6900 vs 7200 GVWR
Discussion in 'Towing & Hauling' started by Westside_cook, Jan 25, 2020.
  1. Jan 25, 2020 at 10:44 PM
    Westside_cook
    Westside_cook [OP] New Member
    2018 Double Cab in Superwhite
    Stock
    Hey guys, I’m trying to figure what possible reason some tundras have 6900 GVWR and why some have 7200. Aside from the engine and 2WD vs 4WD I can’t think of any possible suspension differences. Only cab/bed length are different from what I can tell. If you don’t mind post your Year, Cab, Trim, 2x2 or 2x4, and finally your posted GVWR. I’m trying to see if I can figure out Toyota’s nonsense in why some of us get jipped on Payload. PS not interested in anyone’s payload #’s just GVWR (payload has too many variables). Thanks. I’ll probably make a chart if I get enough input.
  2. Jan 25, 2020 at 10:46 PM
    Westside_cook
    Stock
    Edit: just realized that the pro has a different suspension but go ahead and post your #’s. It’s a variable that will be easy to distinguish.
  3. Jan 25, 2020 at 11:09 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Double cab vs Crew max. Crew max is heavier due to it's bigger cab. Single cab will be the lightest if it's still made.
    Westside_cook[OP] likes this.
  4. Jan 26, 2020 at 12:23 AM
    Westside_cook
    Stock
    That's more of a payload difference though not so much what the suspension should be able to handle.
    Post your #'s
  5. Jan 26, 2020 at 3:14 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    4.6 vs 5.7.
  6. Jan 26, 2020 at 4:27 AM
    Westside_cook
    Stock
    Negative. I have a 5.7 with the 6900 GVWR
  7. Jan 26, 2020 at 4:29 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    My 2019 4WD Crewmax 5.7L 1794 is 7200.
  8. Jan 26, 2020 at 4:39 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    My 2018 SR5 Upgrade Double Cab 5.7L 4x4 is at 7200.
  9. Jan 26, 2020 at 4:46 AM
    SprinterAE86
    Ian
    SR5 crew max is lighter than the 1792. 1792 have more bells and whistles each ounce of switches, servos, wires, can add up to pounds. That's why the payload are reversed. 1792 have less payload than base sr5.
  10. Jan 26, 2020 at 4:52 AM
    Westside_cook
    Stock
    I'm not talking about payload. I understand how it works. Bottom line, I'm trying to figure out what variable causes toyota to rate my vehicle lower than some crewmax's GVWR. My truck is 4x2, DC, SR5. I dont think you're getting the point of my OP.
  11. Jan 26, 2020 at 5:31 AM
    SprinterAE86
    Ian
    2020 SR5 DC 4x4 7100 "0" dealer add ons
    2016 SR5 DC 4x2 6900 "200lbs" dealer add ons
    6M6ykx1gI1TEqEodDQHyhsn6lBEMsWFcOaustdix_55111568d79e834550678e0e2dd0b1d66d46cc87.jpg
  12. Jan 26, 2020 at 5:34 AM
    timsp8
    NY
    But addons don’t lower the gvwr. You can always take them off. They only lower the payload.
    Cpl_Punishment and GODZILLA like this.
  13. Jan 26, 2020 at 5:41 AM
    timsp8
    NY
    I have a 2018 Limited Crewmax 5.7 4wd. 7200 gvwr.
  14. Jan 26, 2020 at 5:41 AM
    SprinterAE86
    Ian
    The gross weight is set from the factory. But you have to subtract it from your payload.
  15. Jan 26, 2020 at 6:21 AM
    Westside_cook
    Stock
    I wonder what tires yours come with stock. I noticed with the 2 different plates sprinter pointed out that the axle ratings are different but as far as I know toyota uses all the same axle's.
  16. Jan 26, 2020 at 8:11 AM
    timsp8
    NY
    The Michelin’s.
  17. Jan 26, 2020 at 8:12 AM
    timsp8
    NY
    Pretty sure it’s the opposite. Gvwr is set and never changes. You have to subtract the actual vehicle weight from gvwr to get your payload.
    Payload changes. Gvwr never changes.
    Example: gvwr is 7200. Truck actually weighs 6000. Payload is 1200.
    You put 200 # worth of addons. Truck now weighs 6200. With gvwr of 7200 the payload is now 1000.
