831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. May 9, 2019 at 9:39 AM
    #811
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Yes all part of the float arm assembly
  2. May 9, 2019 at 2:35 PM
    #812
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    That's what she said:rofl:
  3. May 9, 2019 at 2:58 PM
    #813
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well, ya know what one saggy boob said to the other saggy boob.
    If we don't get some support soon, people are gonna think we're nuts.:D
    saybng, joonbug, dcsleeper408 and 7 others like this.
  4. May 9, 2019 at 3:21 PM
    #814
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Lookin like a fly ass truck now with them 7's on it!
    831Tun[OP] likes this.
  5. May 9, 2019 at 4:26 PM
    #815
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Are those the Demello hybrids? I got rid of mine because they would flex and hit the body. They have 30” to the rear that is unsupported :censored:
    831Tun[QUOTED][OP] likes this.
  6. May 9, 2019 at 4:51 PM
    #816
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No, not Demello. They're All Pro and not DOM.....Doh!!
    Thanks Tommy!
    I don't know how there could be room for 9s...... unless I stack a bracket lift on the LT. :eek: :anonymous:
  7. May 9, 2019 at 4:58 PM
    #817
    TheBeast The Beach
    well next time he will know what to do :)
  8. May 9, 2019 at 7:59 PM
    #818
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I should give credit and thanks to @TRON for the info he gave me with regards to the stuck valve. Steffan had recently experienced the same issue and basically told me how to fix it by breaking it.:D I think his tank was replaced whereas mine is now "repaired". Also, @Vizsla, I mentioned the problem to him initially and he knew exactly what the problem was. WTF? How do you know this s4it? Thanks Bud
    Sunnier, joonbug, Trdwillie14 and 2 others like this.
  9. Jun 24, 2019 at 9:45 AM
    #819
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Did your fueling problem start right away? Seems like mine got progressively worse. I'm debating whether I should drop the tank and mess with this valve since thats free or just spend the money on an evap canister since that easy haha
  10. Jun 24, 2019 at 10:03 AM
    #820
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You know how sometimes you just get a bad pump nozzle at the gas station? Well, I remember experiencing that a few times and once shortly before T2S. So, I'm not too sure if there was a slow onset, no conclusive evidence. I didn't have issues on the way to Sedona but did before I left. What a PITA getting home. LOL
    Depending on how many times you've topped off, say 20 or more, I'd guess your evap can. And one of your recent adventures (;)) may have allowed some fuel to drain into the evap can. The stuck inertia valve isn't that common as far as I know, I only know of 1 other 3rd gen that had the issue. But as soon as I mentioned it @Vizsla correctly diagnosed the problem so I'd wanna know what he says. I'm only guessing.
    How bad is your issue? It was obvious with mine. I'd fill maybe 2 cups of gas and the pump would click off, 2 cups off, rinse and repeat for 30 min. to fill the tank.
    Sunnier likes this.
  11. Jun 24, 2019 at 10:10 AM
    #821
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah thats how mine is. I kept thinking I was getting bad nozzles. But then the last 2 or 3 fill ups the clicking became more common. On the last fill up it would click every second or 3 at the most. I ended up holding the vapor hose back and pouring the gas in. Made it faster because it didn't click off all the time, but I still had to fill at half speed.
  12. Jun 24, 2019 at 10:13 AM
    #822
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I couldn't even fill at half speed, pulling the vap hose didn't help. Seriously, 2 cups at a time.
  13. Jun 24, 2019 at 10:15 AM
    #823
    osidepunker
    Alex
    2013 Tundra DC 4x4
    so you pull back the vapor hose and pour the gas in, and it drains super slow? Maybe I do have a bad evap canister...
  14. Jun 24, 2019 at 10:44 AM
    #824
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep. You could actually pull the vapor boot back and see it slowly draining into the tank as if it was blocked, 'cause it was. When I dropped the tank and saw the inertia valve it was fully closed. There's still a possibility yours is only partially closed. But that seems unlikely 'cause when I barely touched it with a screw driver it snapped open with force. Then I decided to permanently disable it. Dropping the tank to inspect is easy and free but time consuming. It would eliminate that possibility w/o needlessly spending money. With those used evaps you don't know what the prior owner did in terms of topping off, though I doubt it's common practice.
