831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Jun 4, 2018 at 3:01 AM
    #361
    Sunnier
    Sunny
    San Diego, CA
    :spy:
  2. Jun 11, 2018 at 1:39 PM
    #362
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Warren, you were right about the spec'd width of your tires, 12.4.
    Were they still good on the drive home? If so, I'm going to order a set.
    dcsleeper408 likes this.
  3. Jun 11, 2018 at 1:39 PM
    #363
    GodlessPro
    Matthew
    NorCal
  4. Jun 11, 2018 at 5:35 PM
    #364
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Huh,,,, My tape measure was telling me that YOU were right.:notsure:
    I haven't seen any chunking from yesterday, OK maybe a little on the rims, but the tires held up well. There was just a wee bit of noise on the ride home. I noticed cause the stereo was off. I'm kinda surprised that they're as quiet as they are considering the tread.
  5. Jun 11, 2018 at 10:46 PM
    #365
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Some new bed bars arrived today.
  6. Jun 12, 2018 at 2:05 AM
    #366
    Sunnier
    Sunny
    San Diego, CA
    Which are those? (I keep finding sets of 2, but would prefer 3.)
    831Tun[QUOTED][OP] likes this.
  7. Jun 12, 2018 at 2:18 AM
    #367
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Warren correct me if I'm wrong but those look to be Relentless Fab and you can get them as a set of three as an option on their website.
    Sunnier[QUOTED] likes this.
  8. Jun 12, 2018 at 8:25 AM
    #368
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hey Sun, @Bo-Hunter is correct. They're Relentless bars and they have a date with rattle can.
  9. Jun 15, 2018 at 11:02 PM
    #369
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Picked up some new tire deflators today. I haven't had a chance to test them but, for the sake of expedience, I'll test 'em tomorrow using a wheel barrow tire to be sure the gauge is accurate.
  10. Jun 16, 2018 at 8:33 AM
    #370
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Those are super nice!! I had my eye on those ever since I got the Tundra.
  11. Jun 16, 2018 at 8:34 AM
    #371
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    :popcorn: for the review. I have the ARB deflator and it's hit or miss.
  12. Jun 18, 2018 at 10:18 AM
    #372
    Sunnier
    Sunny
    San Diego, CA
    Also interested in your review. These are pretty affordable compared to many of the best sellers on Amazon.
    boardude[QUOTED] likes this.
  13. Jun 18, 2018 at 11:32 AM
    #373
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    I bought a set a couple of months ago. They are off about 5 lbs. Set them for 22 lbs and ended up around 17 lbs. Next time I will start at 30 and see where it goes. They are handy and seem to be of good quality.
    831Tun[OP] likes this.
  14. Jun 18, 2018 at 12:28 PM
    #374
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Any chance the reading was off due to warm vs cold tires? Just asking 'cause a warm tire might read about 5 lbs higher than a cool tire.
    5.7TRDProm likes this.
  15. Jun 18, 2018 at 12:54 PM
    #375
    Broncobroke
    Charlie
    Piedmont, NC
    That is possible. I suffer from CRS so I can't tell you whether the tires were still hot or warm. But you are right that will make a difference. If I had to guess what my actions were, I had just gotten off the road from 2 hour hwy drive so they were pretty warm. I usually air down as soon as I get to the beach. I intend to play around with them some more to see if they can be dialed in any better. All that being said regardless if they were set for 22 lbs my tire gauge read 17lbs. Hot or cold you would think they would read the same??:der:
  16. Jun 18, 2018 at 8:46 PM
    #376
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    joonbug and Sunnier like this.
  17. Jun 19, 2018 at 4:15 AM
    #377
    Broncobroke
    Charlie
    Piedmont, NC
    Directions???:confused:. I better go back and look. What trailer are you working on? I don't know how I missed that. Your truck and build are one of my favorites. I will have to go back through your build thread.
    831Tun[OP] and Sunnier like this.
  18. Jun 21, 2018 at 4:31 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    My latest Franken fabs for the trailer, a double jerry can mount and a sliding solar panel mount beneath the RTT. There' a loop pin to keep it secure for traveling. You can just see the skate bearing used for sliding the panel on the "Z" track, 4 bearings per side.