    So with a gvwr that can never change, the original question was why are some 7200 and others 6900 on the same truck.
    Original question didn’t have anything to do with payload or addons.
  18. Jan 26, 2020 at 9:00 AM
    SprinterAE86
    Ian
    I appologize for adding the second sentence in my on my second post mentioning about payload. It just went off track of your original question.
    https://auto.howstuffworks.com/auto-parts/towing/towing-capacity/vehicle /gvwr.htm
  19. Jan 26, 2020 at 10:05 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Steel vs aluminum wheels make any difference?
  20. Jan 26, 2020 at 10:25 AM
    timsp8
    NY
    I wouldn’t think wheels or tires would make a difference as those are easily replaceable by the owner. Tires are a wear item.
    Too much liability if for instance a truck came with the gvwr rated for load E tires at max psi then someone switched to some cheap tires but still tried to haul the same payload up to their gvwr. I think the manufacturer would go with the lower # like tundras with p rated tires.
  21. Jan 26, 2020 at 10:30 AM
    timsp8
    NY
    Yeah I was just referring to post 9 and 11 when you mentioned addons and payload. Those don’t alter manufacturers gvwr rating. I have a spray on bedliner and a sticker that my max payload is reduced by 40# or something. But gvwr is the same. That article you linked doesn’t even mention payload.
  22. Jan 26, 2020 at 10:43 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I agree that they downgrade our ratings on purpose. But that is just my opinion.
    But tires and wheels could affect the GAWR. If each wheel is only rated for a 2000lb load for example, then it doesn’t matter if it is a GM 14 bolt full floating axle. The rear axle should only have 4000lbs of load on it correct?
  23. Jan 26, 2020 at 10:57 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Sliding moon-roof option will be the difference maybe? I know I couldn't get the moon-roof and sprayed in liner from the factory... It exceeded some bullshit weight limit. I'm in a Platinum CM
  24. Jan 26, 2020 at 11:04 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I just went in to the build configuration tool on their website, and GVWR changes from 7,000 to 7,200 when you go from 4x2 to 4x4. Not sure why they would do that, other than making payload capabilities the same across 4x2 and 4x4 models. I know that in HD truck builds, you can opt for a higher GVWR "package" if you get a diesel so that you don't lose payload.
    Maybe there is some slight structural differences between the 4x2 and 4x4 models that would allow a slightly higher GVWR?
  25. Jan 26, 2020 at 11:19 AM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    Mine is a 2013 double cab rock warrior it comes at 7100. Of course it’s a second gen. Of course y’all know that.
  26. Jan 26, 2020 at 11:22 AM
    Westside_cook
    Stock
    I would be curious to see of there are any structural changes that make a 200+ pound difference (200 pounds plus the offset of the weight of the 4x2 system.
    My initial thought was as you stated that they were trying to keep a certain number for payload and adjusting the GVWR allows them to do that.
    I dont intend on overloading my vehicle but if Toyota was playing with the #'s I would feel more confident about my payload while towing knowing that I have the same basic structure as another tundra toyota deemed was 300 pounds more capable.
    Not declaring it so but thank you everyone for your numbers.
  27. Jan 26, 2020 at 11:48 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Isn’t there a chart in the owner’s manual that has the different configurations and GVWRs? I am away from my truck today so I can’t check but I am pretty sure I looked at it.
    I just looked at the 2008 owners manual online and the last 3 pages have the different configurations and GVWRS.
  28. Jan 26, 2020 at 12:54 PM
    Westside_cook
    Stock
    I'll have to glance at mine again, I know there is a chart for payload, which mysteriously doesn't match my door plate at all.
  29. Jan 26, 2020 at 12:56 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Totally weird that 4wd is the difference.
    They have all the same major parts.
  30. Jan 26, 2020 at 1:33 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    The front wheel bearings are larger on a 4x4, other than the weight of the 4x4 components, I believe that is the only difference. My guess is they pushed up the gvwr because almost all the 4x4 weight is on the front axle rather than the rear which is where most people load up there trucks. Which means that the 6900lb gvwr and the 7200lb gvwr allow the same amount of rear axle load. This is also supported by the fact the rear axle rating on those 2 door stickers are within 50lbs of each other but the front axle rating is 100lbs difference. Another thing that is different between the sticker is tire size, which affects bearing loads.
    Westside_cook[OP] and Hbjeff like this.
