6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jul 13, 2022 at 6:37 PM
    #2041
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    Thanks man, I like that a lot!
    ShinyConcretE[QUOTED] likes this.
  2. Jul 20, 2022 at 1:15 PM
    #2042
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    I can finally add to this thread. I have been running my Tundra for the last 5 years with stock suspension and 275/70R18 Cooper Discover XLT’s.
    This week I installed 6112 set at 1.9” (no spacers, only a 1/8” difference between sides) and 315/70R17 Cooper Discover XLT on Vision 17x9 12mm offset (thanks king.cong.1119 !).
    I had to remove the mud flaps on the front and back of the tire and the inner wheel wheel liner that covers the back of the fog light. I didn’t need to but I trimmed a bit out of the bottom edge of the front bumper.
    An unexpected thing is that I actually got 2.25” of lift from the 6112’s. Now it looks a little nose high maybe.
    king.cong.1119, equin and FISHN43 like this.
  3. Jul 20, 2022 at 7:12 PM
    #2043
    deepimpact
    deepimpact New Member
    David
    Suffolk, VA
    2020 Tundra TRD Sport Crewmax
    Billstein 6112/5160 @1.9” TRD Pro Front Skid Plate Go Rhino RB20
    An afternoon with 4 cans of plastidip! :thumbsup:
    Next set of tires I’ll probably
    • Add .25” spacers on top of my 6112s, move them to 2.5” settings
    • Add +1.5” Coachbuilder shackles in the back
    • Change wheels to 18” and move up to a 34” tire
  4. Jul 20, 2022 at 7:15 PM
    #2044
    deepimpact
    David
    Suffolk, VA
    Congrats and nice setup! Mine was nose high until I got a professional alignment and then a month of driving to get it to settle. The tundras lines also contribute to looking nose high!
    Uturn09[QUOTED] likes this.
  5. Aug 7, 2022 at 10:16 AM
    #2045
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Does this setup give you some rake ? I currently have 6112 at 1.9” and plan to add the CB shim on both fronts for .50” lift and CB +1 shackle in the rear to be level. Any other suggestions with this setup ?
    nowayout[QUOTED] likes this.
  6. Aug 8, 2022 at 2:52 PM
    #2046
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    Finally got around to ordering and installing my 6112/5160s at 3rd clip (1.9") setting since they came back in stock. I also installed the Roadmaster Active Suspension. I ended up purchasing the Bilstein remote reservoir mounts because the hose clamps that came with the 5160s broke on me...
    I forgot to do a before/after measurement, but I'm not too concerned because I like the ride. Still riding with the stock tires since they have plenty of tread left.
    GELCW, COTundra23 and Skew12 like this.
  7. Aug 8, 2022 at 3:02 PM
    #2047
    Uturn09
    Uturn09 New Member
    Roscoe
    Did you do the standard or heavy duty RAS?
  8. Aug 8, 2022 at 3:18 PM
    #2048
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    I got the HD. I wanted a little bit of ride height increase from it so opted for the heavier one. I used a quarter for the adjustment spacing after I read about it being a good medium between the spacers they provide.
  9. Aug 8, 2022 at 3:38 PM
    #2049
    Uturn09
    Uturn09 New Member
    Roscoe
    Did you add it the same time as the shocks and or can you tell what the difference the Ras made on ride quality?
  10. Aug 8, 2022 at 4:11 PM
    #2050
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    I added it at the same time as the shocks. I haven’t hooked my boat up or loaded anything so I can’t tell how it does with some weight on it.
    However, my overall impression is that it rides more smooth and controlled than stock. I was a little surprised because I thought the ride would be a little stiff after the upgrades. It’s kind of hard to describe but when I’d hit a bump or pot hole with the stock suspension, it would seem like I could feel the suspension shuttering. With the RAS and Bilsteins, it seems forgiving and doesn’t have the same jarring feeling.
  11. Aug 11, 2022 at 6:28 PM
    #2051
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Yep gives seem rake. Im still enjoying it 50k miles later. But you need the +2 shackle to get where I am with rake.
  12. Aug 11, 2022 at 7:18 PM
    #2052
    Tundra694
    AJ
    I actually want it level so that’s why I was curious how yours was. In theory the plus one I have should be level then. Good to know it’s still workin good 50k later
  13. Aug 11, 2022 at 9:01 PM
    #2053
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Did you say rake?
