6x6 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Bruce2020, Jul 20, 2020.
  1. Jul 22, 2020 at 2:54 PM
    #61
    Bruce2020
    Bruce2020 [OP] New Member
    I need help with understanding how the 4WD system works....a wiring diagram will be very helpful. I ended up with a PDF of the transfer case actuator timing
  2. Jul 22, 2020 at 3:30 PM
    #62
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    The 4WD may be difficult to troubleshoot since we may be looking at a hybrid system. Can you take some pictures of the front differential and transfer case?
  3. Jul 22, 2020 at 4:06 PM
    #63
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are the engine, transmission, and transfer case the same type that came in the stock version of the truck? The non-factory looking radiator and that bright blue/green thing on the top of the engine bring me to this question.
    Is the transfer case (4WD high range) actuated via a button/switch/dial on the dash or a button on the transfer case handle (if there is one) on the transmission tunnel?
    What is flashing when you attempt to engage 4WD?
    Is it the transfer case that's not engaging, or just the front differential?
    sf319 likes this.
  4. Jul 22, 2020 at 4:35 PM
    #64
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Interesting...
  5. Aug 19, 2020 at 5:06 AM
    #65
    Bruce2020
    So basically everything is stock. The rear axle gets it drive when the front diff (4wd) is engaged...they are 2 buttons around the AC panel on the dashboard. When we try to engage the 4wd the indicators on the cluster begins to flash, 4 hi.... sometimes if I cycle the ignition it stays on solid.
  6. Aug 19, 2020 at 5:08 AM
    #66
    Bruce2020
  7. Aug 19, 2020 at 6:07 AM
    #67
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you been able to maneuver the slightly while shifting from 2H-4H? Many times it helps thing align for engagement. Think of splined collars having to slide over splined shafts where the shaft has to be rotated just ever so slightly so the collar can complete its travel to engage and the computer shows it's satisfaction with a steady indicating dash lamp. Sometimes it helps to ease up on the service brake to allow the vehicle to roll a few inches. And remember that for the 4L transition to happen the transmission needs to be in P or R and the transition from 2H to 4H has to be completed successfully. You can't really go from 2H to 4L in one transition. Same for the reverse transition.
  8. Aug 19, 2020 at 6:11 AM
    #68
    Bruce2020
    They had removed the unit from the transfer case, I don't know if there is a particular way of reinstalling it. I'll try the advice..thank you.
  9. Aug 19, 2020 at 6:17 AM
    #69
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Removed the electronic actuator? Oh jeez! I've read that those are a bugger to get reinstalled and synced up correctly. That's way outside my ability to offer suggestions about.
  10. Aug 19, 2020 at 6:56 AM
    #70
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    How on Earth did I miss this one? That was easily a first gen in the first pic, the hood and engine bay are the tell.
    If we keep bumping this somebody will have a diagram. Where is this at? Looks like Central America?
    bmf4069 likes this.
  11. Aug 19, 2020 at 10:26 AM
    #71
    Bruce2020
    Guyana..south America
    Darkness likes this.
  12. Aug 19, 2020 at 10:46 AM
    #72
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Dude, same! How the .... did I miss this? The TB cover gives it away as a 4.7
    Is that a ford bed? And the front axle drives the rear?
    So when you push 4hi it sends a signal to the xfer case and front axle to tell them to go into 4wd. If either doesn't engage your light will blink.
  13. Aug 19, 2020 at 10:54 AM
    #73
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I thought it was a stretched Step-Side bed...?
  14. Aug 19, 2020 at 10:54 AM
    #74
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  15. Aug 19, 2020 at 10:54 AM
    #75
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That tail light looks very fordish.
  16. Aug 19, 2020 at 11:05 AM
    #76
    N84434
    Milwaukee WI.
    2001 Limited TRD
    You're right. Now i see it... the Ford has a round fuel door though, so maybe Ford lights grafted onto the Tundra bed?
  17. Aug 19, 2020 at 11:08 AM
    #77
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah yeah, I see it. And I may be mistaken, but are those tacoma headlights? I know someone said 2nd gen, but my first thought was taco.
  18. Aug 19, 2020 at 11:08 AM
    #78
    Bruce2020
    Bmf4069 thank you. Well to be honest these guys have done a lot on this build. Radiator, ebc brakes..flow master headers, complete suspension, new fuel pump(double flow rate), 12 point injectors, double oil cooler, msd coil packs. As I remember I'll update.
    Darkness, N84434 and bmf4069 like this.
  19. Aug 19, 2020 at 11:09 AM
    #79
    Bruce2020
    All of the lights are not tundra lights...sheet metal fabrication.
    bmf4069 likes this.
  20. Aug 19, 2020 at 11:09 AM
    #80
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    No problem. All I ask for in return is a complete build sheet and at least 57 pics.
  21. Aug 19, 2020 at 11:17 AM
    #81
    Bruce2020
    Definitely
  22. Aug 19, 2020 at 11:47 AM
    #82
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looked like modified f150 besides to me as well. I love how lawless this build is.
    @bmf4069 you bought that book and today is where it pays off :D
    bmf4069 likes this.
  23. Aug 19, 2020 at 11:51 AM
    #83
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is he reading it in his work van? Dedication
    bmf4069 and Darkness[QUOTED] like this.
  24. Aug 19, 2020 at 12:00 PM
    #84
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've been reading my Honda Element book before bed every night, volume 1 of 2 at least.
    :anonymous:
    bmf4069 and FrenchToasty[QUOTED] like this.
  25. Aug 19, 2020 at 12:04 PM
    #85
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm actually liking the yellow color that it was before. I've only seen one other yellow first gen, its a refreshing thing to see.
  26. Aug 19, 2020 at 12:05 PM
    #86
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't know how I missed this either. And I'm so uncultured I had to google Guyana.
  27. Aug 19, 2020 at 1:46 PM
    #87
    Professional Hand Model
    Hand Protectors
    I knew a Witch Doctor from Guyana. He tried throwing some voodoo secret mojo potion on me and I blocked it in the Name of JC.
    Stoked on this 6x6 action. What kind of brakes are we using on the rear axles?
    Fieldnstreamer and bmf4069 like this.
  28. Aug 19, 2020 at 2:59 PM
    #88
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Indeed I am! I carry in there just in case I can help someone on my lunch break.
  29. Aug 19, 2020 at 6:56 PM
    #89
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Oh, man...now I want one of those 6Xs--just to pull into Toyota dealerships around here and see the reactions... :monocle:
    Cpl_Punishment likes this.
  30. Aug 19, 2020 at 6:58 PM
    #90
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ask for warranty work...
