6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Mar 9, 2024 at 4:56 PM
    #2281
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    What size wheels boss?
  2. Mar 11, 2024 at 5:23 AM
    #2282
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Im running 275/70 18 Bridgestone, Costco special. Great tires and warranty.
  3. Mar 11, 2024 at 9:21 AM
    #2283
    InfernoBoyz
    Reno, NV
    Thank you. Knowing we have the same tire size, it looks like from stock suspension I gained almost 3” front and 3” rear. From TRD pro it’s around .5” front and 3” rear.
    Norfolk757[QUOTED] likes this.
  4. Mar 12, 2024 at 10:44 AM
    #2284
    Norfolk757
    Tom
    Norfolk, VA
    looks bad A$$! I love that color as well.
    InfernoBoyz[QUOTED] likes this.
  5. Mar 13, 2024 at 6:17 PM
    #2285
    InfernoBoyz
    Reno, NV
    I just found a bag of bushings deep in one of the shock boxes of my 6112/5160. would someone mind helping me out with the orientation and location? no paperwork and I re-used the ones I had on the truck.
    I ordered pre-assembled 6112 from Wheelers so I am assuming rear?
  6. Mar 19, 2024 at 1:00 PM
    #2286
    AKMI
    AKMI New Member
    17 CM
    6112/5160, CB +2 shackles.
    Hello, first time posting but long time reader.
    I'm looking into everything I need for the 6112/5160 set up. So far I have the kit order just waiting for it to show up. In the meantime I want to get anything else I will need on ordered.
    Current specs:
    Stock 2017 Crewmax magnetic gray
    Stock TRD off-road rims.
    38 Gal tank
    Measuring from middle of hub to fender:
    FL: 22 FR: 22 1/8
    RL: 23 1/2 RR: 23 5/8
    6112s will be 1.9" (clip #3)
    The my goal is to level the truck and put on 285/70/r18 Nitto ridge grapplers on stock rims.
    So what else do I need?
    -CB .5 shim for front left? Anything on right?
    -Bolt kit for the shim?
    -will I need CB shackles for the rear?
    -UCA's? - I don't think I will need.
    -Tcase drop? - I don't think I will need.
    -what am I missing?
    I drive lots of highways with hunting and fishing trails on the weekends. I don't tow much but I use the truck like a truck.
    I appreciate the help!
  7. Mar 19, 2024 at 1:27 PM
    #2287
    SRQRUSTY
    SRQRUSTY New Member
    Bone stock 2018 Tundra 4X4
    Man, I'm getting ready to install that exact setup except for the stock wheels. I'll be running 18X9 +25s,
    285 70R18 Toyo AT3s, 6112s set at the 1.9 setting, and a single 1/4" CB shim on the driver's side.
    Now I'm curious about the shim bolt kit. I'll be installing it this weekend so I'll keep you posted.
  8. Mar 19, 2024 at 1:29 PM
    #2288
    InfernoBoyz
    Reno, NV
    Just recently did all this for myself.
    - Shims are preference. I did a 2/1 .25 shim on each side which gave me 1” driver and .5” passenger. I have no more tundra lean. You can do 1 driver shim if you wish, you would just end up with less overall lift but it sounds like you want level so no worries there. You wont need a bolt kit if you just do 1, not sure about 2.
    - no need for UCA
    - no need for diff drop
    - cb shackles if you want some rear end lift and more durable shackles. Smallest one is .625” lift. Wouldn’t hurt because once you level the front, you gain some visual sag with any weight in the rear.
    SRQRUSTY and Norfolk757 like this.
  9. Mar 23, 2024 at 1:08 PM
    #2289
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Any issues with alignment on stock UCAs?
  10. Mar 23, 2024 at 1:42 PM
    #2290
    therealjonwick
    JR
    2019 OR
    So what is the reason for doing CB 0.50” shims on the 1.9” lift setting vs just the top setting? Both net 2.5”. Is one better than the other? Thanks!
  11. Mar 23, 2024 at 1:54 PM
    #2291
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Less preload better ride
    I'll be doing 1.9" with a 2/1 shim. And a 3" CB shackle. No UCA (but might do one just because though not necessary)
    Bumper/winch. Full skids. Camp gear/ski stuff/bikes on the back
  12. Mar 23, 2024 at 2:24 PM
    #2292
    therealjonwick
    JR
    2019 OR
    Ah. I was thinking that. Yea I can’t afford UCA’s at the moment. Figure I’ll risk it without them. They will be my first purchase next year. I’m going to do the same set up with the 2/1 shims and +3 cb shackle. Can’t wait.
  13. Mar 23, 2024 at 3:59 PM
    #2293
    therealjonwick
    JR
    2019 OR
    I run 285/65/18 and have no rub on stock lift. 285/65 are wider than 275/70. Once I lift I’ll go bigger when these wear out. But I like the look now. My goal would be 285/70s.
  14. Mar 24, 2024 at 11:39 AM
    #2294
    therealjonwick
    JR
    2019 OR
    You’ve convinced me to go with 1.9 up front. Currently running 285/65/18. Only have about 6k on them so I’ll be waiting a bit to upgrade to 285/70. Prob do rims at that point. The +2cb looks great on your truck. I’m thinking of doing the +3 due to my diamondback cover and panels in the bed. Figure it will have the same look as yours with my added weight. Any issues with tire rub?
