Discussion in '2nd Gen Tundras (2007-2013)' started by nimbostratus, Sep 24, 2016.
  1. Sep 24, 2016 at 8:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I'm gonna guess, if they don't notice the rust, you might get somewhere in the $15-20k range. Depending on what you're buying and how nice your truck is. I've traded in 2 cars and both inspections lasted less than 10 minutes, both times. They seem to care more about bluebook value than actual condition of the car. And being in Alabama, I don't think they'll look too hard for rust.
  2. Sep 24, 2016 at 8:44 PM
    nimbostratus
    nimbostratus [OP] New Member
  3. Sep 24, 2016 at 9:02 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I would get it inspected first. It looks bad, but it could just be superficial. If it's not to bad, spend a day underneath with a wire brush and plenty of cold beverages with a bunch of rustoleum and it'll be fine. After the paint is dry, hose that bad boy down with a few cans of fluid film every year to keep it nice. It's not my truck or money, but Im willing to bet that the linex option is going to be really expensive and can't do as good of a job as fluid film can as far as prevention goes.
    Black Wolf likes this.
  4. Sep 24, 2016 at 9:05 PM
    nimbostratus
  5. Sep 24, 2016 at 9:08 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Can you get inside the interior under the carpet and look for sand and silt? It may have been in a flood?
    Main thing i see is a leaf shackle bracket possible rusted and brittle.
  6. Sep 24, 2016 at 9:15 PM
    nimbostratus
  7. Sep 24, 2016 at 9:22 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I vote for trying to clean it up. Worse case scenario, it will probably help you get more money if you decide to trade it in. Best case scenario, you get it all fixed and have a long, happy relationship with a great truck.
    rons23 likes this.
  8. Sep 24, 2016 at 9:24 PM
    nimbostratus
  9. Sep 25, 2016 at 3:51 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Hey man. It's not that bad. In nw ohio here and looks about like any Midwest vehicle. What I'd do. Buy a needle scaler (I just picked one up on Amazon for $50) get some rustoleum rusty metal primer and some rustoleum black. The primer makes a huge range difference in adhesion and rust stopping. The needle scaler will make the huge job of scraping very manageable. You do need a decent sized air supply to run it. I've treated several trucks this way. Brush on the primer, brush on top coat as much as you can reach and use rattle can for the rest. Will need touched up every few years. You're fine. Trucks fine.
    TheBeast and MotoTundra like this.
  10. Sep 25, 2016 at 3:57 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I may be in minority here, but it doesn't look that bad. Most rust seems to be surface rust. The only way to find out is to get underneath and use wire brush. If it starts to break, then the rust is too deep I would just bite the bullet and trade it in. Dealers have resources to deal with it. I would suspect, however, that most of it will scrub away.
    All steel rusts, even stainless steel. The question is when. Western PA (near the lake) are blessed with lots of snow. Snow is not bad, but the chemical/salt to fight it eats up cars like crazy. You are probably not used to seeing rust like that, but that's sorta common around here. When the rust begins to eat the side of the vehicle (we have plent of those), then it becomes big $ problem.
  11. Sep 25, 2016 at 4:58 AM
    NJMIke
    NJMIke New Member
    2016 Tundra Double Cab SR5
    Rial cast wheels. Looking for TRD Pro grill with chrome surround
    I checked and there is no recall on 2007 Tundras for frame rust. What this basically means is that any problem would be yours to deal with & Toyota would not likely offer any $$$ help. However, a good Toyota dealer, particularly one who was involved with the thousands of Tacoma recalls and many 1st Gen Tundras, could give a real world evaluation. If they deem it to be unsafe they would not let you drive it away without you signing a waiver that you understand the issues. You can ask them the specific procedures before you let them look at it so if you get backed into a corner you at least understand beforehand. Other possibilities is a previous owner drove it a lot through muddy areas and never bothered to clean the mud off the frame. That too would start corrosion like your pictures show. Might not be nearly as bad as you think. One more thought. I had a really great independent mechanic I used for years who serviced my 2002 Tacoma. Had this truck for 333,000 miles. He was totally surprised when Toyota replaces the frame on it under their recall since he inspected the frame himself and thought it was good. As good as he was, he didn't know what to look for until I showed him what they found and where to look. These trucks have been around for some time now so a good Toyota dealer should know what's just surface rust and what might be a structural problem.
    TheBeast and SouthBoundSteve like this.
  12. Sep 25, 2016 at 7:33 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    If it were mine, I would just start at one end of the truck and start cleaning it up. Wire brush, sand paper and rustoleum. It might take a while, but it won't take forever. When you get to the suspension, either clean it up as best you can or buy used parts, clean them and paint, then install them when you can. Unless you see holes from the rust, the metal is probably still just fine. You could have it inspected to ease your mind. Car max is only going to give you wholesale price on it, so most likely you will take a loss. But you could take it up there and see. There's no harm in it.
    NewImprovedRon and rons23 like this.
  13. Sep 25, 2016 at 7:49 AM
    TheBeast The Beach
    some good advice here.
  14. Sep 25, 2016 at 8:09 AM
    nimbostratus
  15. Sep 25, 2016 at 8:24 AM
    TheBeast The Beach
    sounds like a plan
  16. Sep 25, 2016 at 9:08 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    That's what I'm talkin bout, :cool:
    NewImprovedRon likes this.
  17. Sep 25, 2016 at 9:50 AM
    15whtrd
    15whtrd Mr. Blonde
    Its nice to see you're going to save it from the inevitable graveyard 5-10 years from now.
  18. Sep 25, 2016 at 10:03 AM
    nimbostratus
  19. Sep 26, 2016 at 11:09 AM
    #49
    nimbostratus
  20. Sep 26, 2016 at 11:58 AM
    #50
    nimbostratus
  21. Sep 26, 2016 at 12:41 PM
    #51
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    yes. rust convertor or rusty primer and then topcoat.
  22. Sep 26, 2016 at 1:13 PM
    #52
    nimbostratus
  23. Sep 26, 2016 at 1:36 PM
    #53
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Go trade it in, The dealership won't even look under it. At that age the dealership will wholesale it out...
  24. Sep 29, 2016 at 9:14 PM
    #54
    nimbostratus
  25. Sep 30, 2016 at 7:24 AM
    #55
    nimbostratus
  26. Sep 30, 2016 at 11:49 AM
    #56
    15whtrd
    15whtrd Mr. Blonde
    Scrub off that rust behind the bumper, hit it with some rust converter, maybe blast it with some rustoleum, and then some body color duplicolor to hide it a little bit. Same thing under the truck knock off the loose stuff and hit it with some matte black rustoleum. When you're all finished protect it with some fluid film.
