831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Jun 1, 2018 at 9:44 PM
    #331
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm getting a custom credit card design with ghost flames. LOL
  2. Jun 1, 2018 at 9:44 PM
    #332
    TheBeast The Beach
    I was gonna say...lmao
    831Tun[OP] and GiantsFanDan like this.
  3. Jun 1, 2018 at 9:46 PM
    #333
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Seriously... Icon arms are bullshit.
  4. Jun 1, 2018 at 9:46 PM
    #334
    TheBeast The Beach
    TC and MCM good to go.
    zcarpenter92, Tacotundra and Vizsla like this.
  5. Jun 1, 2018 at 9:49 PM
    #335
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I thought I'd posted the photos of the 2 different arms stacked on top of each other. I'll post the photo "evidence."
    Sunnier, Vizsla and TheBeast like this.
  6. Jun 1, 2018 at 9:50 PM
    #336
    Vizsla
    Vizsla 2 = 2.5
    This picture sums it up, they have been that way for 10ish years. 7FBAD6F5-6CC4-4BE8-BE41-60ED10FC284B.jpg
    Sunnier and 831Tun[QUOTED][OP] like this.
  7. Jun 1, 2018 at 9:55 PM
    #337
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Draw a straight line thru where the long bolt goes through the bushings and my eyeball tells me the ball/ delta joint is closer to the long bolt on the Icon than stock?
  8. Jun 1, 2018 at 9:56 PM
    #338
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Curious Curious.. I may have the shop try to match your alignment #'s once I get my truck put back together. I can't get the damn thing to stop pulling right; almost like it wants to be a backwards NASCAR racer
    Could be the angle of that pic, but the Icon arm does appear to be noticeably shorter
    Vizsla and 831Tun[QUOTED][OP] like this.
  9. Jun 1, 2018 at 9:58 PM
    #339
    Vizsla
    Vizsla 2 = 2.5
    Just a little bit...
    831Tun[QUOTED][OP] likes this.
  10. Jun 1, 2018 at 9:58 PM
    #340
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Any idea what your #s are?
  11. Jun 1, 2018 at 9:59 PM
    #341
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :rofl::rofl::rofl: Yeah, just enough to be effed!:D
  12. Jun 1, 2018 at 10:05 PM
    #342
    Help New Member
    Ryan
    Tucson, AZ
    L/R
    0.0/0.2 Camber
    5.0/4.9 Caster
    0.15/0.14 Toe
    I tried playing musical tires, still pulls
  13. Jun 1, 2018 at 10:17 PM
    #343
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    And it pulls right? Maybe @Vizsla will offer some advice? I think he's forgotten more than I know.
    I have .3 less caster on the L I would say your toe is just a little too much. Might be nothing but I think max total is supposed to be .24 so .12 ea. side.
    Another thought, but you probably already checked, is everything rotating freely on the right side, no binding brakes or wobbly wheel bearings?
    tbell18, TheBeast and Vizsla like this.
  14. Jun 1, 2018 at 10:39 PM
    #344
    Help New Member
    Ryan
    Tucson, AZ
    I haven't thoroughly gone over that side yet, but a quick once over didn't reveal any obvious reasons. Going to try a different shop for this alignment to see if they have the same issues and/or can find anything that could cause it. Last shop said they had a hell of a time getting those numbers, but couldn't tell me why they had difficulty. My guess is ineptitude :oops:
  15. Jun 1, 2018 at 10:52 PM
    #345
    Vizsla
    Vizsla 2 = 2.5
    The combo of camber split, and backwards caster split has to pull right. I repeat this a lot, not openly because everyone that read an alignment thread, race truck parts make noise, etc..
    L/R
    -.1/-.1 Camber, EVEN!
    4.5/5.0 caster, bit of a guess
    .07/.07 toe as low as can go
    If the rear end is out far enough, some tweaks might be needed, but your OCD would match mine at that point. Caster is a guess for me with your Camburg arms, it seems low for them which to me is better, so I suggested a higher caster split. My caster is the same, I can let go of my wheel and nothing but straight.
    Help[QUOTED] and 831Tun[OP] like this.
  16. Jun 1, 2018 at 11:06 PM
    #346
    Vizsla
    Vizsla 2 = 2.5
    Sorry didn’t read this first. They are trying to pull your caster down to spec, they usually only know green or red. Your arms want more caster, that’s mostly preference(I don’t get it), but will align better if you tell them to disregard caster other than the needed split.
    831Tun[OP] likes this.
  17. Jun 2, 2018 at 9:04 AM
    #347
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Here are some comparison photos of the Icon vs MCM UCAs. The ball joint cup on the Icon is close to 3/8" shorter (in closer to the truck) than the MCM. And, the MCM moves the joint farther aft which increases caster.IMG_20180529_110151748.jpg IMG_20180529_110057194.jpg
  18. Jun 2, 2018 at 9:43 AM
    #348
    TheBeast The Beach
    big difference. damn
    GodlessPro likes this.
  19. Jun 2, 2018 at 9:51 AM
    #349
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    You have seen the light!!!:rofl:
    TheBeast, 831Tun[OP] and GodlessPro like this.
  20. Jun 2, 2018 at 10:02 AM
    #350
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    This explains a lot lol
    Glad I went with mcm with with all the advice I got and research.
  21. Jun 2, 2018 at 6:57 PM
    #351
    Help New Member
    Ryan
    Tucson, AZ
    I'll give that a whirl. Thank you sir!
  22. Jun 2, 2018 at 7:20 PM
    #352
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    How are they on the wallet?
  23. Jun 2, 2018 at 8:21 PM
    #353
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    They weren't that bad. Discount Tire Direct, no tax free and fast shipping. They're 1,188 and they had a $75 rebate.
  24. Jun 2, 2018 at 8:23 PM
    #354
    Tacotundra
    Vegas
    2022 Tundra
    That's my wifey's suspension :)
  25. Jun 2, 2018 at 8:52 PM
    #355
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I remember seeing the post, it's for her 4r I think. That's partly what caused me to change the color of my UCAs. I waited a long time for those so I didn't wanna wait any longer for a custom color. ;)
    joonbug and Tacotundra[QUOTED] like this.
  26. Jun 2, 2018 at 8:54 PM
    #356
    Tacotundra
    Vegas
    2022 Tundra
    Yea she waited a while also. Yours look really good the way you painted them:thumbsup:
  27. Jun 2, 2018 at 9:05 PM
    #357
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I wanna see some pics of that 4R. I be it's BA.
  28. Jun 2, 2018 at 9:12 PM
    #358
    Tacotundra
    Vegas
    2022 Tundra
    It stayed really nice rides awesome. She really likes it. We haven't put the tires on yet other bills. She has her wheels waiting in the garage some icon rebound wheels. I will post some once her wheels and tires are on.
    joonbug, TheBeast and 831Tun[OP] like this.
  29. Jun 2, 2018 at 9:45 PM
    #359
    TheBeast The Beach
    wifey 4R deserves its own build thread
  30. Jun 3, 2018 at 4:58 AM
    #360
    Tacotundra
    Vegas
    2022 Tundra
    I will add one on the other builds thread once I get her tires and wheels on.