  14. Aug 22, 2022 at 10:54 AM
    #2054
    Steveward
    Steveward New Member
    After reading all 69 pages of this thread i'm finally pulling the trigger. Probably the biggest help was calling David @Coachbuilder1 who was SUPER helpful and willing answers to several of my questions. I'll provide before and after photos at somepoint.
    2018 Tundra Limited:
    Bilstein 6112 set @ 1.9 w/ 5100 in the rear.
    2 Driver side Coachbuilder shims (0.5 inch).
    1 Passenger side Coachbuilder Shim (0.5inch).
    +2 Shackle in the rear.
    Coachbuilder Front Bumper Shim Kit
    Looking to fit 275/65/R20 Open Country ATIII's with 20 offset.
    GELCW likes this.
  15. Aug 30, 2022 at 11:19 PM
    #2055
    Uturn09
    Uturn09 New Member
    Roscoe
    Now I have added the RAS Heavy Duty. I like the rake better and the ride quality is a lot better!
    Savmikey47, frichco228, equin and 2 others like this.
  16. Aug 31, 2022 at 5:56 AM
    #2056
    mustangr2
    mustangr2 New Member
    Curious did this setup help with the so-called bed bounce?
  17. Aug 31, 2022 at 7:25 AM
    #2057
    Uturn09
    Uturn09 New Member
    Roscoe
    I never had that issue so I’m not sure.
  18. Aug 31, 2022 at 8:00 AM
    #2058
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    +25 is the magic number on wheels,
    I think bed bounce is rear shocks are too soft for the spring
  19. Sep 2, 2022 at 2:54 PM
    #2059
    jaflynn738
    jaflynn738 New Member
    Finally finished my project. Bilstein 6112 on top setting and 2in shackle in the rear. 18x9 +18 Gear Off-Road wheels and 295/70/18 Nitto Ridge Grapplers. Tires did rub the front wheel well, so I just removed it and I may add the shim to the bumper and try to put them back on later. IMG_7510.HEIC.jpg
    IMG_7531.jpg 68382376393__3D84CED7-EE12-4DE6-B3FF-FAE6E34169C3.HEIC.jpg 68382375261__D51D29E5-F22E-4E78-A018-0B273F75E0BD.HEIC.jpg
  20. Sep 7, 2022 at 8:24 AM
    #2060
    SAGE63
    San Diego County
    hey all.... love my 6112/5160, +3 cb shackles, 2d 1p CB shims and westcott preload coller (have the never installed westcott shims also).
    I moving to an ICON 3.0 coilover and 2.5 omega rear set up due a change in how I am using the Tundra. So I will be listing current setup soon. appx 15k miles on it. So stand by for the FS notice in a few weeks.
  21. Sep 7, 2022 at 8:49 AM
    #2061
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    6112 is out of stock everywhere…
  22. Sep 7, 2022 at 9:55 AM
    #2062
    jhacker1
    jhacker1 New Member
    2019 White OR
    I bought mine from 4 wheel parts on Sept 4th. They will be here Friday.
  23. Sep 7, 2022 at 8:22 PM
    #2063
    jaflynn738
  24. Sep 7, 2022 at 9:42 PM
    #2064
    king.cong.1119
    king.cong.1119 New Member
    Front at 6112 and rear with CB+2 for me and they seem level, with ur additional spacer and only cb+1 I’d think it would be nose high
  25. Sep 7, 2022 at 9:45 PM
    #2065
    king.cong.1119
    Very nice. How was the install of the RAS? Did you have cb shackles in the rear?
  26. Sep 8, 2022 at 2:14 AM
    #2066
    Uturn09
    Uturn09 New Member
    Roscoe
    The install was easy. Hardest part was getting the truck blocked up so that the rear axle was free hanging. I am still using the factory leaf springs and shackles.
  27. Sep 16, 2022 at 9:55 PM
    #2067
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Going back and forth on a couple things and would appreciate input from the group. As soon as I can get my hands on them I will be installing 6112s at the 1.9” setting. I’ve got some 17” Icon Vectors (+25) that I’d really like to go either 295/70 or 285/75. Do you think I’d have issues with clearance on either?
  28. Sep 16, 2022 at 10:01 PM
    #2068
    SAGE63
    San Diego County
    I am on +25 18 methods with 295/70 lose the mud flaps and a little heat push to the front liner or a 3/8" to 1/2 " bumper shim... where are you located I have some takeoff 6112/5160 etc.
  29. Sep 17, 2022 at 4:19 AM
    #2069
    king.cong.1119
    not at all
  30. Sep 17, 2022 at 5:37 AM
    #2070
    DFW
    2021 Limited 4x4
    I’m in Fort Worth
