916tundra Audio System Build
Discussion in '2.5 Gen Tundras (2014-2021)' started by 916tundra, Mar 28, 2019.
  1. Apr 16, 2019 at 11:28 AM
    #241
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Agreed, I never would have picked it up if you didn't first.
    916tundra[QUOTED][OP] likes this.
  2. Apr 16, 2019 at 11:42 AM
    #242
    916tundra
    916tundra [OP] New Member
    Ken
    2017 Tundra Crewmax
    @jmevis where did you put your ground? Any ground loop noise for you?
  3. Apr 16, 2019 at 11:50 AM
    #243
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    You know what I didn't run the ground. I probably should. Especially since Im planning on going the amp route too.
  4. Apr 16, 2019 at 11:56 AM
    #244
    916tundra
    Ken
    2017 Tundra Crewmax
    Surprised your HU works without running the ground cable, now I’m wondering if it’s even needed.
  5. Apr 16, 2019 at 12:15 PM
    #245
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    hi_rawb, Watt maker and 916tundra[OP] like this.
  6. Apr 16, 2019 at 6:36 PM
    #246
    amazingswami
    amazingswami New Member
    Just got this system in the mail today. I'm wiring in the multi-cam switcher and the truck accessory module as well. Quick question: did you use the mic that came with the unit, or does the stock mic plug in via a harness connection in the back?
  7. Apr 16, 2019 at 6:47 PM
    #247
    Beastmode1794
    I had it installed they used the new Mic but let me know if you figure out how to use the factory one also can you post a link for the cam switcher I want one I also got the accessory controller havent installed it yet tho also dont forget to get a hdmi/USB outlet installed and get a meastro module works great
  8. Apr 17, 2019 at 6:09 AM
    #248
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra Installed my front facing camera yesterday. I went with a different one from Amazon from what I linked previously. It looks stock which I like. Also here is a pic of the app (bottom left) in fact all 3 apps in that bottom row showed up on their own after I messed with the Car Factory Settings on the HU.
  9. Apr 17, 2019 at 6:49 AM
    #249
    minter66
    minter66 2007 TSS CrewMax
    How is the front cam powered?
  10. Apr 17, 2019 at 6:50 AM
    #250
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    But the HU. There is a yellow "F-Cam Power" wire.
  11. Apr 17, 2019 at 7:05 AM
    #251
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Watt maker likes this.
  12. Apr 17, 2019 at 7:13 AM
    #252
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis Looking good! I have not installed a front camera yet because I am thinking of adding a side view camera for parallel parking too but I won’t do so until I figure out if I want tow mirror or not. If you have multiple cameras, you will need switches.
    jmevis likes this.
  13. Apr 17, 2019 at 7:14 AM
    #253
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis can you post a link to the new front camera you got?
    jmevis likes this.
  14. Apr 17, 2019 at 7:15 AM
    #254
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
  15. Apr 17, 2019 at 8:10 AM
    #255
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  16. Apr 17, 2019 at 1:00 PM
    #256
    916tundra
    Ken
    2017 Tundra Crewmax
    jmevis[QUOTED] likes this.
  17. Apr 20, 2019 at 11:09 AM
    #257
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra The cable works! I went ahead and installed the carplay adapter behind the HU too. Can you tell me what app you use to get carplay to work?
    I tested this and the phone will charge plugged in to the OEM usb port. I haven't tried to play anything through it yet. Im just assuming its working since it now charges the phone. And the adapter lights up.
  18. Apr 20, 2019 at 1:11 PM
    #258
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Man that HU looks SHWEEET! i have 18CM SPORT for about a year now and its about that time to swap out my HU. How are you liking it so far?
  19. Apr 20, 2019 at 2:11 PM
    #259
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis The app is AutoPlay, one of the preloaded apps on the HU
    jmevis likes this.
  20. Apr 20, 2019 at 2:15 PM
    #260
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis the way you have it plugged in is into the factory cable that is not connected to the HU so that’s why it doesn’t work. There is power but no data transfer. You have to use the HU usb.
  21. Apr 21, 2019 at 12:13 AM
    #261
    Beastmode1794
    Love it its perfect video looks good to tons of options and great xm interface
  22. Apr 21, 2019 at 5:39 AM
    #262
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    Did you do the install yourself?
  23. Apr 21, 2019 at 6:52 AM
    #263
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Yeah. But I think the adapter I bought is supposed to use the factory usb cable. After I installed the adapter the factory usb connection will now charge the phone. I’ll try this later today.
  24. Apr 21, 2019 at 5:52 PM
    #264
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra mine didn’t come with the app loaded... can you snap a pic of it?
  25. Apr 21, 2019 at 5:57 PM
    #265
    Beastmode1794
    No I had it installed there was alittle to much going on for me
  26. Apr 21, 2019 at 6:57 PM
    #266
    How do you adjust the gain on the stock amp? I’ve already replaced all speakers, and a 10” JL sub. It sounds great, but I’m happy to fine tune the amp
  27. Apr 21, 2019 at 7:19 PM
    #267
    Beastmode1794
    Theres a amp gain seting on my head unit that you can set and it realy made the difference
  28. Apr 21, 2019 at 7:34 PM
    #268
    916tundra
    Ken
    2017 Tundra Crewmax
  29. Apr 22, 2019 at 6:37 AM
    #269
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra
    Ok I went in to settings and enabled car play but I still don't have the app. Nor is there one in the play store that is called that. I did figure out how to keep the volume up when in reverse though. Settings > Car > Extra Settings > Reversing Volume.
    Also for what ever reason when one of my rear doors opened the display would show the opposite door open, and I found that setting under factory features so that's now fixed.
    I did see something about customer version 1 or 2? Under the factory settings?
    Another question... Have you tried playing netflix, hulu, Amazon prime video on your HU? Mine loads these and then says there is an issue and wont play videos. But youtube works fine. I have even tried to just go to hulu through chrome and it takes me all the way to where is should play and then spits out an error.
  30. Apr 22, 2019 at 6:40 AM
    #270
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Unfortunately the only way is to change out the head unit. The stock unit has no ability to control the amp.
