916tundra Audio System Build
Discussion in '2.5 Gen Tundras (2014-2021)' started by 916tundra, Mar 28, 2019.
  1. Apr 12, 2019 at 10:10 AM
    #211
    motocrossman99
    motocrossman99 New Member
    Josh
    2019 Barcelona Tundra SR5
    i got the same charger. i didnt cut all the way through. Just the underside plastic ribbing and it was tough to get it to link up w/ my phone case. i then tore off the plastic casing from the charger and mounted that directly underneath and now i can charge with a fairly thick phone case. i dont care that the charger doesnt have the case as i never see it under the arm rest.
  2. Apr 12, 2019 at 12:40 PM
    #212
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra does the HU have the ability to send power to a front camera? Im guessing that is on one of the harnesses?
  3. Apr 12, 2019 at 1:49 PM
    #213
    minter66
    minter66 2007 TSS CrewMax
    @916tundra
    Do you have your HU / Is there any way to get the HU to launch Carplay automatically when you plug in your phone?
    My pioneer immediately pulls up carplay on the screen as soon as I connect my iPhone, just curious. I will be utilizing it in a similar manner as you, CarPlay only pretty much.
  4. Apr 13, 2019 at 9:32 AM
    #214
    916tundra
    916tundra [OP] New Member
    Ken
    2017 Tundra Crewmax
    Yes, it can send power to front cam. There is a wire for it next to rca input
  5. Apr 13, 2019 at 9:33 AM
    #215
    916tundra
    Ken
    2017 Tundra Crewmax
    Yes, it automatically launch CarPlay when you plug in your phone, if carplay was used last
    minter66[QUOTED] likes this.
  6. Apr 13, 2019 at 1:24 PM
    #216
    916tundra
    Ken
    2017 Tundra Crewmax
    While the 2-10” Focal subs have plenty of bass, I think this might be my next project. Should I add 2 more or even 3?
    Pudge and Jrharvey02 like this.
  7. Apr 13, 2019 at 5:03 PM
    #217
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    Just got the halo9 installed finaly i gota say the JBL speakers arent half bad once you turn up the gain on the stock amp and set the eq right im still replacing them all in a few weeks but im sure if i wanted to i could get away with just a new sub and amp
  8. Apr 13, 2019 at 5:20 PM
    #218
    916tundra
    Ken
    2017 Tundra Crewmax
    That’s a nice HU but man it’s expensive. What’s the resolution?
  9. Apr 13, 2019 at 7:50 PM
    #219
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Hahaha things are really snowballing. That's a good setup. Looks like $$$$$$$$$
    916tundra[QUOTED][OP] likes this.
  10. Apr 14, 2019 at 9:58 AM
    #220
    Beastmode1794
    Idk what the resolution is but your right its not gona look like your 4k tv but its fine for what i do with it im still playing with the settings but im happy so far also i got mine used for 450 so it wasent that bad
  11. Apr 15, 2019 at 6:13 PM
    #221
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra Mine came in today and I got it all installed. A few questions.
    1.)How did you get the steering wheel controls to work? I cant find anything about setting the vehicle type for it to learn.
    2.) I don't know which cable is the GPS antenna cable? There are 3 potential cables? Mine didn't come with a GPS SD card installed. Note: Waze and Google Maps works fine, but the built in GPS app doesn't.
    3.) My truck still beeps with lock/unlock
    4.) The Blutooth OBD 2 adapter works just fine with a phone and the OBD 2 connected.
    5.) Where did you install your USB cables & carplay adapter?
    6.) There are 2x gold coaxial type connectors on the back of the unit, one is clearly GPS idk what the other is? Satellite Radio?
    tinman10101 and Watt maker like this.
  12. Apr 15, 2019 at 6:46 PM
    #222
    minter66
    Man that looks awesome
  13. Apr 15, 2019 at 8:10 PM
    #223
    916tundra
    Ken
    2017 Tundra Crewmax
    1) steering wheel control. Go to settings, car factory settings, password is 126, canbus choose number 8.
    2) use this adapter with the small coaxial adapter and hook up to the gps cable with the foam.
  14. Apr 15, 2019 at 8:10 PM
    #224
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis the cables that you are holding in your hand will not be used
  15. Apr 15, 2019 at 8:13 PM
    #225
    916tundra
    Ken
    2017 Tundra Crewmax
    I ran the 2 usb cables to the glove box
  16. Apr 15, 2019 at 8:16 PM
    #226
    916tundra
    Ken
    2017 Tundra Crewmax
    The other usb for CarPlay adapter is on the opposite side. Since you have a center console, you have to be creative with routing it.
    This is where I ran mine.
    Watt maker likes this.
