the AC on it'll grind for a second and kick on.
  13. May 8, 2019 at 1:37 PM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    My 2016 did it, and so does my 2019 I just got after it sits for a couple of days. If it works I'm not taking it to the dealer.
  14. May 8, 2019 at 1:40 PM
    TFONG95
    TFONG95 New Member
    Sacramento
    2019 SR5 Off Road
    My 2019 does this too. Seem to happen when i let my truck sit for a couple days. I will even start the truck up and warm it up for a few minutes before turning on the AC and it will make that sound.
  15. May 8, 2019 at 1:45 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    My 2018 does the same sh$$..
  16. May 8, 2019 at 5:49 PM
    netranger6
    Jeremy
    victoris
  17. Apr 17, 2020 at 1:32 PM
    Chris31909
    Chris31909 New Member
    2020 Tundra TRD Pro
    None
    My new 2020 does this exact same thing when first turning on the ac even after sitting just overnight. It seems to be working fine and cooling just makes that noise only the first time to turn the ac on or if you left the ac on when you turned the truck off and restart it after sitting. Unless something breaks or quits working I’m just writing it off as another annoying noise the truck makes lol
  18. Apr 17, 2020 at 2:24 PM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    2016 here and mine does it too. I do notice if I shut the ac off before turning my truck off and keep it off until it’s warmed up a little, it’s not as noticeable. It doesn’t bother me enough to take to the dealer. It still blows good cold air. My truck is also a weekend warrior. Roughly 5-7k/year.
  19. Apr 17, 2020 at 10:07 PM
    SilentSteven
    SilentSteven New Member
    2020 Platinum
    My 2020 does this too. Has anyone been able to get the dealership to do anything about it?
  20. Apr 17, 2020 at 10:39 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    I noticed the same thing when I tried the same thing, it’s just out of my ordinary to turn it off and back on after warm, I’m used to just leaving it on when I shut the truck off and then when I start it I hear that loud clunk noise coming from the compressor clutch and or the belt. I can immediately shut the truck off after I hear the noise and when I restart the truck it doesn’t make the noise again, only on the first start of the day...weird but I’m sure there is some sort of mechanical reason as to why it happens but it doesn’t seem to be having a negative effect on the ac system so I’m gonna just live with it. Maybe one day there would be a TSB come out about it but as of now I haven’t seen one.
  21. Apr 17, 2020 at 10:42 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    I haven’t seen anybody talk about a dealership remedy, if anyone does have a dealership trip about this issue I hope they post about their experience whether good or bad
  22. Apr 18, 2020 at 8:27 AM
    cch2a
    cch2a New Member
    Mine sits all week and does this too. 2017 bought new.
  23. Jun 12, 2020 at 9:28 PM
    AZ_Tundra1
    AZ_Tundra1 Gold member
    Phoenix, AZ
    2020 White Tundra SR5
    Bilstien 6112 front shocks set at 1.9"
    I had the same issue, took it to the dealership, they even let it sit overnight and couldn't reproduce the sound.
  24. Jun 24, 2020 at 1:20 PM
    AZ_Tundra1
    Phoenix, AZ
    I got it on video https://youtu.be/bwL8vi6pEqo
  25. Jun 24, 2020 at 1:26 PM
    SilentSteven
    2020 Platinum
    That’s the exact same noise mine makes. Mine consistently does it if I turn the A/C on before the engine is fully warmed up. I haven’t had a chance to take it to the dealership.
    AZ_Tundra1[QUOTED] likes this.
  26. Aug 18, 2020 at 4:19 AM
    edwardc_
    edwardc_ New Member
    Edward
    2020 Tundra
    Any resolution on this?
  27. Aug 18, 2020 at 6:37 AM
    Cjames17
    Cjames17 You gotta wanna
    Indiana
    2019 Black SR5 TRD Sport CM
    What kind of resolution are you looking for? Does your A/C work? My truck makes this noise as well, but i have never had any issue with my air not blowing cold. So like the ABS self check, i just learned to live with it.
  28. Aug 18, 2020 at 6:46 AM
    edwardc_
    edwardc_ New Member
    Edward
    2020 Tundra
    Just wondering the fix for it mine does it too but I notice it only does it when my temp shows over 100 degrees in my truck, it’ll make that loud clunk. It does blow cold no issues with that. But yeah it’ll do it once then stops after that.
  29. Aug 18, 2020 at 8:08 AM
    AZ_Tundra1
    Phoenix, AZ
    I had it yesterday where the truck was sitting in 115 weather and was in reverse when I turned the ac on, the truck almost felt like it stalled out, it robbed a ton of power to crank the ac on, so it definitely seems like an issue that only happens in after sitting in 100+ heat. The dealer sho saw the video kept my truck for the better part of a week and was unable to reproduce or spend more shop time trying to figure it out, he said it's documented now so if it grenades, then I'll be covered, even likely out of warranty for a bit.
  30. Sep 5, 2020 at 11:00 AM
    SaltH20
    SaltH20 New Member
    2019 Tundra SR5 5.7
    Add my truck to the list. 2019 DC 5.7 w/5700 miles (not driving much these days due to COVID). Makes this same exact noise as AZTundra1 in the video. If I drive it everyday, it does not make that racket. Let it sit 2-3 days and it sounds like something slamming together (AC clutch?). I'm taking it to the dealer for my first oil change, etc and will have the dealer look into it. I will post up what they say. Normal? No other vehicle I have owned makes this kind of noise when the AC is engaged (Fords, Hondas, current Mazda 6).
    AZ_Tundra1 likes this.