    Here you can see the 2 pieces of aluminum angle (Home Defect) that I pop riveted together to create a "Z". Just 2 bolts per rail attach the Z to the bottom of the the RTT rails. I made custom, threaded, aluminum T-slot nuts
    Here's the custom Jerry can mount. This is made from the top of our recently replaced front loading washer. It was candy apple red. I taped it off and sprayed some textured, black, Krylon that matches the Scout trailer perfectly. The mount has 2 pop rivets into the side of the trailer, 2 into the fender and 2 in the corners where I cut and folded to create the back of the mount. I used auto door edge moulding to trim out/ cover up the sharp edges. Total cost of the mount is under $10. The rattle can of textured black being $8. I also put Bituthane tape between the mount and trailer wherever they contacted each other.
  19. Jun 21, 2018 at 5:32 PM
    #379
    TheBeast The Beach
    not seeing the pictures :spy:
  20. Jun 21, 2018 at 6:39 PM
    #380
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    ditto...
    I'll have to give this deflating device a try. Been using the ARB deflator and so far I've been getting desired psi settings, if not then 1psi off at max.
  21. Jun 21, 2018 at 7:09 PM
    #381
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks man. I found a deal I couldn't, actually the wife couldn't pass up on a Smittybilt Scout trailer that was pretty well built. Everything worked great........ so I tore the electrical out :D I didn't like the way the wires were run or the space dedicated for it.
    BTW if your readings on the Brooks deflators were only off a few pounds then you probably adjusted them correctly, to the body and then tighten the nut which then hides your selected #. I kept adjusting to the top of the nut and couldn't figure out why, when set at 18lbs I was completely deflating the tire.:anonymous:
    joonbug likes this.
  22. Jun 21, 2018 at 7:48 PM
    #382
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Looking good Warren. Taking the trailer on the next overnight trip?
  23. Jun 21, 2018 at 8:18 PM
    #383
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    ARB is what everyone else is compared to. So, it's gotta be a good deflator. I worry about possibly losing the valve, if it can go wrong I'm likely to find a way to make it happen.
    Thanks Dan. We'll see, kinda depends on what the trails are like. I can always move the RTT to the bed rack.;)
  24. Jul 8, 2018 at 11:39 PM
    #384
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, made it back to the driveway after some interesting wheeling in Tahoe. We, @joonbug, @GiantsFanDan and @t4RPEE went up to Buck Lake and Ellis Peak. A little damage was incurred by all.:eek::D There was a broken axle which was repaired on the trail, a couple dents here and there, 1 new tire destroyed, some reshaped bumpers, new tattoos on everyone's skids, wheels and sliders and of course, the requisite pinstripes.IMG_20180708_202349472.jpg
    I pulled the RTT off the trailer and installed it on the truck for this trip, man was it nice. I also enjoyed the heck out of wheeling in Friday night around 3:30 am, trying to find 3 trucks in a place I've never been to. Believe it or not a couple times I actually got out and checked the ground for their tire tracks.....LOL
    At one point I was so frickin tired my mind was playing tricks on me, I came out of the trees and it looked like Joon had driven into a swampy area and got stuck. IMG_20180707_160543813.jpg
  25. Jul 9, 2018 at 12:53 AM
    #385
    Sunnier
    Sunny
    San Diego, CA
    Man! I love these $40,000 bet adventures you guys do!! #vicariously
  26. Jul 9, 2018 at 2:44 AM
    #386
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Sounds like a great weekend. So are you happy with the bed bar set up ?
  27. Jul 9, 2018 at 7:39 AM
    #387
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Man! That RTT is the chit for simplicity. At 4 am I was in no condition to assemble even the simplest of tents. With the RTT I was literally asleep in about 5 min.
  28. Jul 9, 2018 at 7:45 AM
    #388
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I hope to find some time later today to work on the rear bumper. It took a huge hit and bent a mounting bracket.:ohsnap: It'll be really nice when I can open the tailgate again.:D On the bright side, the sliders took some good hits and the drivers rear door is clearing the sliders a little better than before the trip.:yes::rofl::rofl:
  29. Jul 9, 2018 at 8:27 AM
    #389
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    STOP. HAMMER TIME! :thumbsup:
  30. Jul 9, 2018 at 8:55 AM
    #390
    GodlessPro
    Matthew
    NorCal
    Did you see Presley's bumper? You weren't the only one to take a hit this weekend.
    joonbug and 831Tun[QUOTED][OP] like this.
