7” BDS suspension alignment
Discussion in 'Suspension' started by Blacktundra808, Mar 9, 2020.
  1. Mar 9, 2020 at 12:36 AM
    Blacktundra808
    Blacktundra808 [OP] New Member
    Hi guys I’m new here I have a 2017 tundra planning on swapping out lift currently running BDS 7” having major outside tire wear reaching a dead end on fixing issue . Anyone running same lift with CB tie rods I heard it’ll help with alignment issues ?? My truck only has 15k miles never gone off road and been aligned 2x ..can this issue be fixed at all ?? I need some input please thank u
    7” BDS
    20x12
    Nitto Trail Graplers
    15k miles
    BUGEATER likes this.
  2. Mar 9, 2020 at 1:22 AM
    tmart
    tmart New Member
    Travis
    The 7 inch bds lift is known for this. I’ve put 30k miles on my new tires though and it’s barely starting to be noticeable so something might be off with yours. I’m going to dismount my tires and flip them on the rim next time I go in for a rotation to get it to wear evenly but mine isn’t too bad. I can’t help with why yours is so bad if your alignment numbers look right...
  3. Mar 9, 2020 at 1:31 AM
    Blacktundra808
    Are you running CB tie rods ?
  4. Mar 9, 2020 at 2:54 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome from Gettysburg!
  5. Mar 9, 2020 at 9:24 AM
    Blacktundra808
    are you running CB tie rods?
  6. Mar 9, 2020 at 9:25 AM
    Blacktundra808
    Hello from Hawaii
  7. Mar 9, 2020 at 4:28 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Welcome from SC
  8. Mar 10, 2020 at 2:39 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Are you running CB tie rods? They are fantastic.
  9. Mar 10, 2020 at 2:52 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have the same 7inch bds lift and I’m running the coach builder tie rods! I haven’t had any problems!
    DM 2018 Tundra likes this.
  10. Mar 10, 2020 at 4:51 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Are you using factory alignment specs?
    BDS suggests:
    The Tundra specifications for the best tire wear are below. I have attached the procedure Tundra’s use for their alignment, I am sure you’ll find it interesting.
    Caster =maximum positive adjustment available
    Camber=0
    Toe=1/8” toe in
  11. Mar 10, 2020 at 6:28 PM
    Blacktundra808
    How many miles you have on your lift/tires ?
  12. Mar 10, 2020 at 6:28 PM
    Blacktundra808
    I’m getting CB tie rods this Friday
  13. Mar 10, 2020 at 6:30 PM
    Blacktundra808
    Awesome info I’m passing this on to my mechanic I’m getting CB tie rods & brand new tires
  14. Mar 10, 2020 at 6:30 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I have a set just have not put them in. They are beefy
  15. Mar 10, 2020 at 6:31 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Oh and get the specs from David at CB on aliment
