6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Feb 3, 2022 at 8:40 PM
    #1981
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    Looks amazing! Are you on stock UCAs? And no BMC?
  2. Feb 4, 2022 at 5:12 AM
    #1982
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    Icon UCAs, and I do have a BMC. Thanks!
    Mfanatic22[QUOTED] likes this.
  3. Feb 11, 2022 at 3:44 PM
    #1983
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    This is beautiful. I'm waiting for 6112's to show up and want to go 1.9. I currently have BFG ko2 285/65r18 on stock suspension. Will definitely want to bump up for the next set. nice to see your set up and know that its not super complicated to get 295/70's on there.
  4. Feb 22, 2022 at 7:14 AM
    #1984
    Torgo Nudho
    Torgo Nudho New Member
    Kyle
    California
    '18 CrewMax Sport 4X4
    No modifications so far... that's why I'm here.
    Has anyone ran Deaver AAL with a 6112/5160 setup? I bought 6112/5160 last year in November with a set of Deaver AAL. This was recommended by Cali Raised Off-road to maintain the rake on top setting (2.5”). I’m supposed to get my SCS Ray10’s in tomorrow and plan on going down to 4WP this weekend for the install of everything. The goal is to maintain factory rake, but I’ve yet to see any builds with the 6112/Deaver AAL. Anyone have pics of their trucks with those installed?
  5. Mar 3, 2022 at 2:41 PM
    #1985
    Navi
    Navi New Member
    2019 CrewMax Limited
    I can't find anyone that has 6112/5160 in-stock right now. Can anyone suggest a source or another place I should be looking? Don't really want to go with another product. Someone tried to tell me to go with 5100s but i don't want to do that.
  6. Mar 3, 2022 at 3:24 PM
    #1986
    thedonn
    thedonn New Member
    I was in the exact same situation - no one has them. I found a guy on here with some used ones - actually new in box he just never insta
    lled them . it was a little risky but the pics were indeed neew and he came through
    Navi[QUOTED] likes this.
  7. Mar 3, 2022 at 3:31 PM
    #1987
    tonynw318
    Tony
    Oregon coast
    I’m trying to go through a shop in the area. Put money down on some 5160s they had in stock and just spending eternity waiting for 6112s to come in and my turn on the list. Guy said Bilstein won’t give them much indication when or how much stock is coming, it will kinda just show up. Either way, I’m willing to wait for what I want at that price point.
  8. Mar 3, 2022 at 5:25 PM
    #1988
    Navi
    Navi New Member
    Yeah, normally I would wait too. Like you said, price is right but i need tires real bad. i'm practically bald at this point
  9. Mar 3, 2022 at 5:26 PM
    #1989
    Navi
    Navi New Member
    you like them? pretty good upgrade over stock? what wheel/tire combo did you get?
  10. Mar 3, 2022 at 6:12 PM
    #1990
    thedonn
    thedonn New Member
    I like them a lot. i did 18x9 +25 mm Methods w 295 70 18 Falken AT3
  11. Mar 3, 2022 at 6:19 PM
    #1991
    Navi
    Navi New Member
    Looks great
  12. Mar 8, 2022 at 7:16 AM
    #1992
    Kajunxplorn
    Kajunxplorn New Member
    2021 Silver Limited CM TRDOR
    I recently purchased a 2021 CM TRDOR, and I'm looking to level the truck. I've been researching lifts for the last couple of weeks and decided to go with the 6112/5160. And, I came across this thread last night and read a countless amount of replies.
    I'm looking to install the 6112 kit in the front on the 1.9 setting with either 1 or 2 coachbuilder shims on the driver side (for the known leaning issues on the driver side) and either none or one on the passenger side. And, I would install the 5160 shocks in the rear with the coachbuilder +1 shackle (for eliminating side flex, bed hop and strength for towing) or a greasable shackle. I don't plan on changing the control arms if necessary and trying to stay under 3 inches of lift to avoid any caster issues.
    I'm leaning towards the newer TRD Pro BBS wheels to maintain the stock look if I'm able to run them with either 33 or 34 inch BFG A/T or their Trail terrain tires (metric size) without rubbing. If not, I'll go with either the fuel or methods that don't stick out pass the fenders too much.
    My main usage for the truck would be towing about a +/- 4500 lb boat about 200 miles a few times a month during the summer and fall and off roading on light to moderate trials from time to time. My main concern would be using the truck for towing more than anything and not loading too much power from the larger tires going up steep inclines.
    Any suggestions would be appreciated
    DgoTss likes this.
  13. Mar 8, 2022 at 7:41 AM
    #1993
    Okierunner
    sometimes that “lean” is overblown, mine has no lean with no shims. I don’t understand putting shims in the front with the bilstein not in the top setting, just seems like unneeded extra parts to me. If you think you want 1.9 plus shims in the front I’d just put em all the way up. The rear shackle and rear height is just for the stance you want, unless you do beefier leaves it’s not changing much other than ride height.
    a lot of people overthink these bilstein setups, it’s basic stock geometry with a little higher ride height, just set it at the amount of lift you want and roll.
