6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. May 7, 2019 at 3:12 PM
    #241
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    It rides phenomenally to me. So much better than stock. Those shocks are monsters. Way bigger than the 5100’s which I’ve ran on previous trucks. They ride way better than the 5100’s in my opinion.
    Hol Milk likes this.
  2. May 7, 2019 at 3:15 PM
    #242
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Which stock shocks are still on the rear? I do no off reading but am unsure to just do 5100’s or put the 6112’s which might be overkill
  3. May 7, 2019 at 3:29 PM
    #243
    BigLoggerhead
    I’m not really sure what your question is but I’m still running the stock shocks in the rear. I’ve heard of people running the 5100’s in the rear with the 6112’s but I think a lot of people run the 5160’s which are the 6112 equivalent for the rear I believe.
  4. May 7, 2019 at 3:51 PM
    #244
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    You stated you kept the stock rear shocks. I was unsure what came with your truck, thats all. My SR5 has the Billstein 4600 all the way around.
    BigLoggerhead likes this.
  5. May 7, 2019 at 5:20 PM
    #245
    Big J
    Big J New Member
    2020 4x4 crewmax
    I think all stock shocks are 4600
    5100 rear allows up to 1" more of lift
    5160 rear allows up to 1.5" more of lift
    5125 rear is 3-5" more of lift
    Not sure if bilstien makes anything that goes like 0-2. Or 2-3 range . Anyone know?
  6. May 7, 2019 at 6:35 PM
    #246
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    5AEF4492-6168-4073-A100-3977C39271D9.jpg 6112 1.3” with 5160. 275/70/18
    Got some big wheel envy at the northeastern meetup with all those big tires, but with this size tire I love the drive and look.
  7. May 8, 2019 at 7:30 AM
    #247
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    Looks awesome.
    It doesn't look nose high to me in the pics, but I also have my 6112's at 1.9" on same size RG's with a driver side shim and at certain times it looks nose high. Not always. I've measured it multiple times and it always measures as having 1/4-1/2" rake. Have you measured yours?
    I may end up going with a +1 shackle in the rear as well.
    Coachbuilder1 likes this.
  8. May 8, 2019 at 7:36 AM
    #248
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    That is not correct. Only Tundra's with the "TRD Off-Road" package get the 4600 rear shock. The black shock that come on non-TRD Tundra's are just some generic shock made for Toyota by ?
    Big J[QUOTED] likes this.
  9. May 8, 2019 at 8:13 AM
    #249
    BigLoggerhead
    I measured it initially and it appeared to be .25” to .5” lower in the front. Maybe it’s just an optical illusion. I’m gonna give it a week or so to settle and then revisit it.
  10. May 8, 2019 at 8:24 AM
    #250
    Big J
    Big J New Member
    2020 4x4 crewmax
    Ohhh I though 4600 was standard. :eek: anyone know if bilstien makes a 0-2" range for the rear? I could only find the 5160's at 1.5
  11. May 8, 2019 at 8:28 AM
    #251
    TundraLaw
    TundraLaw Fourth Year Member
    Northern Nevada
    OTW 22 limited crewmax trd offroad black/boulder
    very nice! about to set mine at 1.3 on 275/70/18s as well. Any rubbing or removing besides the front little aero flaps?
  12. May 8, 2019 at 8:30 AM
    #252
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I don’t know. About 15-20 years ago I called Bilstein and asked them for a rear shock recommendation for a lifted 1st gen Tacoma. That was before they had any specifically for that application. Their tech was very knowledgable and recommended a shock designed for a different vehicle that shared similar length and mounting requirements and a valve setting that would with the weight and leaf spring rate of my Tacoma. They ended up working great. So long story short, I’d call up Bilstein and see what they say.
  13. May 8, 2019 at 8:33 AM
    #253
    Zero One Actual
    I have the same question. I have 6112s at top setting and @coachbuilder +3 shackles for the rear due to a rack system and @decked system (extra weight issue) Nothing installed yet though. I am debating if I should go with the @toytec boss shocks because they say they support up to three inches of lift. Whereas the 5160s say 1.5.
    If anyone knows the answer to this, that would be a big help.
  14. May 8, 2019 at 9:58 AM
    #254
    bomber
    bomber New Member
    2017 tundra cm 4x4
    Sorry for the late response. Last I checked I had .75 of a inch rake. Looks dead level though.
  15. May 8, 2019 at 11:06 AM
    #255
    justfortun
    James
    Boston
    2016 SR5
    Had to take a grinder to the skid plate because there was some rub when reversing. Probably could have cut a bit less but cleaned it up and hit the naked edge with some rustoleum
    Kiddnapped Tundra, misfit and equin like this.
  16. May 8, 2019 at 11:09 AM
    #256
    TundraLaw
    Northern Nevada
    Dang! Not what I wanted to hear lol. May have to size down to stock size. Would really prefer to not have to cut or trim anything.
