916tundra Audio System Build
Discussion in '2.5 Gen Tundras (2014-2021)' started by 916tundra, Mar 28, 2019.
  1. Apr 9, 2019 at 7:20 AM
    #151
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You wouldn't do that on the head unit. You would have a gain/bass knob connected to your amp.
    jmevis[QUOTED] likes this.
  2. Apr 9, 2019 at 7:44 AM
    #152
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    If the headunit has sub-preouts you would be able to control it wouldnt you? I could've sworn I did this with the headunit I had in my Camaro.
  3. Apr 9, 2019 at 8:22 AM
    #153
    Danimal86
    Daniel
    Sacramento, CA
    You can do it this way, but you are better off with using a remote bass knob connected to your amp
    jmevis likes this.
  4. Apr 9, 2019 at 8:33 AM
    #154
    916tundra
    916tundra [OP] New Member
    Ken
    2017 Tundra Crewmax
    The HU does have a sub out and you can go into the settings to turn sub on/off and control the gain; however it’s better to use the bass knob for your sub amp.
  5. Apr 9, 2019 at 8:34 AM
    #155
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Cool, I am going to start my upgrade but ill be starting with the HU.
  6. Apr 9, 2019 at 8:41 AM
    #156
    916tundra
    Ken
    2017 Tundra Crewmax
    Three things I’ve noticed so far with this HU.
    1) this is obvious with any aftermarket HU, you will lose turn by turn navigation at the steering wheel dash/screen
    2) locking and unlocking the truck no longer makes beeping noise. I have to do some research into why it’s no longer beeping. Anyone heard of this issue?
    3) music is paused when in reverse, this could be a good thing so you won’t be distracted.
    jmevis likes this.
  7. Apr 9, 2019 at 9:20 AM
    #157
    lriar
    lriar New Member
    Lov
    Bakersfield, CA
    2017 Tundra
    Awesome set up! Looking to do something similar to mine in the near future. Thanks for sharing
    916tundra[OP] likes this.
  8. Apr 9, 2019 at 9:26 AM
    #158
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    #2 is interesting... Can you pull up the reverse cam with out being in reverse?
  9. Apr 9, 2019 at 9:49 AM
    #159
    916tundra
    Ken
    2017 Tundra Crewmax
    Will look into it after work.
  10. Apr 9, 2019 at 9:53 AM
    #160
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Thanks I'd like to install a front camera too and use it when ever I want. Most of these after market HU have the ability too view cameras.
    muledawg likes this.
  11. Apr 9, 2019 at 10:06 AM
    #161
    G10dra
    G10dra Not a New Member
    Ken -
    For # 3, I believe there is a setting that you can change. I remember reading that on the "android head unit" thread. try going into the settings and make sure the parking sound is on
    I think you should read the android unit thread here, it's full of knowledge. Even though your radio is different then theirs, the operating system is almost the same.
  12. Apr 9, 2019 at 10:13 AM
    #162
    916tundra
    Ken
    2017 Tundra Crewmax
    Thanks, I will look into it but having the music pause might be a good thing for me. As for #2, not sure why locking and unlocking no longer beeps. Debating if that’s a good thing or not. Read that some people was looking to disable the beeping feature on this forum.
  13. Apr 9, 2019 at 10:35 AM
    #163
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Rica25 and 916tundra[OP] like this.
  14. Apr 9, 2019 at 1:43 PM
    #164
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @916tundra You inspired me. I placed an order for everything on your HU spreadsheet and I added a Front View Camera to the Amazon shopping cart. Some of the parts from Allied Express show 25 days but you got yours very quickly. :fingerscrossed:
    Pudge and 916tundra[OP] like this.
  15. Apr 9, 2019 at 1:48 PM
    #165
    916tundra
    Ken
    2017 Tundra Crewmax
    Which front camera did you get? Can you provide a link? I will install one too.
    Installing the HU to the Metra trim kit was a bit tricky. I will post some photos and tips to make installation easier.
  16. Apr 9, 2019 at 1:54 PM
    #166
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    https://www.amazon.com/gp/product/B078ZZSKQ2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    I have TRD PRO so the grill is different. But I think I can mount this under the TOYOTA box frameIMG_5572.jpg
  17. Apr 9, 2019 at 2:57 PM
    #167
    916tundra
    Ken
    2017 Tundra Crewmax
    Here are some tips on how to install the HU to the Metra mounting kit.
    1) place only the face plate on top of the HU first.
    2) put on the screen and align with HU and install the two plastic pins. Move the face plate around to make room to insert the pins.
    3) Install the two thumb screws. You have to cut the plastic (I used wire snip) off the thumb screws in order for them to fit the face plate. The third photo shows the thumb screw before it was cut and I found out they both didn’t fit. Cut only the outside edge.