    SRQRUSTY likes this.
  15. Mar 25, 2024 at 3:54 PM
    #2295
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    Only a very slight rubbing when backing up and the wheel turned at full lock but it's very minor and negligible.
  16. Mar 25, 2024 at 4:59 PM
    #2296
    therealjonwick
    JR
    2019 OR
    Thanks for the info. You think if I added the shims (2 driver/1 passenger for 2.4” I’d avoid that rubbing?) did you install the kit yourself? Trying to figure out what a fair price for install is.
  17. Mar 25, 2024 at 5:16 PM
    #2297
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You'll have more luck with bumper shims than you will top plate shims if you're hoping to knock out the rubbing in reverse :)
    RobertD and b6graham like this.
  18. Mar 25, 2024 at 5:24 PM
    #2298
    therealjonwick
    JR
    2019 OR
    Good to know! When new tire time comes, I’ll add those to the list haha.
    memario1214[QUOTED] likes this.
  19. Mar 25, 2024 at 5:47 PM
    #2299
    InfernoBoyz
    Reno, NV
    Wondering if I can get a hand with this. I reached out to Wheelers with no response. anybody with a 5160 rear set up can send pics of bushings?
  20. Mar 25, 2024 at 6:52 PM
    #2300
    BigLoggerhead
    I had the bumper shims installed. I still get a feint plastic rub in reverse every once in a while.
  21. Mar 26, 2024 at 5:08 PM
    #2301
    AKMI
    AKMI New Member
    17 CM
    Thanks for the info!
    I ended up calling coach builder and talking with David. Super good dude. I ordered 2 (.5) shims for drivers side and 1(.5) shim for passenger, +2 shackles. No bolt kit needed for up to 2 shims.
    Hopefully I get the 6112s and CB parts in soon and I'll post some before and afters when all said and done.
    SRQRUSTY and InfernoBoyz[QUOTED] like this.
  22. Mar 26, 2024 at 5:37 PM
    #2302
    therealjonwick
    JR
    2019 OR
    Getting ready to order my set up soon. Pricing out shops for install. Many are telling me that due to living in the North East, the lower control arms and eccentrics often seize up and need to be replaced. That adds about +$700 to my kit. Anyone experience this??? Not what I wanted to hear.
  23. Mar 26, 2024 at 6:22 PM
    #2303
    ETexTundra
    ETexTundra New Member
    Glenn
    2021 Silver Tundra SR5 4x4
    Sorry for the major delay but here are my ground to fender numbers. RF = 40 1/4” LF = 39 7/8”. RR = 41 5/8” LR = 41 3/8”
    This is on the 4th setting (highest) Bilstein 6112. I’m also going to remeasure my fender to center of hub again, it’s been a little while since the install.
    COTundra23[QUOTED] likes this.
  24. Apr 10, 2024 at 5:41 PM
    #2304
    b6graham
    b6graham New Member
    has anyone put the updated 5160s on? 25-311365
    @memario1214
  25. Apr 10, 2024 at 7:27 PM
    #2305
    memario1214
    Colton
    Missoula, MT
    Yes. That’s all we've sold/installed for the past year or so. What’s up?
    b6graham[QUOTED] likes this.
  26. Apr 10, 2024 at 7:49 PM
    #2306
    b6graham
    b6graham New Member
    Planning on ordering 6112/5160 this week just haven't seen many posts about the changes
  27. Apr 10, 2024 at 8:40 PM
    #2307
    memario1214
    Colton
    Missoula, MT
    I got you. We also have them on the shelf here at Hotshot Offroad :cool:
    6112 has a new banded piston for more consistent valving - New "super spacers" which are just essentially a new/more robust internal spacer design - The black labelling for a branding change - Body now has a clear coat on it.
    5160 has the same new clearcoat and decal treatment as the 6112s plus - there’s now a billet clamp that affixes the reservoir to the shock body. Some have been shipping with frame mounts for some applications now. The endcap design has changed and fittings have changed. Design change is intended to increase long-term durability against leaking.
    They alluded to some valving changes, but didn't expand on them. Having been around them all I don't notice anything.
    equin and b6graham[QUOTED] like this.
  28. Apr 10, 2024 at 11:21 PM
    #2308
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    does this help?
  29. Apr 22, 2024 at 5:12 PM
    #2309
    AKMI
    AKMI New Member
    17 CM
    I had a busy weekend.
    Installed 6112/5160 setup with 2(.5) CB shims drivers side 1 passenger side.
    CB shackles +2 (1.25) on the rear.
    Powerstops all around.
    And got the tires on today.
    285/70/18 Nitto Ridge Grapplers
    Super happy with this set up.
    Measurements from middle of hub to fenders.
    FR
    Before 22. After 24 3/8.
    FL
    Before 21 3/4. After 24 1/2
    RR
    Before 23 3/4. After 24 3/4
    RL
    Before 23 1/4. After 24 3/4
  30. Apr 22, 2024 at 5:32 PM
    #2310
    therealjonwick
    JR
    2019 OR
    Looking good! What height setting on the 6112’s?
