A/C button help
Discussion in '1st Gen Tundras (2000-2006)' started by Toyoda4win, Sep 2, 2022.
  1. Sep 2, 2022 at 3:26 PM
    Toyoda4win
    Toyoda4win [OP] New Member
    Drew
    2004 grey Tundra SR5
    Couldn’t figure out why my A/C button keeps turning off then green light comes on then goes off. Well after research and research I tried holding the button in while driving and it stayed on so I have wedged a pen too to hold it in and it’s staying on so how do I find the button or is there a sensor behind it in need to replace can’t find any info what to look up and purchase thanks 2004 tundra 2wd V8
  2. Sep 2, 2022 at 7:36 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Not to Patronize you but do know that the AC light only comes on when the fan is on. If the light wont stay on in the on position. Probably a contact problem in the switch. Not an easy fix. Gotta pull that front panel off to replace or fix it.
  3. Sep 2, 2022 at 8:33 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If it is the switch itself that's faulty I do think it would have to come apart. If you get to any point and it won't go back together for some reason make sure if you buy a new bezel it's from the same year and same 2wd/4wd setup or you will have issues. There's a lot of these bezels that look identical but for whatever reason operate totally different.
  4. Sep 2, 2022 at 11:32 PM
    Toyoda4win
    Drew
    Thanks for the info guys and yes correct light comes on when pushing button in but will stay on or go off any moment will try have time tomorrow to remove the bezel thank you
  5. Sep 2, 2022 at 11:53 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    it doesnt flash does it? flashing a/c light means somethings wrong with the system. at least i think these trucks were new enough for that.
  6. Sep 3, 2022 at 12:12 AM
    Toyoda4win
    Drew
    Doesn’t flash it just with button pushes in it goes on and off as it pleases. Well I wedged that pen too in there early today and it works perfectly fine. Wondering if there is a switch behind that button that is bad
  7. Sep 3, 2022 at 2:49 AM
    NickB_01TRD
    Nick
    KY
    My shitbox 96 Camry has a flashing A/C light so it goes back that far at least.
  8. Sep 3, 2022 at 3:07 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    A more obvious question, perhaps...does the AC run while the switch is pushed in, but the lamp is off?
