831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Jul 29, 2018 at 3:28 PM
    #421
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, but that's 'cause you're on a sanctioned maternity leave... ;) Not 'cause they decided to go the day AFTER you came home from there.:notsure: I mean really,,,,,,,,,,,, my feet aren't that dirty.
    joonbug and dcsleeper408 like this.
  2. Jul 29, 2018 at 3:30 PM
    #422
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sorry you couldn't make it Matt. We'll have to go back and spend several days, there's lots to explore and play around with. You could spend more than a day on Bald Mtn alone.
  3. Jul 31, 2018 at 5:41 PM
    #423
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I received a new tranny skid plate from Desert Eagle. This is also an anti theft deterrent for you Catalytic converters, cheap, functional insurance. Originally I saw a post by @joonbug about this and recently @Vizsla posted a pic of one he just mated up to RCI engine skids. I was really hesitant to do business with someone who's advertising almost exclusively on Face Book. But, as it turns out, he's a super nice guy and the transaction went very smoothly. Skid mark on pavers courtesy of the Fed Ex delivery guy.:facepalm:
  4. Jul 31, 2018 at 6:01 PM
    #424
    TheBeast The Beach
    please post your thoughts after install. I like the design. Thanks
    GodlessPro, 831Tun[OP] and Sunnier like this.
  5. Jul 31, 2018 at 6:12 PM
    #425
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Looks like it is going to give some good coverage.
    831Tun[QUOTED][OP] likes this.
  6. Jul 31, 2018 at 7:53 PM
    #426
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    it looks like a pair of shorts lol
    TheBeast, GodlessPro, Vizsla and 3 others like this.
  7. Jul 31, 2018 at 9:45 PM
    #427
    Vizsla
    Vizsla 2 = 2.5
    I like mine, little bit of work adapting to the engine skid. Also junked the hardware for grade 8 bolts and thick washers.
    jtwags, GodlessPro, joonbug and 2 others like this.
  8. Jul 31, 2018 at 10:00 PM
    #428
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice install! I was thinking about whether I wanted to use all four bolts or reduce to 2 bolts where the DE and RCI mate. Now I know for sure, gotta keep up with the Jones's. Everything is temp fitted so I can scribe it, pull it out and cut/ drill it. Nice clean cutouts you made for the DE bolts.
    BTW, I think you're working too much. I can tell 'cause your truck is waaay too clean.:D
    dcsleeper408, GodlessPro and joonbug like this.
  9. Jul 31, 2018 at 10:02 PM
    #429
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    How thick is it compared to the RCIs? My RCIs are already bashed in.
    This is supposed to be flat. :(5B9198D4-7375-4870-A0EE-841BA4928413.jpg
  10. Jul 31, 2018 at 10:22 PM
    #430
    Marty McFly
    Morty McBoonJug
  11. Jul 31, 2018 at 10:24 PM
    #431
    Vizsla
    Vizsla 2 = 2.5
    Yes work too much. Old pic, truck has been on jack stands for a month... Just missed a 2nd gen regular cab with 19k miles, I hate working.
  12. Jul 31, 2018 at 10:29 PM
    #432
    TheBeast The Beach
    kinda be expected with all the hardcore wheelin you do :)..me I just cruise the malls for some MILFs
  13. Jul 31, 2018 at 10:39 PM
    #433
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Exactly the same, 10 ga steel. Mine aren't quite as badly bent but I'm having a heck of a time lining up holes to reinstall.:sawzall:
    joonbug[QUOTED] and dcsleeper408 like this.
  14. Jul 31, 2018 at 10:40 PM
    #434
    TheBeast The Beach
    imagine if you got the Aluminium instead.
    joonbug and 831Tun[OP] like this.
  15. Jul 31, 2018 at 10:42 PM
    #435
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Man,,,,, I wish you'd gotten that RC. I hope to hear the stories you mentioned about the latest work. Do I dare even ask why the truck's on blocks? I think you said you were modifying the suspension ........ after all?
    joonbug, dcsleeper408 and TheBeast like this.
  16. Jul 31, 2018 at 10:44 PM
    #436
    TheBeast The Beach
    @831Tun be like :spy:
  17. Sep 3, 2018 at 6:59 PM
    #437
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Like @boardude I just got rid of the ghetto pro and upgraded to the Switch Pros. I'm not much of a follower, nor much of a leader for that matter. But I definitely march to my own drum so this install is a little different than most I've seen.
    I don't use the brake controller so I wrapped it in foam and and secured it to a heating duct, out of the way behind the dash. I made a block-out plate from some re-purposed ABS plastic and mounted the switches to it and to the OEM dash part using the (slightly modified) SP supplied hardware.
    And installed.
  18. Sep 3, 2018 at 7:13 PM
    #438
    Sunnier
    Sunny
    San Diego, CA
    Looks good!
  19. Sep 3, 2018 at 7:19 PM
    #439
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I couldn't bring myself to mount the switch pro on the fuse box cover as I've often seen done. It's not yet completely cleaned up but this is where it is at present. I used some double sided carpet tape to temporarily hold it in place on the inner fender while I checked fitment. I left the tape in place after screwing it in place as a damper. I made a couple stand offs for the distribution block to create space for wires.IMG_20180903_190134125.jpg
    boardude, joonbug, Sunnier and 4 others like this.
  20. Sep 3, 2018 at 7:39 PM
    #440
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Nice warren! Does your flip phone have blue tooth?
    joonbug, Sunnier, BlueBottle and 2 others like this.
  21. Sep 3, 2018 at 7:44 PM
    #441
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :rofl: Blue smoke signals....
  22. Sep 3, 2018 at 8:47 PM
    #442
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Great install! Any worries about the positive wires being exposed on the block? Or does it get covered?
    Make sure you change the default password so people don't screw with your switch pro's
    Sunnier likes this.
  23. Sep 3, 2018 at 8:52 PM
    #443
    Sunnier
    Sunny
    San Diego, CA
    Wait, what?!! I'm not the only one that still carries a flip phone. Ah, Warren! :rolleyes:
  24. Sep 3, 2018 at 8:54 PM
    #444
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Nice control location Warren.
    831Tun[OP] and dcsleeper408 like this.
  25. Sep 3, 2018 at 9:59 PM
    #445
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, the exposed dist. block is a concern and I plan to make or have made a cover. I'm surprised that Blue Sea doesn't make a cover for this??? There's a small plastic shop nearby and I'll have a chat with them about what and how to create a cover.
    joonbug likes this.
  26. Sep 3, 2018 at 10:02 PM
    #446
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hey @BlueBottle , I could use a little advice with the "trigger" wires and programming. I'm guessing you've got it ALL figured out.
  27. Sep 3, 2018 at 10:08 PM
    #447
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I haven’t installed a sp yet. @dcsleeper408 has one tho.
  28. Sep 3, 2018 at 10:11 PM
    #448
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Dang Man,,,, I thought you had one. Oh boy talking to @dcsleeper408 is scary...... He's always asking, "So, whatcha wearing?" LOL
  29. Sep 3, 2018 at 10:32 PM
    #449
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I left my trigger wire disconnected. If you want to wire it to a reverse switch/high beam/parking light you would just connect accordingly. I kept all my lights/radio controlled off the switch pro..
    Programming through Bluetooth would be easiest.
  30. Sep 4, 2018 at 2:00 AM
    #450
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Ditto, really like the location. Now you have the wheels in my head spinning again and that is a dangerous thing.
    joonbug, 831Tun[OP] and dcsleeper408 like this.