  14. Mar 8, 2022 at 8:06 AM
    #1994
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    One of the best resonses in this whole thread. :thumbsup:
  15. Mar 8, 2022 at 8:51 AM
    #1995
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    I'm running 6112s up front on the top setting and 5160s w/Resi's in the rear. Tire Setup is 275/70/18 Discoverer AT3 with a Black Rhino York Matte Gunmetal wheel 18x9 -12mm!
  16. Mar 8, 2022 at 9:31 AM
    #1996
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Unlike the lucky guy that had no drivers side lean at all my truck had nearly a full inch of lean. It was pretty annoying having 1" of lift on one side and 2" on the other. I initially had two shims on the drivers side but was uncomfortable with the very little thread remaining for the nuts on the top. I am now 1.9" setting with one shim drivers and none passenger and I think that's pretty perfect. You would probably be happy having a +1 Coachbuilder shackle on the back but it really is all personal preference. If the bilstein 6112 isn't in stock my friend has the Eibach pro adjustable Coilovers for about the same price I think they are just as good if not slightly better.
  17. Mar 11, 2022 at 5:45 AM
    #1997
    Ronsofury
    Ronsofury New Member
    I have a noob question.. If I go 5160 can I still install CB+3? It seems alot of ppl are doing it but on paper the CB+3 provides 1.75" lift but 5160 only allows for 0-1.5" lift. how does it work?
  18. Mar 11, 2022 at 4:27 PM
    #1998
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Yea you shouldn’t have any problems with the CB +3. I probably have 2.5” rear life with my 5160 and it’s no problem
    Ronsofury likes this.
  19. Mar 11, 2022 at 7:30 PM
    #1999
    thedonn
    thedonn New Member
    +1.9 front , rear 5160 with Roadmaster Active HD suspension at +25% for +.75 rear
    295 70 18 Falken AT3 on Method +25 offset
  20. Mar 11, 2022 at 8:04 PM
    #2000
    Ronsofury
    Thats the setup I want! I am drooling.... :cheers:Looks like you got 1" front bumper shim, or is that 0.5"? removed mud flaps, stock UCA no CMC? I thought 295 falkens maybe too wide for 1.9" lol
  21. Mar 12, 2022 at 4:15 AM
    #2001
    thedonn
    thedonn New Member
    exactly right - flaps removed and no BMC but the offset plays a big role. I used the coach builder shims and I would be surprised if they totaled much more than .5"
    tonynw318 and Ronsofury[QUOTED] like this.
  22. Mar 29, 2022 at 6:08 PM
    #2002
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    Finally got shipping confirmation on my 6112s, so hopefully in the next few weeks I’ll be able to get the 6112s, 5160s, coachbuilder shackles, and bumper spacers put on
  23. Mar 29, 2022 at 8:37 PM
    #2003
    Torgo Nudho
    Kyle
    California
    6112/5160’s with a Deavers AAL
    285/75r18 Geolandar X-AT (G015)
    SCS Ray10’s, +25 offset
  24. Mar 29, 2022 at 8:40 PM
    #2004
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    2021 Tundra Limited MGM TRD Off Road DC
    Vehicle Modifications:
    I really want to go 285 75 18 but the gas mileage is scarring me,
  25. Mar 30, 2022 at 6:52 AM
    #2005
    tgsfire
    tgsfire New Member
    2014 Toyota Tundra
    Where did you order them through?
  26. Mar 30, 2022 at 10:23 AM
    #2006
    Bo Dangles
    Jesse
    Canada
    Tdot Performance, in Ontario. Ordered them at the end of June last year.
  27. Apr 10, 2022 at 9:33 AM
    #2007
    Trstno1
    Trstno1 New Member
    Brent
    2021 cavalry blue SR5 w/TRD Offroad
    None
    How did you mount those raptor lights?
  28. May 17, 2022 at 2:37 PM
    #2008
    Bo Dangles
    Jesse
    Canada
    After a long wait I finally got my 6112/5160 kit installed yesterday. Have the fronts set at 1.9” with one 1/4” coachbuilder shim on the drivers side. The shop apparently broke their ball joint press trying to remove the old bushings, so the coachbuilder +2 shackles will have to wait a couple weeks until I can give up the truck again. Overall pretty happy with the ride so far, and it’s relatively level as it currently sits, but looking forward to a little extra rake. The tires are 275/60r20 Goodyear wrangler duratracs on stock 20s, but will be upsizing to a 275/65r20 when the tires wear down or I come into a little extra cash.
  29. May 20, 2022 at 8:37 AM
    #2009
    Rivulose
    Rivulose New Member
    Looking to see if anyone's got a similar setup to what I'm wanting to do or has some experience with lifts and suspension.
    Ordered a pair of 6112 planning on setting to 1.9 or second off the top setting. A single coach builder shim on the driver side so eleviate some lean going on. Stock Bilstein 4600 shocks in the rear with coach builder +3 shackles.
    Looking to have some forward rake and not breaking the bank to have a near 2 inch lift.
    Thanks for the input and help
  30. May 20, 2022 at 9:11 AM
    #2010
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    6112s top setting up front ... 5160s in back with Toytec shackles @ 1" setting. 285/75/17 KO2s. Had to bend in the corners of the skid to prevent rubbing at full lock.
