831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Nov 22, 2018 at 2:43 PM
    #631
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    ??? You mean the C/Os from Matt come with a flutter stack? I haven't rebuilt any shocks yet so my knowledge is lacking.
  2. Nov 22, 2018 at 3:04 PM
    #632
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Pretty sure yes. I bought basically direct from ADS, Brian told me the coilovers use a flutter. I would assume the sets from MCM are valved the same, i wouldn't imagine them to be different.
    831Tun[QUOTED][OP] likes this.
  3. Jan 9, 2019 at 9:05 AM
    #633
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    A few upgrades coming soon. 5.29 gears and an ARB locker will hopefully be installed next week.
    Then, around the end of Jan, it'll be time to begin installing the LT kit for the front hopefully with some help from @dcsleeper408.
    And, I still need to install the new Icom, dual band radio that I bought back in Nov.IMG_20190109_082235867.jpg
  4. Jan 9, 2019 at 9:12 AM
    #634
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Wow Christmas was good for you this year!
    831Tun[OP] and TheBeast like this.
  5. Jan 9, 2019 at 9:15 AM
    #635
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    So excited for you Warren !!!! Your truck is already bad ass, now going to the next level.
    831Tun[OP] and papasmurf like this.
  6. Jan 9, 2019 at 9:27 AM
    #636
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You already got your 5.29's????
  7. Jan 9, 2019 at 9:34 AM
    #637
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    :transformer:
    Badass Warren.
  8. Jan 9, 2019 at 9:35 AM
    #638
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, Boss 4x4 had 4 "intorductory" sets of Nitro's so I picked up a set. I made an appointment for next Wed. to have gears and locker installed. When ebay had one of their 10% off deals I got a locker 'cause that was the only way I could find a deal on one.
  9. Jan 9, 2019 at 9:36 AM
    #639
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Let's hope our buddy, Mark, can keep me from effing up the install.:D
    Sunnier, BlueBottle, joonbug and 2 others like this.
  10. Jan 9, 2019 at 10:39 AM
    #640
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @831Tun Warren!!! dude... so stoked for you to join the LT club.. its life changing..
    and you are correct, best setup for the front end is a flutter stack in the coilover with 700lb spring then run your bypass shock as well to deal with the bigger stuff on compression and rebound
    im not 100% on the flutter in ADS MT coilover, if brian says yes and Matt @M C M says yes then they do. I switched the standard 12/15 stack to a flutter stack and 700lb coils on my LT front coilovers and its so much nicer of a ride both on and off road. Id almost say thats how they should be built however, i know after talking with TC about the king spec shocks, they built them to suit more mild offroading guys, not crazy people like SGU and bastards LOL so we have to step up to a heavier rate spring and different valving. Anyway let me know if you have any questions on the LT front install. Its pretty straight forward, but im only a phone call away if you have any trouble.
    Cant wait to see you out on the trail with a shit eating grin on your face!!
  11. Jan 9, 2019 at 12:41 PM
    #641
    n2deep
    n2deep Pavement Princess
    King builds all there stuff that way unless you specify - Running a flutter stack in my coils and a 20 stack in my bypasses.
    831Tun[OP] likes this.
  12. Jan 9, 2019 at 4:12 PM
    #642
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Bruce. The SGU crew sure makes LT look like the way to go (sorry Kevin LOL) I'm sure I'll have some questions. The axles are the only part of the build that I'm unfamiliar with. I'd like to replace my rack bushings while I'm in there too so I don't pull an Alex.
    I'll have to check with Roy about the valving, guessing it's standard.
    Hopefully the Bastrds can run with SGU again this year. That was an awesome trip with great people.
    Sunnier, joonbug and GodlessPro like this.
  13. Jan 9, 2019 at 4:17 PM
    #643
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for that info. I'll ask Roy what he ordered and see if a re-valve before I install is necessary. It might be cool to run dual rate springs too.
  14. Jan 9, 2019 at 4:55 PM
    #644
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    That’s a great setup, congrats. I hope to see it in action out on the trail when we get SGU and Bastards together again. Bruce installed it on Roy’s truck so I’m sure he has all the valving details and such.
