831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Aug 17, 2019 at 9:05 PM
    #841
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ummmm. Just wanna make sure you know Big Bear is not next weekend. o_O
  2. Aug 18, 2019 at 1:03 PM
    #842
    TheBeast The Beach
    did you keep running into the same issue or you built it for other people as well ?
    will it pass CA SMOG ?
    thanks !
    831Tun[QUOTED][OP] likes this.
  3. Aug 18, 2019 at 2:22 PM
    #843
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Ummm, yeah, I knew that. LOL
    I built a bunch for other people. I haven't had any issues with any of them but mine and it's an easy fix, just add a clamp. I don't know about any smog issues, the AIP is only for cold starting as far as I know. It's pretty well covered up by the wheel well liners for those that still have 'em.
  4. Aug 18, 2019 at 2:50 PM
    #844
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Technically it could fail visual but it would have to be a really picky smog tech to even look for it. As long as there isnt a check engine light on, no engine control unit faults stored, and the OBDII monitors are set you should have no issues with smog.
    GodlessPro, TheBeast, joonbug and 2 others like this.
  5. Aug 26, 2019 at 10:06 PM
    #845
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Installing the fiberglass bedside is a major PITA only because they don't fit worth sh##. But did some interesting, fun and different stuff today making the struts/supports for the bedsides. While waiting for epoxy to cure I riveted in I a piece of PVC conduit for wiring lights in the rear.bedside conduit.jpg
    But, first thing this morning I cut a bunch of pieces of 4"x4" chopped strand glass, a bunch of 17-08 (biaxial weave w/.75 oz. mat) glass, and a couple pieces of carbon fiber.
    First I wet out the 10 mil plastic then add alternating pieces of 17-08 and chopped strand, wetting out each piece. Then, after the glass is all wetted out and stacked, I topped it with a piece of carbon fiber and finally peel ply. With 10 mil plastic on top and bottom of the stack I clamped the whole thing together between 2x4s. This is what it looked like after unclamping and a little trimming.
    These are the pads for the strut/supports, then I just needed the actual support material. So, I took 2 pieces of Divinycell foam and laminated them together with a piece of biaxial carbon fiber tape between them.
    After curing and a little shaping I epoxied a carbon fiber sleeve over the foam.....
    I wet this out with epoxy and quickly wrapped it with plastic wrap borrowed from the kitchen. End result is the supports glassed to the bedside and to the mounting pads mounted on the truck.
  6. Aug 27, 2019 at 2:14 AM
    #846
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Nice work Warren
    Vizsla, joonbug and 831Tun[OP] like this.
  7. Sep 6, 2019 at 1:59 PM
    #847
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    That's fuckin Cool Warren - very creative. Any pics of how the truck looks overall now?
  8. Sep 6, 2019 at 3:13 PM
    #848
    TXTundra2722
    2015 Black Tundra
    Are you running LT in the front or do you just have spacers/ rims with offset?
    831Tun[OP] likes this.
  9. Sep 6, 2019 at 3:13 PM
    #849
    TXTundra2722
    2015 Black Tundra
  10. Sep 6, 2019 at 3:26 PM
    #850
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    John Bull Gatekeeper
    Vizsla, r4z0r51o, JDL17CM4x4 and 9 others like this.
  11. Sep 6, 2019 at 4:50 PM
    #851
    TheBeast The Beach
    Beast !
  12. Sep 6, 2019 at 8:22 PM
    #852
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yes it's LT in front. It's the TC kit with King 2.5 c/o and bypass.
    Hey Kev, Thanks. Here's a little more info on the bedsides:
    First I cut the angle I wanted. Then created a "return lip" behind the cut to stiffen the edge. Then filled the molded area so the panel and bumper will look like they're intended to go together instead of looking like someone hacked off the panel. I used bondo to adhere Divinycell foam and after shaping/ fairing put a layer of 4 oz. glass over it make it sincere (boat building term).bed side cut.jpg
    Took this panel on and off at least 30 times fitting it. The glass doesn't fit worth sh--.bedside.jpg
    Immediately after removing the peel ply. Peel ply is applied to the surface while the epoxy is still wet. A squeegee is used to smooth and cause any excess resin to rise to the peel ply. With a lot of luck (I only had a little) the peel ply will take on a uniform wet look w/o being too wet, too wet and the epoxy will actually push the carbon fiber away the surface that you're trying to bond to. If you don't have enough epoxy for a uniform wet look you'll end with a bumpy VERY hard to repair surface. Touchy stuff to be sure and I'm just learning about it. After removing the peel ply and assuming you had uniform wetness, it's time to sand it w/o sanding into the carbon, then apply an automotive clear coat. I didn't have time before the trip and still haven't done it. Lucky too, I'll get to sand out the gouges from the "car wash" we drove thru.after peel ply removal.jpg You can see the peel ply still stuck to the fuel door. And, one more pic w/o the peel ply on the fuel door.:rolleyes:JV jump.jpg
    Vizsla, r4z0r51o, JDL17CM4x4 and 13 others like this.