  17. May 8, 2019 at 12:31 PM
    #257
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    What offset are your rims? As a fellow cavalry member, great looking truck!
  18. May 8, 2019 at 12:39 PM
    #258
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Or be a man and set you 6112 higher :rofl::rofl:
    Allrsdup and Smiley like this.
  19. May 8, 2019 at 1:27 PM
    #259
    gjcarving
    gjcarving New Member
    If your running the stock skid you only have to bend the back edges up or down. If you run something like RCI they are made to handle larger tires etc. And as a huge bonus add better protection and easy access to the oil filter.
  20. May 8, 2019 at 2:14 PM
    #260
    justfortun
    James
    Boston
    2016 SR5
    Stock is great if you don't mind the look. Great gas milage. Great on pavement. Great off the line. Nobody will look at you funny...or at all. I joke. But seriously, you aren't trimming anything structural. It's a 5 min, do it yourself job. Cutting through 1/16th" sheet metal...All you need is a $35 grinder from Harbor Freight. Or the other option is as @gjcarving says - you can bend it up, or you can always run an RCI if you don't want to trim.
    I upgraded suspension mostly for drive improvement, not to flex my bro lean. The second setting sits the truck at a front height that all trucks should look coming off the factory floor. I wanted a proportioned look, with a slight rake, and a larger tire. It's my daily driver. And in the 2.5 years I've put on 50k miles, so I can't go too crazy on size.
    If I go with bigger tires than the 275/70, I'll raise it up but I don't want to be the guy who drive around the malls looking like they skipped leg day.
    And right now, the drive is amazing.
    misfit and danno266 like this.
  21. May 8, 2019 at 3:37 PM
    #261
    cmiller219
    Nashville, TN
    I was just giving shit haha. But it would be impossible with only 3inches if lift to look like you skipped leg day that’s not much at all
    justfortun likes this.
  22. May 8, 2019 at 4:04 PM
    #262
    justfortun
    James
    Boston
    2016 SR5
    I'm just pissed because in Massachusetts we're not allowed to lift it more than 2"
    Just another example of the man keeping me down. Literally.
    Silverghost likes this.
  23. May 8, 2019 at 8:38 PM
    #263
    Wldkatz03
    Wldkatz03 New Member
    Michael
    2019 Toyota Tundra 1794 Edition 4x4
    Any more pics? I’m looking at the same set up with factory wheels and tires since they’re new. Thanks! How’s the ride compared to the stock platinum ride?
  24. May 8, 2019 at 10:42 PM
    #264
    BigLoggerhead
    I’m pretty sure SCS wheels are +25 on the Tundra.
  25. May 9, 2019 at 2:57 AM
    #265
    allstar617
    allstar617 New Member
    Sy
    Boston,Ma
    2014 sunset bronze 1794
    Thule areoblade roof racks,Full Led conversion, rackarod lockable rod holders,Led bed lights,Lock'er down safe, 42" led light bar.......6112/5160 suspension lift Coachbuilder +3 shackles, shims and bushing set. Toyo open county AT2’s 295/65/20’s on stock black painted wheels..........
    I have had no issues with my setup
    6112’s on top setting 3 Coach builder shims 2 on drivers side 1 on passenger side
    5160’s in the rear with +3 coach builder shackles with leaf spring spring bushings
    Supreme diff drop on stock Uca’s
    Running 35’s Toyo open country AT2’s on factory platinum wheels with 1 1/4” bora spacers. Only issue Mass inspection gave me was for my tint SMH!!!
  26. May 9, 2019 at 3:32 AM
    #266
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Chris forgot to share with you to get diff drop off you go top setting. It's $50 extra bucks. Noone does it hardly and I'm sure many will say not necessary but after my CV boot tore 50 miles into my 6112s on highway driving it's worth the peace of mind.
  27. May 9, 2019 at 3:34 AM
    #267
    justfortun
    James
    Boston
    2016 SR5
    If you’ve had the inspection after the new camera systems, that’s great news. Especially with wheel spacers. Your truck looks awesome. Have you touched your exhaust?
  28. May 9, 2019 at 3:41 AM
    #268
    allstar617
    Sy
    Boston,Ma
    Thank you
    Nothing to the exhaust yet, planning to do the TRD pro end pipes with the BA system. The inspection was last August when they implemented the camera’s
    justfortun[QUOTED] likes this.
  29. May 9, 2019 at 10:19 AM
    #269
    Kurdt
    Kurdt New Member
    Austin TX
    Yep all I did was bend mine up a bit...took 10 minutes maybe. I figure I'll end up replacing it at some point anyway as it is about the flimsiest skid plate I've ever seen.
    allstar617 likes this.
  30. May 9, 2019 at 10:22 AM
    #270
    Kurdt
    Kurdt New Member
    Austin TX
    I thought this was some sort of joke until I looked it up. wow. do they actually enforce this law?
