831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Sep 20, 2019 at 2:31 PM
    #871
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Oh no... I was gonna tell you guys but I just forgot.
  2. Oct 12, 2019 at 5:50 PM
    #872
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Swapped bushing UCAs for heimed in an effort to improve alignment #s. Specifically camber, I couldn't get better than 1.2* of negative camber. It didn't drive well and looked terrible. Also swapped in 700 lb 3" dia. coils in place of the 600 lb 3.75" that TC specs for their LT kit.
    The UCA is straight forward, especially since this is the 5th different set of arms I've installed on this truck. The heims are a PITA cause you've gotta pull the long bolt all the way out to make adjustments. I got super super lucky eyeballing/guesstimating and only had to pull the driver side once after the initial install.
    The coil overs were more of a challenge since this is only the 2nd set of shocks I've rebuilt. To get the new smaller coil nut on the body the top of the shock has to come off. So, thanks to the write up by @ColoradoTJ, I was able to heat the top with a torch (using propane not Mapp or other hot fuel) and spin it off. Once the top is off you're kinda in rebuild mode 'cause the shock has to be bled. The only way I know to bleed the shock is to remove the shaft and reinstall while pushing the air out from the IFP in the resi. I had intended to reuse the shock oil but it was roughly the color of coffee, burnt? I dunno but I tossed it and refilled the shocks with Fox red. I'd also like to thank @osidepunker and @papasmurf, both of whom answer their phones and are super helpful and willing to share info. Even if some of my questions are sometimes naive.
  3. Oct 12, 2019 at 6:25 PM
    #873
    LML 3500HD
    If your shock oil looked like coffee, definitely time for oil/seal swap.
    Glad the shock thread helped out.
    You should see how loaded down Clowns Inc (Facebook page) is when traveling out of state. We bring the equivalent of the woman’s kitchen sink in tools.
  4. Oct 12, 2019 at 6:58 PM
    #874
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    That decal is fire
  5. Oct 12, 2019 at 7:00 PM
    #875
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Matt, got yours right here. They're too big to stick in an envelope so next time I see ya.
    dcsleeper408 and joonbug like this.
  6. Oct 12, 2019 at 7:14 PM
    #876
    Rubberdown
    Looking nice sir! Did you get it officially aligned? Still waiting on my MCM arms... getting ansy.
    joonbug and 831Tun[OP] like this.
  7. Oct 12, 2019 at 7:14 PM
    #877
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Where and how can I get a sticker to replace my u/c like that lol
    dcsleeper408, joonbug and 831Tun[OP] like this.
  8. Oct 12, 2019 at 7:23 PM
    #878
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I did take it in for alignment. I was close and I can do it but alignments are new to me and very time consuming. I've got a lot of little projects to complete this week so I can wheel next weekend. Half my ARB twin isn't working and I've got a broken leaf. Alignment #s are only sightly different (increased caster by +/- .5* both sides) from what you'll want.
    Matt's not the fastest at getting stuff out but the stuff he gets out is the best.
    Vizsla and joonbug like this.
  9. Oct 12, 2019 at 7:25 PM
    #879
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    TC LT UCAs don't have a sticker and the ones I had made are too big for standard UCAs. But, you can go online and make just about any sticker you want.
    dcsleeper408, joonbug and sr5shark like this.
  10. Oct 12, 2019 at 7:30 PM
    #880
    Trdwillie14
    Billy
    2014 trd off road
    Mine have a sticker
    What can I say I wanna be like warren
    Bo-Hunter, GodlessPro, Vizsla and 2 others like this.
  11. Oct 12, 2019 at 8:01 PM
    #881
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The LT ones have the sticker on the LCA and nothing on the UCA
  12. Oct 12, 2019 at 8:07 PM
    #882
    Trdwillie14
    Billy
    2014 trd off road
    But u have to understand I’m not on that :spending::spending::spending::spending:
    Warren level of L/T
    831Tun[OP] and joonbug like this.
  13. Oct 12, 2019 at 8:08 PM
    #883
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Give it 1-2 years. Or 3 trips with us. :laugh:
  14. Oct 12, 2019 at 8:28 PM
    #884
    Trdwillie14
    Billy
    2014 trd off road
    That’s the thing I purposely don’t go due to knowing I can’t afford the madness that is the bastards lol
    Pinay and joonbug like this.