  13. Sep 6, 2019 at 8:50 PM
    #853
    TheBeast The Beach
    still have your little trailer ?
  14. Sep 6, 2019 at 8:59 PM
    #854
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, it's great for family camping. We just used it last month up at Lake Edison.
  15. Sep 7, 2019 at 10:50 AM
    #855
    KevinK
    Tundras to Sedona
    That’s awesome. I love that you have the skills and spirit to lay that stuff up yourself. And I like hearing about the process behind it instead of just ‘I put some glass and carbon on it.’
    Looks pretty sick in action too. ;)
    Can’t wait to wheel together again! I’m living vicariously through you guys for the time being.
  16. Sep 19, 2019 at 1:23 PM
    #856
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Andy, @Challenger1 for the console badge.
    I never thought of this and probably wouldn't have gotten one if I had thought of it. But, I'm stoked, I really like it. Thanks brothaBastrds CC badge.jpg .
  17. Sep 19, 2019 at 1:52 PM
    #857
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Shit, I have to find mine. I'm gonna have a center console to stick it on soon.
  18. Sep 19, 2019 at 2:30 PM
    #858
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    I'm Glad you like it Warren!
    I "MIGHT" have an extra one for you sir! lmk if you cant find it.
  19. Sep 19, 2019 at 8:13 PM
    #859
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Do I need 2.5 in the rear and to not go under 95 on flat dirt to get one of these ?
    Sunnier and 831Tun[OP] like this.
  20. Sep 19, 2019 at 8:23 PM
    #860
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Under 95 is totally acceptable. 2.5 is a suggested minimum....LOL
    Honestly, we've had all kinds of setups out there. Stuff like full size spare, sliders, your own tools etc. are usually mandatory though.
  21. Sep 19, 2019 at 8:58 PM
    #861
    Vizsla
    Vizsla 2 = 2.5
    Sorry @Challenger1 , meant to thank you also, so awesome! Next time I see my truck I’ll grab a pic..:thumbsup:
    joonbug, GodlessPro and Challenger1 like this.
  22. Sep 19, 2019 at 9:01 PM
    #862
    Challenger1
    Andy
    You already thanked me when. I handed it to ya. :)
    Just glad you guys liked them. And didn't just toss it lol.
    Me and Warren went and installed his right away! Haha
    joonbug, GodlessPro and 831Tun[OP] like this.
  23. Sep 19, 2019 at 9:03 PM
    #863
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, I thought it was lame at first. That lasted 1.3 seconds then I was like, "hell yeah!":p
  24. Sep 20, 2019 at 9:27 AM
    #864
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I usually just ask that guys have tools and the ability to change a tire... youd be surprised who cant meet that criteria
  25. Sep 20, 2019 at 9:29 AM
    #865
    KevinK
    Tundras to Sedona
    :help:
    831Tun[OP], joonbug and Challenger1 like this.
  26. Sep 20, 2019 at 10:42 AM
    #866
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Andy originally had the stripes diagonally. I made him change it. :laugh:
  27. Sep 20, 2019 at 10:45 AM
    #867
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    That looks really good. Bay Area dealers should offer this as an option. :D
  28. Sep 20, 2019 at 11:03 AM
    #868
    TheBeast The Beach
    TRD BASTRDs edition.
  29. Sep 20, 2019 at 11:15 AM
    #869
    Challenger1
    Andy
    haha. I was running ideas by Joon. For approval lol.
    831Tun[OP] and joonbug[QUOTED] like this.
  30. Sep 20, 2019 at 1:36 PM
    #870
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well he's good at keeping a secret cause I had no idea.