  17. Apr 15, 2019 at 8:57 PM
    #227
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis the other coaxial adapter in the back of the head unit i think is for WiFi. There should be a short antenna included in the package.
  18. Apr 16, 2019 at 6:17 AM
    #228
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra THANK YOU!
    The steering wheel controls work now! But it no longer beeps when locking. It'll be this afternoon before I can pull it apart to add the wifi antenna.
    My unit didn't have an SD card installed in the GPS slot did you take yours out of your etune unit and add it? I did and that doesn't seem to be the answer because I GPS kicks an error even though I have the right cable plugged in.
    How long does yours take to boot mine seems to take quite a long time (20-30 seconds.)
    I found out you can view the rear camera at any time. Under the "Car Factory Settings" Select yes on front camera. This will download an app that you can switch between a front and rear view at any time.
    It was real nice driving to work this morning with Waze :bananadance:
    For those of you thinking about doing it, it definitely has more gain (volume) you have to go in the settings and boost the amplifier but it for sure gets louder.
  19. Apr 16, 2019 at 6:48 AM
    #229
    minter66
    Pretty responsive? No jitter/stutter? It's why I got away from Android phones, they weren't as smooth or polished.
  20. Apr 16, 2019 at 6:51 AM
    #230
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    No issues yet, the rear camera isn't as clear, I'm assuming the reverse camera isn't a high megapixel count. I haven't installed my front face camera which is supposed to be 720p resolution.
    The screen it self is very responsive. No issues opening apps, I still need to figure out how to use it. Just like a new phone.
    916tundra[OP] likes this.
  21. Apr 16, 2019 at 8:33 AM
    #231
    916tundra
    Ken
    2017 Tundra Crewmax
    1) I am assuming that locking/unlocking no longer beeps because we changed the canbus. Hopefully we can figure this out because I do miss it. I have to look at the light to confirm the truck is lock.
    2) My HU did come with a SD card but I’m not sure it’s for the GPS app. I don’t use that app anyway because I use carplay google map or apple map, much faster. You should contact Dasaita to send you a SD card if you really need it.
    3) cold boot is about 20-25sec. If you go into settings,car, extra settings, shutting delay. You can change the shutdown delay up to 1 hour. That means it will fastboot within the hour. I have mine at 30 mins because it does use some power from battery.
    4) my front camera setting is on. Which app did it download for you?
    5) the rear camera is blurry because the stock camera resolution is bad.
    6) I agree with you that the HU does have more gain and I would say the sound quality is better than stock HU.
    How do you like the HU so far?
  22. Apr 16, 2019 at 8:38 AM
    #232
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis go into the gps antenna or signal app on the HU to see if you have signal strength. If you don’t, your wiring/adapters are not connected correctly or might be something else
  23. Apr 16, 2019 at 8:41 AM
    #233
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    1.) There are some sub options under the canbus type maybe it could be one of those. I agree I miss the beep.
    2.) I have an SD card in the 2nd slot but not the GPS slot didn't know if it was needed or not.
    3.) Perfect I will change that setting
    4.) It's an app call "F-CAM" I believe. It automatically showed up as an app after the HU rebooted for changes made.
    Loving the HU so far. I wish I didn't have to select connect to my phones hot spot every time. But I wonder if I change the shutdown delay if it'll connect automatically.
  24. Apr 16, 2019 at 8:42 AM
    #234
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I do have signal strength, just didnt know if the stock GPS should work or not. Google Maps and Waze work great.
  25. Apr 16, 2019 at 8:50 AM
    #235
    916tundra
    Ken
    2017 Tundra Crewmax
    Stock GPS does work for me but it’s slow so I don’t even bother
  26. Apr 16, 2019 at 9:16 AM
    #236
    minter66
    Appreciate all the feedback you guys are putting into this thread. Making it easier for us who haven't bought one yet.
  27. Apr 16, 2019 at 11:06 AM
    #237
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I'm thinking about looking in to a USB 4g LTE hub or something so I dont have to connect to wifi every time.
  28. Apr 16, 2019 at 11:14 AM
    #238
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis I see that you have the red and white rca hooked up in one of your photos. What is it for? Are you using the included microphone? Or are those rca for the factory microphone?
  29. Apr 16, 2019 at 11:17 AM
    #239
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra The red and white were labeled Aux L & Aux R I'm assuming its the 3.5mm aux cable connection in the center console by my USB port. But I guess it could be the mic cable I was able to talk to text earlier while connected to Bluetooth and I didn't think that would work since I haven't run my mic cable yet.
  30. Apr 16, 2019 at 11:26 AM
    #240
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis I’m glad you also got the HU. It’s nice to have other people’s input and hopefully work out all the minor bugs/issues.
    jmevis likes this.
