831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Dec 23, 2021 at 5:12 PM
    #1111
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Very true. Only the leaf springs can compare, they got rebuilt/repainted at the same time.
    TG705, GodlessPro and joonbug like this.
  2. Jan 29, 2022 at 9:45 AM
    #1112
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Can you post some pics on where the bucket brace attaches? I’ll have to get this done sometime soon.
    thanks!
    reywcms, nb_nielsen and 831Tun[OP] like this.
  3. Jan 31, 2022 at 9:27 AM
    #1113
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sure thing, I'll be working on it, repairing it, today. Rough weekend out in Johnson Valley.
    joonbug, Cruzer and GodlessPro like this.
  4. Jan 31, 2022 at 10:51 AM
    #1114
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Here's the driver side. It's bolted through the shock hat.
  5. Jan 31, 2022 at 10:54 AM
    #1115
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    3 ton Arcan hybrid jack mod. A new Pro eagle base AND the center bolt (not listed on their website) are required. Then simply choose which extension you want.
    joonbug, alb1k, nb_nielsen and 6 others like this.
  6. Mar 24, 2022 at 10:15 AM
    #1116
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I believe that removing the front most crossmember that ties the frame ends together might not've been a great idea. There are some aftermarket bumpers that require this as well. But, given the way I drive off road I felt it necessary to add reinforcement back to the frame ends. The issue was the power steering cooler was right where I wanted to add a tube. So I created a different cooler using Howe Racing finned tubes and some 8-AN fittings.
    joonbug, TXTundra2722, TG705 and 6 others like this.
  7. Mar 24, 2022 at 10:34 AM
    #1117
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Do you think the coolers get enough air movement when the skid plate is in place?
    831Tun[QUOTED][OP] likes this.
  8. Mar 24, 2022 at 4:50 PM
    #1118
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Good question. I don't have any empirical data one way or another. I believe since I never had any problems with the smaller OEM cooler which is mounted just a couple inches lower this should be fine. I increased the size of the cooler and volume of fluid. The OEM style has more solid tubing which dissipates some heat and I now have more braided hose which is an insulator. I've seen similar dual pass setups but I chose 2 single pass tubes instead. I considered stacked plate too but that would interfere with airflow to the radiator. I also added five 1.5" holes to the skid. I can still cut some larger holes in the skid if necessary but then I'd need some mesh or perforated steel to cover them.
    joonbug, jc153, TG705 and 4 others like this.
  9. May 11, 2022 at 9:53 PM
    #1119
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, hubris and driver error strike again. Made a little mistake in Baja and destroyed the steering rack. On the bright side, I finally got an opportunity to have the Deaver 420 leaf pack de-arched a little and it's much closer to the proper 60/40 shock ratio that I'm after. I can't say enough good stuff about my buddie's shop in Orange, Baja Rex Motorsports. Funny, he's a couple doors away from where SSbuilt used to be.broken rack.jpg Leafs adjusted.jpg
    pvn.beluga, GodlessPro, TG705 and 8 others like this.
  10. May 11, 2022 at 9:56 PM
    #1120
    Sunnier
    Sunny
    San Diego, CA
    I guess I don’t “like” this. Were doing something fun, and did anyone get a picture? I’m glad you’re not hurt; always better the truck.
    Oh! Did you have a great time?!!
  11. May 11, 2022 at 9:59 PM
    #1121
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Sunny. No evidence of the incident will surface. :p Got some pics of some other cool stuff though. It was a good time just too many trucks
  12. May 12, 2022 at 7:32 AM
    #1122
    Cruzer
    Cruz
    Sunnyvale, CA
    Damn!!!! Straight cracked that mofo!!! You must’ve sent it for sure.
  13. May 12, 2022 at 7:37 AM
    #1123
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I saw this on the instagram, pretty wild to crack the steering like that. Joseph is an awesome guy. I'm looking forward to our bk2baja in Jan.
    831Tun[OP] and eccracer104 like this.
  14. May 12, 2022 at 7:53 AM
    #1124
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Joseph putting in lots of work in over at bajarex
    831Tun[QUOTED][OP] and reywcms like this.
  15. May 12, 2022 at 8:03 AM
    #1125
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    BK2 is a great group of folks, you won't be disappointed. Dustin and Kelly wouldn't let me stay at a hotel, insisted I stay with them 'til the next morning when I could go to Joseph's shop. His right hand, Tim is a really good guy too.
  16. May 12, 2022 at 8:10 AM
    #1126
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea my old mans been on a couple not sure If you've been on the same runs. Here's his rig
    eccracer104 likes this.
  17. May 12, 2022 at 8:25 AM
    #1127
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice rig, haven't seen it before. I've only done 2 runs with BK2 though.
    Your 37s will come in handy. There was 1 Yota with 35s and he got high centered in the silt beds.....twice. LOL When he jumped out for the recovery he was mid calf deep in silt....:rofl:
    We drove about 15 miles, high speed and stopped at one of the 7 sisters. Wheels still looked like this:
  18. May 12, 2022 at 8:28 AM
    #1128
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    haha!
  19. May 12, 2022 at 9:15 PM
    #1129
    TheBeast The Beach
    any issues with silt and running 17" wheels on a tundra since calipers are closer to the rim now ?
    831Tun[OP] likes this.
  20. May 12, 2022 at 10:43 PM
    #1130
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No problem with the 17s, the silt is super fine, clumps easily but can't keep a shape
    TheBeast[QUOTED] likes this.
  21. Jun 1, 2022 at 9:43 AM
    #1131
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Didn't Joon do something similar in Anza Borrego a few years back? I remember it took all night to get it fixed, but not bad for a trail side repair!! (thanks to Oside)
  22. Jun 1, 2022 at 4:33 PM
    #1132
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nope, that was me that time too. #needstodrivebetter
    eccracer104 and Sunnier like this.
  23. Jun 1, 2022 at 7:24 PM
    #1133
    DividedSky
    Jeff
    Yeah, that was quite a memorable weekend. I believe that was the time where, before bed, I dug a hole in the ground and filled it with hot coals, rocks and a cast-iron full of beef and dried chiles and then buried it. In the morning we had some steaming hot Barbacoa that just fell apart when you put a fork into it!
    I've been back to that great camp site from the 2nd night quite a few times since that trip as well. Not many people make it back that far down the wash, so it has nice privacy.
    I'll try to keep an eye on Tundras.com more so I can join up with everyone for another adventure. Making some big changes to my rig in the form of a SuperPacific topper.
  24. Jun 1, 2022 at 7:44 PM
    #1134
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I remember the Barbacoa well, think I was the last one to eat.
  25. Jun 1, 2022 at 7:47 PM
    #1135
    DividedSky
    Jeff
    I'm sure you were a little preoccupied... :thumbsup:
    Just glad it got fixed.
  26. Jul 19, 2022 at 4:01 PM
    #1136
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So this showed up today.
  27. Jul 19, 2022 at 4:04 PM
    #1137
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Now that is cool
  28. Jul 19, 2022 at 4:05 PM
    #1138
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Billy!
    joonbug and Trdwillie14[QUOTED] like this.
  29. Jul 19, 2022 at 4:19 PM
    #1139
    Vizsla
    Vizsla 2 = 2.5
    Nice Warren! Where is that from? The blue stripe looks off center.:D
  30. Jul 19, 2022 at 4:25 PM
    #1140
    SpeshulED
    please tell!
    ive been wanting the same but with a red stripe
    joonbug and 831Tun[OP] like this.