  15. Oct 12, 2019 at 8:45 PM
    #885
    Vizsla
    Vizsla ☠️☠️☠️
    :anonymous:
  16. Nov 3, 2019 at 1:02 PM
    #886
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Playing with carbon fiber on the bedsides and fenders kinda sparked my imagination. So, the latest project is a 3rd brake light utilizing 2 Baja Design S2 amber driving combos and a red KC cyclone for a brake light. This iteration has deleted the bed lights and I'm not sure how I feel about that. I have strips under the bed rails so I'll have to see how it works out. Worst case scenario I can retro fit something like Ozium bolt head led lights. Here it is almost completed just needs a few more coats of clear.3rd brake light, almost finished.jpg
  17. Nov 3, 2019 at 1:48 PM
    #887
    Trdwillie14
    Billy
    2014 trd off road
    Dude so cool I really like that
    831Tun[OP] likes this.
  18. Nov 3, 2019 at 2:41 PM
    #888
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Billy. It came out ok for a prototype.
    dcsleeper408 and GodlessPro like this.
  19. Nov 3, 2019 at 2:46 PM
    #889
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  20. Nov 3, 2019 at 3:13 PM
    #890
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Warren you are a man of many talents, that looks awesome
  21. Nov 3, 2019 at 4:24 PM
    #891
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Greg. Hopefully I can have another one ready for ya by the time you make it out here.
    GodlessPro and joonbug like this.
  22. Nov 4, 2019 at 4:30 AM
    #892
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Dope AF
  23. Nov 5, 2019 at 11:57 AM
    #893
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I have a dumb question...
    How do you make the shape? is it like other molding or casting arts where you somehow create a negative of the shape you want, and then apply the carbon fiber to that mold? If so, what medium do you use for the mold and how do you create the shape?
    I understand things like surfboard shaping, and metal casting, but having a hard time figuring out how you arrive at the shape you made. Super cool though!
  24. Nov 5, 2019 at 2:07 PM
    #894
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's rocket science Kevin, you wouldn't understand. Hahaha. Just kidding brotha.
    Many ways to do it, but in this case, I used Divinycell and polyester adhesive to build directly off of an OEM 3rd brake light. So, just the horizontal plane was projected out far enough to create a vertical mounting
    This one actually will become the mold if I decide to make more of them.
    Always happy to chat with you Kevin so lemme know if failed to fully answer your question.
    I'll have to show you sometime, the hollow wood surfboard I made from Mirrasou wine tank redwood.
  25. Nov 6, 2019 at 5:06 AM
    #895
    osidepunker
    Alex
    2013 Tundra DC 4x4
    #carbonscience
  26. Nov 6, 2019 at 6:25 AM
    #896
    KevinK
    Tundras to Sedona
    I think I mostly understood that. Maybe. So you shaped the divinycell to the outer shape of the stock piece, but only horizontally so that you ended up with a flat vertical plane to cut into for mounting the lights flush. Does the divinycell compress or conform to the shape when you apply pressure to it, or do you have to carve and shape it by hand to match the shape of the original?
    I’d definitely love to see a surfboard made from wine tank wood!
  27. Nov 6, 2019 at 8:05 AM
    #897
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    #cabronscience
    zcarpenter92, Sunnier, KevinK and 6 others like this.
  28. Nov 6, 2019 at 8:09 AM
    #898
    osidepunker
    Alex
    2013 Tundra DC 4x4
    HAHAHA awesome
    dcsleeper408[QUOTED] likes this.
  29. Nov 6, 2019 at 8:54 AM
    #899
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Divinycell is a super light, dense, closed cell foam so it's not intended to compress. I'm using .5" sheet material. I adhered the vertical plane to the brake light housing first, then fitted filler pieces around the perimeter so there's a void behind the vertical plane. Once the filler pieces were roughly fitted I just sanded the horizontal plane flat and contoured the sides.
    dcsleeper408 likes this.
  30. Nov 15, 2019 at 11:20 AM
    #900
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Finally got the LT rear done as SSbuilt. I was cool to see they already had a Bastrds sticker on the post of their lift. Steve was really cool to work with. The tailgate is 5'8" from the ground when the wheels finally lift off the ground. Looking forward to a test run next week. I still need to set up limit straps and have the brand new FOA bumps replaced as they pissed themselves as soon as N2 was introduced. AF1QipPk2pUpO6vlM2Wijpfih3qRnQbibcMIdoRQ_e8938ff8ca8db863b9519fa781b834d9be09be32.jpg