    4) Install side mounting plates per provided instruction.
    @jmevis
    jmevis and Rica25 like this.
  18. Apr 9, 2019 at 5:04 PM
    #168
    916tundra
    Ken
    2017 Tundra Crewmax
    There is an app called AVIN and I believe this is your front camera app. I don’t have a front camera so nothing is showing. As for the reverse camera, I’m not sure. I don’t think the Tesla HU has the reverse camera app since it needs the reverse signal. I have to do some research.
    @jmevis
    jmevis likes this.
  19. Apr 10, 2019 at 6:54 AM
    #169
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I guess we could get the FRAC harness to get the anytime view of the front and rear camera.
  20. Apr 10, 2019 at 7:35 AM
    #170
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Not sure if this pertains, but years ago, to be able to watch dvds on my old double din pioneer dvd HU in 4Runner, I installed a relay on the green ground wire from HU which tricked it into thinking truck was in park and allowed me to play movies while in drive...
  21. Apr 10, 2019 at 7:38 AM
    #171
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    That's interesting. From what I have read "quickly" the tesla HU guys can toggle through the cameras with out a FRAC? There is conflicting info though. One of my pet peeves with the stock HU is that you cant connect a new phone to bluetooth with out stopping. Im hoping this new one will let you.
  22. Apr 10, 2019 at 7:38 AM
    #172
    motocrossman99
    motocrossman99 New Member
    Josh
    2019 Barcelona Tundra SR5
    does that head unit act like a full android tablet with playstore access and everything or only the 8 or so apps that show? are there any USB slots or expansion slots?
  23. Apr 10, 2019 at 7:42 AM
    #173
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Looks like it comes with 2 or 3 usb hook ups. @916tundra will have to answer the apps question. I'm fairly certain off the youtube review you can download apps.
  24. Apr 10, 2019 at 7:46 AM
    #174
    motocrossman99
    Josh
    nice i have done no research on this yet as i was certain i was going the tesla unit route but i got it yesterday and the digitizer has an issue and the resolution and color is awful. so i'm looking for an alternative.
    jmevis likes this.
  25. Apr 10, 2019 at 7:50 AM
    #175
    Jrharvey02
    Look into it, it was a 20 min mod and costed like $6 for the relay. The relay had 4 pins I believe, I jumped two of them together and connected the ground to another pin and that was it. It was the rage to do in the early 2000’s, tons of DIY videos then, should still be on YouTube somewhere
  26. Apr 10, 2019 at 7:52 AM
    #176
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Very Cool. If it does "lock out" ill prob do this too.
  27. Apr 10, 2019 at 8:49 AM
    #177
    916tundra
    Ken
    2017 Tundra Crewmax
    There are 3 included USB adapters/slots. I use one for the CarPlay adapter, planning to use another usb slot for SSD hard drive, the third will be used for accessory (tpms). This is basically an android device/tablet, you can download any apps you like from play store.
    @jmevis
  28. Apr 10, 2019 at 8:54 AM
    #178
    916tundra
    Ken
    2017 Tundra Crewmax
    @jmevis I haven’t figured out how to keep the music playing while in reverse so even if we use a relay to have anytime front/rear camera showing, we would want the music to keep playing
  29. Apr 10, 2019 at 8:54 AM
    #179
    pablo89
    pablo89 New Member
    pablo
    Miami
    2018 tundra platnium
    Rollnlock amp steps fuel wheels nitto ridge led lights
    Hi gang, I'm new to the forum and I'm loving it so far. I fairly recently purchased my Tundra and have been using this site a lot. I work for a company called Autotech located in Miami, Florida and they are the largest JL audio dealer in Florida. If you guys are interested in anything JL audio I spoke to the owner and they can provide a 15% off on most equipment and maybe even a little more on other parts. They can ship it directly to you guys, let me know if any one is interested. Happy to have found this community looking forward to sharing what I can with you guys.
    just a reminder gang
  30. Apr 10, 2019 at 9:56 AM
    #180
    minter66
    minter66 2007 TSS CrewMax
    Thanks for directing me to your thread.
    Does the carplay adapter / headunit keep your iPhone charged? I saw one review stating it's USB 2.0 and can't charge one guys iPhone fast enough.
    I would be buying this to exclusively use CarPlay and have a giant screen for my reverse cam. So other than the carplay adapter, I don't need any other harnesses / adapters / GPS pucks / etc right?
    Thanks for letting me pick your brain.
    Is this what you bought?
    https://www.aliexpress.com/item/Das...or-2-din-Universal-with-Octa/32857645110.html
    and Carplay:
    https://www.aliexpress.com/store/pr...ml?spm=2114.10010108.1000023.1.17a71f5cUYzVvx
