6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Apr 15, 2019 at 9:55 AM
    #211
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    At what point do you guys think about having to get a after market uca is necessary? 3" or more
  2. Apr 15, 2019 at 10:07 AM
    #212
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    Every truck is different so to speak. I went with them at 2.5 inches. With aftermarket UCAs you can get a lot more caster which helps with wandering at highway speeds.
  3. Apr 15, 2019 at 1:37 PM
    #213
    Hyperlite33
    Hyperlite33 FN-2187
    2018 White Platinum 4x4
    I just put 6112s on the top setting without shims over the weekend and gained 3 1/8" lift in the front. Now sits 1"taller in the front but have CB +2 going on tonight. Does this settle down to 2.5" after an alignment and some dive time? I've read conflicting stories...
    I did drive it around the neighborhood to see what all the interest in the brodozer look was but still couldn't figure it out.
    Coachbuilder1 likes this.
  4. Apr 15, 2019 at 2:05 PM
    #214
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Did you buy preassembled?
    Never seen anything over initial 3” from top setting. I would say you’re going to see some settlement. I imagine at that much height gain your camber is jacked up royally and you need an alignment and some drive time.
  5. Apr 15, 2019 at 2:36 PM
    #215
    Hyperlite33
    Hyperlite33 FN-2187
    No I assembled them myself. I've read anywhere between 1/8" - 1/4" of settling but never 5/8". Going to add the +2s shortly and then re-measure. I'm just hoping it settles to about 3/4" tail high after everything is done so the radar doesn't start freaking out.
  6. Apr 15, 2019 at 3:34 PM
    #216
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Are you sure the front shock/sprng assemblies are assembled correctly?
  7. Apr 15, 2019 at 4:14 PM
    #217
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Looks good! What are you using for the 1” in the back?
  8. Apr 15, 2019 at 4:19 PM
    #218
    Hyperlite33
    Hyperlite33 FN-2187
    Yes... assembled according to the instructions
    matictundra[QUOTED] likes this.
  9. Apr 15, 2019 at 6:14 PM
    #219
    Danman34
    Danman34 New Member
    Danny
    Toytec shackles.
  10. Apr 15, 2019 at 6:16 PM
    #220
    KnuckleHD
    Awesome, I’m guessing they are the adjustable ones, set to 1”. I have a set of CB+2s that are about 1.25” and trying to get an idea of the rake with 1.9” up front. Thanks!
    dannysmith604 and Coachbuilder1 like this.
  11. Apr 15, 2019 at 6:17 PM
    #221
    Danman34
    Danman34 New Member
    Danny
    Yep. 1 or 1.5”. I’m on the 1” setting and also replaced the leaf spring bushings with polys. Back of the truck is noticeably smoother over daily driving road bumps and off road.
  12. Apr 16, 2019 at 11:36 AM
    #222
    Zero One Actual
    Just ordered my 6112/5160 official Tundras.com setup.
    Group question for everyone. I am waiting on the next shipment of @SCSPerformance Ray 10's, so that is the wheel I am getting. As for the tires, I think I have it down to the Cooper AT3 XLT. Now, for our setup, I am stuck between these two sizes...
    Cooper AT3 XLT 60,000 Tread Warranty
    285/75/R18 Depth: 34.84, Width 11.5, 10 Ply, 59 Lbs
    295/70/R18 Depth 34.25, Width 12, 10 Ply, 61 Lbs
    Some people say they wish they went bigger than the 285 to the 295, but others say the 295 is too big/wide and needs UCA, CMC, etc. Anyone out there running our setup have any insight on this? I will have the 6112 at 1.9 and the 5160s in the rear plus Coachbuilder +3 shackles in the rear to assist with some additional weight in the back to include a Decked system and a Leitner cargo rack.
    GELCW and dannysmith604 like this.
  13. Apr 16, 2019 at 12:59 PM
    #223
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    I would set the front at 2.5. 1.9 is going to be tight. I am running 285/70 18 with 2.5 of front lift. I had to remove the front flap on the bumper and push the liner forward.
  14. Apr 16, 2019 at 5:48 PM
    #224
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    Mine looks that way to me at times. I think you and I have the same setup (1.9" with driver side shim, nothing out back).
    I've measured it a couple times, and it is actually .25-.5" rake. Something about the lines of the truck seem to make it look nose high at times.
