A build for speed and handling, I know it sounds crazy.
Discussion in '2.5 Gen Builds (2014-2021)' started by Fastlane47, Feb 5, 2021.
  1. Nov 22, 2022 at 10:25 AM
    #241
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Prospeed fuel lines?
  2. Nov 22, 2022 at 12:23 PM
    #242
    Fastlane47
    Fastlane47 [OP] New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    Nope, we made them from a kit. Very easy to do. Search Evil energy on Amazon, you can build a fuel system yourself.
    M3Tundra-JK[QUOTED] likes this.
  3. Nov 22, 2022 at 12:25 PM
    #243
    Fastlane47
    Maryland
    2018 Platinum
    My truck has a smooth ride for a lowered truck with low profile 22's.
  4. Nov 26, 2022 at 3:37 PM
    #244
    M3Tundra-JK
    Scott
    2005 GX470
    This the one? Want to double check before I place the order. Anything else to consider while I'm at this?
    https://www.amazon.com/EVIL-ENERGY-Fitting-Braided-Universal/dp/B081W79ZC1
    Edit:
    Apparently Amazon says this link is a newer version of the same kit
    https://www.amazon.com/EVIL-ENERGY-Braided-Injection-Stainless-dp-B0922M63H8/dp/B0922M63H8
  5. Nov 26, 2022 at 4:00 PM
    #245
    Fastlane47
    Maryland
    2018 Platinum
    That will work, you should need anything else. Look up Viktor G 1k HP fuel system. Shows you everything you need.
    reywcms and M3Tundra-JK like this.
  6. Nov 26, 2022 at 4:20 PM
    #246
    M3Tundra-JK
    Scott
    2005 GX470
    Admittedly I was being lazy and not watching the videos. But whatcha know, all the info is there lol
  7. Nov 26, 2022 at 4:21 PM
    #247
    Fastlane47
    Maryland
    2018 Platinum
    Yes, he does an amazing job with tech info, his videos are a big help.
    M3Tundra-JK likes this.
  8. Nov 26, 2022 at 5:16 PM
    #248
    M3Tundra-JK
    Scott
    2005 GX470
    Did you do a return fuel line? I'm probably going to, just trying to think how much extra line I need for that. Guessing an additional 10ft would work
    Fastlane47[OP] likes this.
  9. Nov 26, 2022 at 5:42 PM
    #249
    Fastlane47
    Maryland
    2018 Platinum
    That should be fine, you may not need it, but it can't hurt. I didn't do a return line myself.
  10. Nov 30, 2022 at 6:10 PM
    #250
    Fastlane47
    Maryland
    2018 Platinum
    Drivability tuning is done, going to the Dyno tomorrow for WOT tuning. I switched the gauges to AEM, the Glow shift didn't work like I hoped.
  11. Dec 7, 2022 at 4:36 PM
    #251
    Fastlane47
    Maryland
    2018 Platinum
    Under WOT the number one cylinder injector started to cause a misfire, need to pull it out and see what's happening. I was surprised to see it made 450whp on 7 cylinders. IMG_20221207_190123.jpg
    e30cabrio, J&ATundra, D4x4TRD and 4 others like this.
  12. Dec 9, 2022 at 7:41 AM
    #252
    M3Tundra-JK
    Scott
    2005 GX470
    Question on your paint matched mirrors and door handles. Since you have the Platinum, do you also have the smart door handles? The set Sparks sells for mirrors and handles is like $350, but they don't work on smart handles.
    They sent me a link that's just for the handles, and that kit is over $500! and the only difference is the front two handles. I may have to get the original kit and then figure something out for the front two handles.
  13. Dec 9, 2022 at 7:44 AM
    #253
    Fastlane47
    Maryland
    2018 Platinum
    Mine is an 18, so not smart door handles.
  14. Dec 21, 2022 at 10:36 AM
    #254
    Fastlane47
    Maryland
    2018 Platinum
    All done, I decided to go with AEM, the Glow shift didn't work after installing them. Made 509 to the 22in wheels. PXL_20221221_152325989.jpg PXL_20221221_182611597.jpg PXL_20221221_182925389.jpg
  15. Dec 21, 2022 at 1:57 PM
    #255
    centex
    centex New Member
    That’s a nice torque curve.
