6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Sep 17, 2022 at 6:55 AM
    #2071
    SAGE63
    San Diego County
    Got ya shipping from San Diego might not work.
  2. Sep 22, 2022 at 8:55 PM
    #2072
    SAGE63
    San Diego County
  3. Sep 24, 2022 at 11:29 AM
    #2073
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
  4. Oct 24, 2022 at 8:58 PM
    #2074
    TRD77
    TRD77 New Member
    2020 TRD Sport
    The truck looks awesome. I’m going for a similar set up. What setting are the 6112’s at? Any rubbing? Did you do any cutting or chopping? Do you have any pictures of the poke? Thanks.
  5. Oct 24, 2022 at 9:22 PM
    #2075
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Bilstein 6112’s & 5160’s
    Sitting on 6112's (top notch) and 5160's w/a Deaver add-a-leaf sandwiched in the OEM leaf pack. Factory UCA's, no diff drop or shims needed. I have the OEM Rock Warrior wheels w/35x12.5r17 Toyos. I really like this suspension. The ride is firm and but not too firm. It's great on the street and better than stock off-road. I have owned Kings on a previous Tacoma, and those are significantly better (yeah, no shit). I would like to upgrade to Kings eventually. However, I believe coming down one notch on the front coils and upgrading front/rear bump stops to Timbrens would do wonders for the ride quality while off-road.
    I also have this theory I would like to play out.....swap the 6112's & 5160's for a set of new TRD Pro Fox Shocks. My gut tells me it would be smooth as butter off-road with a set of Timbren bump stops. I could be wrong...
    Kiddnapped Tundra and pvn.beluga like this.
  6. Oct 28, 2022 at 2:54 PM
    #2076
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    Beautiful set up and nice wheels! What is in the center of your RW wheels?
    AZEric[QUOTED] likes this.
  7. Oct 28, 2022 at 7:19 PM
    #2077
    thedonn
    thedonn New Member
    Just removed the mudflaps and installed bumper spacers by coachbuilder. i am pretty sure the fronts are at +1.9. offset is crucial
  8. Oct 29, 2022 at 8:47 AM
    #2078
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Thanks! Nothing, I removed the center caps. The caps were faded, peeling, and just a mess. Gonna paint them sooner or later and throw them back on.
  9. Oct 31, 2022 at 10:35 AM
    #2079
    jhacker1
    jhacker1 New Member
    2019 White OR
    So my truck is sitting on third setting (1.9) 2 spacers on the drivers side, 1 on the passenger. 5100’s in the rear with CB +2 shackles. I’m still a 1/2 inch lower on the drivers side. Anybody got an idea as to why?
  10. Nov 1, 2022 at 7:02 AM
    #2080
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Maybe it has something to do with the rear lift and the effect on geometry? I have driver side at 1.9 and passenger at 1.3 - no rear lift and it is level. No issues with the staggered setting that I can tell.
  11. Nov 1, 2022 at 1:55 PM
    #2081
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I don't think it's recommended to have both sides at different heights. The reason why the driver side adds the shims are to compensate for the gas tank and heavy battery...
  12. Nov 2, 2022 at 6:42 AM
    #2082
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Thanks. Yes I have heard that as well. Initially I had both sides at 1.3 setting; after alignment and settling I had a lean so instead of shimming I had the drivers side bumped to 1.9. I have had it at these settings for a few years with no issues. Rides good, level, aligned well. When I purchased the shocks I also purchased 3 Coachbuilder shims and +2 shackles- Never ended up using those. Had some solid guidance from Dirty Deeds and spoke wit Accutune. I believe the Bilstein for the Tacoma are designed to be staggered- not a 100% on that. The plan is go Fox or Kings when these are spent and adjust accordingly.
  13. Nov 4, 2022 at 11:18 AM
    #2083
    GreenGrandpa21
    GreenGrandpa21 New Member
    Derek
    2021 TRD Sport 4x4 Army Green
    Barricade running boards Bakflip MX4 with Bakbox Have 6112/5160 with a host of Coachbuilder parts ready to install Anthem Viper 18x9 0 offset 35x12.5 Yokohama Geolandar G015
    00B17FE4-439E-4C6D-B3F1-E6A367D9CEF1.jpg Have been running my setup for about 6 months now and absolutely love it. 6112’s set at 1.9 with a CB shim on the driver’s side. No lift in the rear with 5160’s. Running Anthem Viper 18x9 0 offset wheels with 295/65r18 Duratracs. No body mount chop. Just had to heat mold the mudflaps a bit and the bumper plastic. The tiny bit of rub still left is hardly noticeable.
