93 octane impressions
Discussion in '3rd Gen Tundras (2022+)' started by ARB1977, Apr 29, 2025.
  1. May 2, 2025 at 4:28 AM
    #61
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    *NSFW* potty language
    raylo likes this.
  2. May 2, 2025 at 5:41 AM
    #62
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    Eddie stress testing those new main bearings!
    Daedalus likes this.
  3. May 2, 2025 at 5:43 AM
    #63
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    You are a novice. I also add generous amounts of WD40 spray to all four tires to reduce rolling resistance. 25% better fuel economy right there! :D
    Corndog123 and EmergencyMaximum like this.
  4. May 2, 2025 at 5:47 AM
    #64
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Tundra ain't Prius, we combat rolling resistance with gas.
  5. May 2, 2025 at 7:40 AM
    #65
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    raylo[QUOTED] likes this.
  6. May 2, 2025 at 7:54 AM
    #66
    VCheng
    VCheng New Member
    Upstate NY
    So you eat beans before every drive? Please clarify. :D
    kirkb and EmergencyMaximum like this.
  7. May 2, 2025 at 8:59 AM
    #67
    pursuit2550
    pursuit2550 New Member
    You guys don't take anything serious. I was genuinely wondering what oil would work best. Now I have to go through hundreds, probably thousands of thread to find my answer. Then if I am not satisfied, I will Google my question and go down that rabbit hole.
    Anyways, I was also wondering what the biggest tire I can run without a lift. Now be serious, just like I am.
    Hammertimerrrr and chrisgibbs707 like this.
  8. May 2, 2025 at 9:30 AM
    #68
    DRP
    DRP Old Member
    Dave
    The biggest tire you can run is the one that won't rub on something......
    Raven67, BlackNBlu and CRFL82 like this.
  9. May 2, 2025 at 9:49 AM
    #69
    eddiefromcali
    Eddie
    100% Stock
    BTW, if we are talking fueling and such....I've gone up to E50 and this fuel system can handle it on the added boost map. Not sure of anything higher than that but fuel trims and AFRs were steady at WOT with JB4 map 5. Having this robust fuel system will def be to our advantage when running hotter tunes on any for of E85 blends.
  10. May 2, 2025 at 9:59 AM
    #70
    Breathing Borla
    AZ
    your stock though....:anonymous::p
  11. May 2, 2025 at 10:01 AM
    #71
    Daedalus
    Daedalus New Member
    What did IDC look like?
  12. May 2, 2025 at 10:28 AM
    #72
    eddiefromcali
    Eddie
    100% Stock
    Just looked at the log and I dont think it recorded IDC. Pull was E48 blend @ 5700 WOT, trims were 25 (0 correction), AFR @ 10.3:1, IAT 98*. This just tells me I didn't run out of injector but not sure on the %.
    I'll take a look at the JB4 menu and see if IDC is an available PID.
    SnowToy likes this.
  13. May 2, 2025 at 10:29 AM
    #73
    eddiefromcali
    Eddie
    100% Stock
    I am, all of this was just a simulation on our VR machine in Mexico :)
  14. May 2, 2025 at 10:32 AM
    #74
    Daedalus
    Daedalus New Member
    That is rather on the rich side. Depending on IATs and how the truck's combustion cycle likes it, you could lean that out a smidge and gain a fair amount of power.
    This was an E30 tune prior to me selling the GTI. Obviously not apples to apples, but you get the idea.
  15. May 2, 2025 at 10:33 AM
    #75
    Daedalus
    Daedalus New Member
  16. May 2, 2025 at 10:37 AM
    #76
    eddiefromcali
    Eddie
    100% Stock
    Thats how fat toyota commands it. Toyota doing Toyota things. Thats for E10 tuning though, not E50...since the ecu doesnt know its on a blend
    Daedalus[QUOTED] likes this.
  17. May 2, 2025 at 10:52 AM
    #77
    eddiefromcali
    Eddie
    100% Stock
    Which reminds me, I need to get a wideband on this thing so I can take a look at lambda, not AFR...so used to dealing with lambda from my previous car. My 1.4 cruze was fully built (I know, i know...a "built" cruze) and thats how I got into this boost world.
  18. May 2, 2025 at 10:59 AM
    #78
    Daedalus
    Daedalus New Member
    Friend of mine stuffed an EFR turbo on his sonic...wasnt anything to sneeze at.
  19. May 2, 2025 at 11:07 AM
    #79
    eddiefromcali
    Eddie
    100% Stock
    theyre capable little motors, just no development behind them so far. Theres one guy on yt with a turbo 1.8....he got good numbers from it at 525 or so whp. I was on a stock frame turbo, so that was my limitation...but did get 230ish hp from that lil thing. Any slightly tuned fiesta would leave me in the dust.
  20. May 2, 2025 at 11:09 AM
    #80
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Did ya hear what other members said? Empty your bowel in the morning! Empty bowel has no gases.
  21. May 2, 2025 at 4:42 PM
    #81
    ARB1977
    ARB1977 [OP] New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Why don’t you create your own thread and not high jack others.
  22. May 2, 2025 at 5:10 PM
    #82
    JaxJacket
    JaxJacket New Member
    21 DC
    Ignore the naysayers. Get a scanner of some sort and see for yourself. On the 5.7 the ecu definitely optimizes spark timing at idle and low loads when using premium. I suspect it optimizes valve timing and fuel injection as well. Have to believe the newer ones aren't at least as smart and would affect how they run.
  23. May 2, 2025 at 5:20 PM
    #83
    ARB1977
    Anthony
    DFW
    Which gauge would you monitor to see the adjustments? I’m almost to a half of a tank on 93 and my tank average is up 1 mpg on my daily commute.
  24. May 3, 2025 at 5:28 AM
    #84
    JaxJacket
    21 DC
    Scangauge will show ignition timing and knock learning values. There are others if you search the site.
    ARB1977[OP] likes this.
  25. May 3, 2025 at 6:12 AM
    #85
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Ha ha ha
  26. May 3, 2025 at 9:14 AM
    #86
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Way too many Oil Threads in this Forum already. Hundreds of posts for you to read. Use the search feature and get reading.
    BlackNBlu and ARB1977[OP] like this.
  27. May 3, 2025 at 9:16 PM
    #87
    MikroT
    MikroT New Member
    Dom
    2024 Tundra Hybrid
    Charts/logs or it didn't happen
    DRP likes this.
  28. May 4, 2025 at 8:36 AM
    #88
    BlackNBlu
    Rich
    MN
    Believe what you want.
    No different than any "modern" vehicle built in the last 30 years with an ECM and knock sensors.
    It's how they keep a turbocharged engine alive running on cat piss 87.
  29. May 4, 2025 at 9:49 AM
    #89
    pursuit2550
    Why dont you use the search feature like PNW tundra Mike said. Way too many threads on oil, fuel, lifts etc. But if you didn't already figure it out, it's called sarcasm.
    I guess some people dont understand sarcasm. :rofl:
  30. May 4, 2025 at 11:24 AM
    #90
    raylo
    Frederick, MD
    Probably the same people who believe premium gas makes it idle better. ;-)
    pursuit2550[QUOTED] likes this.