  15. Jan 9, 2019 at 5:34 PM
    #645
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Ha.... I didn't know Bruce installed it for Roy. Bruce and his wrenches really get around. Really looking forward to us all hitting the dirt.
  16. Jan 9, 2019 at 5:49 PM
    #646
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yeah I’m like the neighborhood bike... everyone gets a ride lol!!
    But yeah I did the install his coil overs were standard spec Kings. I don’t think he had them revalved.. let me check on that... but as far as doing the CV’s there are some tricks and tips to it... it’s not the easiest thing to talk through. Might be better to find a shop who can swap the axles for you. Give me a call this weekend and I can try and explain it to you.. plus you need to order some parts from Toyota these clips you have to replace when you do the job.. can not use originals.
    As far as dual rate.... I would highly advise against that..the coils are already short and your trying to jam two springs and an additional collar in a small space I don’t even think it’s possible or worth it... proper flutter with 700lb spring is amazing... I felt the original spring and valve setup was too soft... even w bypasses... but you might like the fee. W stepping up to LT it’s trial and error. I’d say run it as is.. tune it drive it and see what you think... then if you don’t like it pull it out and have it revalved.
    As far as the rack goes yeah do it while you are in there! You have to do a full alignment after install of LT anyway... so may as well. Plus there is a bit more room to work w the axles pulled out and no suspension on. I’d say strip it down then do the rack bushings then install LT
    jc153, joonbug, Sunnier and 2 others like this.
  17. Jan 9, 2019 at 6:25 PM
    #647
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Considering how much your "bike" gets ridden, I'll take that advise. No duals and run 'em like they are for now. The clips and a couple boot kits should arrive this week. Now to order those rack bushings.
    GodlessPro, jc153, joonbug and 2 others like this.
  18. Jan 9, 2019 at 6:32 PM
    #648
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Ok good deal so you know about those parts then that’s good... the hard part is separating the cv races and keeping all the parts in order and knowing how they go on.. the race cage is kinda weird like one of those puzzles where it only goes on and off one way. And you have to make sure it’s oriented correctly. Again not impossible just a slime greasy messy job that’s detail oriented.
  19. Jan 22, 2019 at 8:49 AM
    #649
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Have you gotten the gears installed yet? How are you liking them so far?
    Bo-Hunter and 831Tun[OP] like this.
  20. Jan 22, 2019 at 9:11 AM
    #650
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yes, gears and a rear locker were installed last week. The ratio is really low even with 35s, seems pretty "snappy." I kept waiting for it to shift on the highway, then realized it was already in 6th. So, it's holding gears on the highway much better and shifting seems smoother. I can feel that it's much easier on the tranny. I've only got 70 mi. on them so far and 50 of that was the drive home so not a lot to report yet. I'm gonna be installing long travel in the front very soon so don't plan to get the required 500 mi. break-in completed for a while.
  21. Jan 22, 2019 at 9:15 AM
    #651
    TexasTundra27
    Mark
    What rpms are you at while driving 70 with the 35s?
  22. Jan 22, 2019 at 9:20 AM
    #652
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Roughly 2,200. I used to see about 1,800 but it would downshift on the slightest of grades. I think with 37s it oughta be perfect.
  23. Jan 22, 2019 at 9:30 AM
    #653
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :benchpress:
  24. Jan 23, 2019 at 4:39 PM
    #654
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What are you doing with ur old set up once u install LT? Going to sale?
  25. Jan 23, 2019 at 8:53 PM
    #655
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    End of January is nigh... when is that kit going on???
    GodlessPro, joonbug and 831Tun[OP] like this.
  26. Jan 23, 2019 at 8:59 PM
    #656
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, probably sell the coilovers and UCA's.
  27. Jan 23, 2019 at 9:00 PM
    #657
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The last of the parts, shock hoops, should be here Friday. Think I'll start the following Friday, weather permitting.:fingerscrossed:
  28. Jan 23, 2019 at 9:29 PM
    #658
    fisherman951
    Tony
    2017 crewmax 4x4
    If you don’t mind letting me know when your ready and a price maybe we can work something out? Thanks.
  29. Jan 23, 2019 at 9:35 PM
    #659
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Will do Tony.:thumbsup:
  30. Jan 23, 2019 at 10:19 PM
    #660
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Giggity