    I'm also considering adding a shackle for 1" or maybe the Coachbuilder .625". What I'm unsure of is if I will need to replace the 4600's for 5100's to account for extra travel. Will look into that more later on.
  15. Apr 16, 2019 at 9:46 PM
    #225
    oneup
    oneup New Member
    Cincinnati
    17 cm
    Yep we got same set up. I went ahead and put 5100 on the rear since it wasn’t much more. I don’t think I want shackle that lift up rear much. Maybe 1” @ most.
    Thinking about adding 1” spacer on mine too. Other than that pretty sweet set up and I like it so far as is.
  16. Apr 17, 2019 at 6:18 AM
    #226
    Marshwalker
    Marshwalker New Member
    Z
    I have same lift put on this week and fumbling which tire size, Nitto like yours in 285 or the 275. I had tire shop order both so I could see side by side. How is the power MPG and feel with 285. I am going to have our slide in camper in during the summer and driving in mountains. Truck doing well with tire? I know a lot of guys go 35 in and have no problem. Love to hear your feedback. thanks Zach
    GELCW and tahoe like this.
  17. Apr 17, 2019 at 7:34 AM
    #227
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    From what I remember there is not much weight difference between the 275s and 285s, maybe a few lbs so there shouldn’t be much of a difference. Power wasn’t effected too much however I have since added 488 gears
  18. Apr 17, 2019 at 8:05 AM
    #228
    Marshwalker
    Z
    what was the reason for 4.88 gears? happy with choice?
    dannysmith604 likes this.
  19. Apr 17, 2019 at 8:16 AM
    #229
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Yep I am happy. I installed gears to bring power back when towing. My truck would hunt gears from 6-4 on the highway. Gears improved that and MPG
  20. Apr 17, 2019 at 8:19 AM
    #230
    Marshwalker
    Z
    Thats awesome and good to know. I am new to a tundra. I came from a f 250 diesel an never had power issues:) just not needed as a daily driver any more. Whats your milage on highway now and rpms?
  21. Apr 17, 2019 at 8:29 AM
    #231
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    70 mph around 2k. Mileage around 15.5 to 16
  22. Apr 17, 2019 at 8:56 AM
    #232
    Marshwalker
    Z
    wow.. thanks for the responses
  23. Apr 26, 2019 at 4:25 PM
    #233
    Hyperlite33
    Hyperlite33 FN-2187
    Finally finished with the lift/ tires...
    6112s top setting no shims
    Coachbuilder +2 with 5100s
    Method NV305 +25 offset wheels
    Falken Wildpeak AT3W 295 70R18
    CB bumper shims, removed all front mudflaps
  24. Apr 26, 2019 at 5:24 PM
    #234
    Part_time
    Oregon
    Went to a local shop today, he suggested going with 5100s and using old man coils said it is cheaper like that. What would the ride difference be?
  25. Apr 27, 2019 at 2:40 AM
    #235
    Marshwalker
    Z
    What was your cost on install and parts?
  26. May 4, 2019 at 4:31 PM
    #236
    TundraLaw
    TundraLaw Fourth Year Member
    Northern Nevada
    OTW 22 limited crewmax trd offroad black/boulder
    V nice! About to do the same thing. Do you still have some rake at the 1.3?
  27. May 7, 2019 at 3:07 PM
    #237
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    6112’s finally installed. @ 1.9” with 1 CB shim on the driver side. Rear is still stock. New shoes as well. 18x9 SCS SR8’s in Matte Dark Bronze wrapped in 285/70/18 Nitto Ridge Grappler’s. Truck appears to be slightly nose high to me. Hoping it settles some. I may add Coachbuilder 1” shackles to the rear.
    6940CEAB-675A-4FEC-921D-18080D5807DF.jpg F2A48BE2-D991-4B39-850B-30F21209933C.jpg C72B4986-BC5C-421F-9976-663C6242BFF0.jpg
  28. May 7, 2019 at 3:09 PM
    #238
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Nice setup? Did you have any rubbing? Trim liner? Thanks!
    BigLoggerhead[QUOTED] likes this.
  29. May 7, 2019 at 3:11 PM
    #239
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    How is the difference in the ride?
  30. May 7, 2019 at 3:11 PM
    #240
    BigLoggerhead
    Thanks. Removed the small flaps in the front of the tires and all is good as of now. I have a set of the @Coachbuilder1 bumper shims that will be installed soon.
    Faht Nocker[QUOTED] likes this.