  16. Dec 22, 2022 at 6:46 AM
    #256
    Fastlane47
    Maryland
    2018 Platinum
    I can honestly say the supercharger is much louder than before, with the PS intake. Driving along, I can make the air filter sing by just tapping the gas pedal.
    M3Tundra-JK and DannyD303 like this.
  17. Dec 23, 2022 at 4:11 PM
    #257
    Fastlane47
    Maryland
    2018 Platinum
    I did some WOT pulls on the highway to see what kind of boost leaves I would hit with the 2.3 pulley, PS intake and RFC throttle body, I was getting 11.3 on my gauge.
  18. Jan 4, 2023 at 11:36 AM
    #258
    M3Tundra-JK
    Scott
    2005 GX470
    How do you feel about these after having them a while? Would you buy them again if you had a do over?
    They're closest style to what I'm looking for, but expensive
  19. Jan 4, 2023 at 11:39 AM
    #259
    Fastlane47
    Maryland
    2018 Platinum
    Love them.
  20. Jan 14, 2023 at 8:01 AM
    #260
    Fastlane47
    Maryland
    2018 Platinum
    The shop that tuned the truck made this video of it, they could have cut out us talking so much, but it gives a better look at the truck.
    https://youtu.be/pTZAXEisAvI
  21. Apr 12, 2023 at 6:08 AM
    #261
    Fastlane47
    Maryland
    2018 Platinum
    After a few data runs, @snivilous could see that the truck was running lean and on the dyno tune was picking up knock on the top end. I have ordered the Prospeed fuel system, since I already have the 750 injectors from them and the 450 fuel pump, I think it will be needed. Hopefully this will help out.
  22. Apr 12, 2023 at 7:25 AM
    #262
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Was your injector duty cycle maxed and it was still lean? Also wondering if you’re running the stock 43psi fuel pressure regulator and if you have it boost referenced. I may spring for a similar setup one day as far as 4.5” intake and RCF TB so just trying to get a better understanding.
  23. Apr 12, 2023 at 7:48 AM
    #263
    Fastlane47
    Maryland
    2018 Platinum
    I have the stock FPR and rails, not completely sure what the fuel pressure is. Having a bigger pump and injectors helped out well with the stock intake and TB, but now I need to add the bigger lines, rails and FPR for the RCF and PS intake.
    Silver17 likes this.
  24. Apr 12, 2023 at 8:12 AM
    #264
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The duty cycle isn't maxed out, I just can't get the truck to inject more fuel. I've tried nearly everything from using COTS to enrich it, to using injector multipliers, etc. and the thing just won't richen out. I literally have the PE and COTS maxed out and the truck says the commanded AFR is extremely rich but it'll just bounce between 11-13. I'm not sure what the deal is, seems like it's running out of pressure. Or maybe I just suck at tuning. His datalogs are very similar to e30cabro's though (where the truck says it wants rich and then runs away lean, though not as bad as e30s were originally), so hopefully getting a reading on fuel pressure will get some clarity why the truck isn't responding to fueling changes in the tune.
  25. Apr 12, 2023 at 8:20 AM
    #265
    Silver17
    Eastern PA
    Could be worth a try running the FPR to boost reference to keep the pressure up when boosting. If it’s 43 at idle and he’s running 11psi the pressure could be dropping off to 32psi.
  26. Apr 12, 2023 at 9:14 AM
    #266
    Fastlane47
    Maryland
    2018 Platinum
    You do a great job, we will get this figured out. I will run the FPR to boost and set the pressure at 60psi.
    ZPhilip, e30cabrio, Silver17 and 2 others like this.
  27. Apr 12, 2023 at 11:50 AM
    #267
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My solution was a functional pump.
    Now it's too rich.
    lol
  28. Apr 19, 2023 at 3:52 AM
    #268
    Fastlane47
    Maryland
    2018 Platinum
    The fuel system has arrived, install is today.PXL_20230419_105031876.jpg PXL_20230419_105046894.jpg
    armyoffoo, reywcms and HulkSmurf14 like this.
  29. Apr 23, 2023 at 7:09 PM
    #269
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    Nice build there, Congrats. Was funny to watch the guy in psgr seat go rocking with his cam @ 5:35 Lol
  30. Apr 23, 2023 at 7:24 PM
    #270
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Freakin wicked brother!