  14. Nov 4, 2022 at 1:25 PM
    #2084
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    Every time I see Army Green I go all jizzy! Love that color, just looks so ferocious your truck!!
  15. Nov 19, 2022 at 6:16 AM
    #2085
    Robster80
    Robster80 New Member
    Is it pretty much level or do u still have a slight amount of factory rake with that setup?
  16. Nov 19, 2022 at 2:52 PM
    #2086
    TRD77
    TRD77 New Member
    2020 TRD Sport
    Just installed 6112s top setting and Falken Wildpeak AT3 on MR 316. Slight rub on mud flaps so they’re gone now. Gained some height and lost MPGs- Love hate relationship but I’m digging it.
  17. Nov 19, 2022 at 4:26 PM
    #2087
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    I'm kind of doing something like that, 6112s on the front with some Eibach coils (I know they aren't supposed to fit... I figured out a way) and some TRD Pro fox rear shocks... I'd love to slap timbrens on them, but they're so dang expensive considering you need to buy 2 sets for just the front
    SAGE63 likes this.
  18. Nov 19, 2022 at 6:04 PM
    #2088
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    Anyone went from 5100 to 6112?
    is there a huge difference in ride quality?
  19. Nov 22, 2022 at 10:39 AM
    #2089
    SAGE63
    San Diego County
    What are you doing to make them fit?
    joseph_womack[QUOTED] likes this.
  20. Nov 22, 2022 at 1:18 PM
    #2090
    joseph_womack
    Joe
    Louisiana
    trimming the rubber around the top hat to the coilovers, this should allow them to fit, haven't tested it just yet, parts are still sitting on my workbench
    SAGE63[QUOTED] likes this.
  21. Nov 22, 2022 at 1:19 PM
    #2091
    joseph_womack
    Joe
    Louisiana
    I'm gonna post pics when I do it, alternatively, you could also actually grind down the inside of the coilover and remove some metal
  22. Nov 22, 2022 at 2:01 PM
    #2092
    SAGE63
    San Diego County
    I thought about doing that too but the guy I was working with was nooooooo. you will end up with metal on metal... not good. anyway
    .02.. good luck
  23. Nov 22, 2022 at 4:48 PM
    #2093
    joseph_womack
    Joe
    Louisiana
    theres actually a decent amount of clearance if removing the rubber on the wall of the cap and not the top, you could either trim it down, or cut it off and maybe then wrap in electrical tape... you shouldn't run too much issue of metal on metal because the gap on either side should be about 1/8"+ if I remember right
  24. Nov 28, 2022 at 11:42 AM
    #2094
    TundraRyan
    TundraRyan New Member
    2014 Crew Cab TSS
    Stock
    the stance and look with the 18's I'm looking for! This truck looks like it can do work. not a pavement princess. I got my 34" but on my 20's and my 6112's going on tomorrow.
  25. Dec 8, 2022 at 12:32 PM
    #2095
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    I keep going back and forth on what I'd like to do with my truck. Anybody have any input or pics on how a crewmax 4x4 would look with 6112s at the third clip (1.9 inches) and Icon add-a-leaf pack (1.5 inches) in the rear and 285/70R17 tires?
  26. Dec 16, 2022 at 7:56 PM
    #2096
    Boomx2
    Boomx2 New Member
    K.
    2018 Quicksand CM
    It'd look like this
  27. Dec 17, 2022 at 10:26 AM
    #2097
    DFW
    2021 Limited 4x4
    I appreciate it! Truck looks great by the way. Did you end up messing around with a diff drop?
    ryanwgregg likes this.
  28. Dec 17, 2022 at 9:52 PM
    #2098
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    Anyone got pics of 6112 top setting and 5160 with a 1” shackle in rear ?
  29. Dec 18, 2022 at 12:35 PM
    #2099
    Boomx2
    Boomx2 New Member
    K.
    2018 Quicksand CM
    Thanks! No diff drop. But I’m sitting on 285/75r17 and I experienced rubbing on full turn for both front tires. I had to remove the front mud flaps and use a heat gun to push the front plastic forward a bit. Hope this helps
  30. Dec 19, 2022 at 10:38 AM
    #2100
    JJcksn12
    JJcksn12 New Member
    Jay
    6112 top setting no shims
    5160
    Toytec shackle top setting
    18x9 method NV +25
    29570R18 Falken Wildpeak AT3W