    My guess in your case would be evap.
  15. Jun 24, 2019 at 10:46 AM
    #825
    osidepunker
    Alex
    2013 Tundra DC 4x4
    dammit. ok, I'll try evap. I wish there was a way to bypass it haha
  16. Jun 24, 2019 at 4:27 PM
    #826
    TheBeast The Beach
    you mean if you top off after it clicks, it will lead to that issue ?
    831Tun[QUOTED][OP] and joonbug like this.
  17. Jun 24, 2019 at 4:35 PM
    #827
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes. Never top off.
    Sunnier likes this.
  18. Jun 24, 2019 at 5:28 PM
    #828
    TheBeast The Beach
    good to know. thanks.
    joonbug likes this.
  19. Jun 24, 2019 at 5:35 PM
    #829
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yes, won't happen right away but it will lead to "fouling" the charcoal canister.
    joonbug likes this.
  20. Jun 24, 2019 at 5:46 PM
    #830
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I’ve way overfilled a few times dumping my cans after a trip. Hopefully I don’t see this issue anytime soon :facepalm:
    joonbug and 831Tun[OP] like this.
  21. Jun 24, 2019 at 6:07 PM
    #831
    TheBeast The Beach
    seeing how our trucks are gas guzzlers, I'm sure we all tend to squeeze that extra drop in :)
  22. Jun 25, 2019 at 8:19 AM
    #832
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Every trip I top off. I can fit 3 more gallons in haha
    jc153, 831Tun[OP] and joonbug like this.
  23. Jun 25, 2019 at 8:31 AM
    #833
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ha!! 2.8 gallons into the tank... .2 gallons straight into the charcoal canister!! :laugh:
    TheBeast and 831Tun[OP] like this.
  24. Jun 25, 2019 at 8:33 AM
    #834
    osidepunker
    Alex
    2013 Tundra DC 4x4
    haha maybe! But I got 6 years 70k miles sooo...
    831Tun[OP] and joonbug[QUOTED] like this.
  25. Jun 25, 2019 at 8:36 AM
    #835
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Actually if it ends up being an easy fix, it probably was worth getting 3 more gallons in every trip. When I know gas will be an issue, I usually squeeze in like an extra 2 dollars and then I chicken out. :D
    831Tun[OP] and Sunnier like this.
  26. Jun 25, 2019 at 8:38 AM
    #836
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well I guess step one is for me to fork over a couple hundo and see if the evap canister is actually bad. If that corrects the issue then I'll probably stop topping off. I can carry 4 cans if fuel if I need to so topping off is kind of unnecessary for me
  27. Jun 25, 2019 at 9:41 AM
    #837
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you fix it for a couple hundo, I'm going to start topping off.
  28. Jun 25, 2019 at 9:48 AM
    #838
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I found used, 2nd gen evap units on ebay for around $150. Not sure what the 3rd gen would cost.
    joonbug[QUOTED] likes this.
  29. Jun 25, 2019 at 10:14 AM
    #839
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yeah bunch of used ones for $150 to $200. Some of them look almost new, but that could be because they spent time to clean them up LOL
    I won't know for a few weeks. Need to get The Truck off the blocks first
  30. Aug 17, 2019 at 9:01 PM
    #840
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Ok, I've gotten a few requests for this parts list and @Sunnier suggested I just put it in my build thread. So here's the list of parts that I've used to build a few AIP kits.
    3. 10 AN 90* elbows.
    1. 120* 10 AN elbow
    6'. 10AN stainless/nylon hose
    2. 10 AN to 3/4" hose adapters
    I use 3/4" Pex tubing, expand it and put it over the barbed end. This is the connection to the factory hose. Seems goofy but works really well.
    2. 10 AN to 1/2" hose adapters to connect your filters.
    2. 13mm Crankcase filters of your choice.[​IMG]
    Since going LT I have hit the outer most elbow twice and dislodged it from the OE hose. I don't have fender liners presently and there is a factory location where I can strap/clamp the hose to keep it out of the way. I'll try to provide pics when complete and will be "field" testing in Big Bear next weekend.
    TheBeast, Sunnier, GodlessPro and 2 others like this.
