6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Sep 14, 2021 at 3:18 AM
    #1891
    pursuit2550
    pursuit2550 New Member
    Then why not just go to the next notch which is 2.5 and no need for shims. My truck didn’t have the lean, so I didn’t do shims. In the end it came out perfect and did 1.5” in the rear.
  2. Sep 14, 2021 at 6:41 AM
    #1892
    COTundra23
    COTundra23 New Member
    Every truck is different.. I know my had the lean so I used the shims. While I only ever ran mine at 1.9", some users have said that maxing the shock out at 2.5" takes away from ride quality and travel.
  3. Sep 14, 2021 at 6:45 AM
    #1893
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    People have said the ride is rougher at 2.5 and it will strain your axles a little more. Even with my shocks at 1.9 and the .5 shims I had to go to two alignment shops for them to get the alignment right.
  4. Sep 14, 2021 at 6:48 AM
    #1894
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Correct! I have Coachbuilder +2 shackles on the rear and with my airbags with a 10 psi minimum I'm at 25.5 inches from fender to center of rim in the rear and 24.5 inches from fender to center of rim in the front.
    Just got 285/75/18 Falken Wildpeak AT3Ws put on yesterday. Had to cut the skid plate last night, remove the front flap, and I still got some rub on the driver's side mudflap I have to figure out what to do with.
    Pictures this weekend once I'm able to wash the truck!
  5. Sep 14, 2021 at 6:49 AM
    #1895
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Darren with Boss 4x4 was where I got mine. They had them to me within 1 week even with assembling them as well. He also sells shims on their website.
  6. Sep 14, 2021 at 7:42 AM
    #1896
    CamV.
    CamV. New Member
    CamV.
    2018 Tundra SR5
    Black decals, all weather mats
    How did you get these black? Did you buy them that way or get them dipped, etc?
  7. Sep 14, 2021 at 9:58 AM
    #1897
    pursuit2550
    I actually like the ride now better than stock. Stock it feels to much like a cushiony/spongy felling. I have mine set at the 3rd notch which is 2.7” for the 4x2. I am running 33” tire at 45psi and did the rear TRD sway bar. I feel it’s more rough in the sense that the small holes are felt more but when going on the expressway and not having the truck bouncing up and down like the stock suspension, it’s way better for me. I have a speed bump at the entrance to my job. With the stock suspension the front would bounce and so did the rear. No it’s absorbs the speed bump and no bounce. The way a truck suspension should work, keeping the wheels planted to the ground and not bouncing. Sucks about your alignment. We have a shop down here that the guy knows what he’s doing. I asked him at what specs he puts the tundras on and he told me exactly what everyone in here says they should be at. He said he’s don’t plenty of Tundras out of the factory with messed up alignment. Well like put it, aligned to Toyota specs but not the correct specs.
  8. Sep 14, 2021 at 12:43 PM
    #1898
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    same thing I did - 6112's on the top notch, Icon AAL in the rear. sits mostly level, I think the back is < 1/4" higher than the front.
    imo, 2.5 isn't too rough, but maybe it's relative. I used to have a '14 Tacoma with a full Icon lift and AllPro Expo springs and that was waaaay rougher than the Tundra 6112's @ 2.5. what was off on your alignment to have to get it redone twice?
  9. Sep 15, 2021 at 11:36 AM
    #1899
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Well got around to running it through a car wash last night, so here are some pictures. I cut a few inches off the skid plate, and been trimming the far corner of the mudflaps as I drive around and hear/feel any rubbing.
    Front raised 2.5 inches
    Rear raised 1.5 inches with minimum air in airbags
  10. Sep 15, 2021 at 9:40 PM
    #1900
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Just got my order for my 6112/5160’s. I requested and paid extra to have the Circlip put at the #3 (1.9) setting. When I got the shipment today it appears as though they are at the #4 (2.5) setting. Just so i can confirm I’m not a dumbass, is this on the #4 setting?
  11. Sep 15, 2021 at 9:52 PM
    #1901
    AZBoatHauler
    So.Arizona
    You may or may not be a dumbass - but that is definitely the 4th (highest) setting. :D
  12. Sep 16, 2021 at 1:30 AM
    #1902
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    any pics of what you cut and how much? I want to go to either 295/70 or 285/75 on my ray10's.
  13. Sep 16, 2021 at 6:56 AM
    #1903
    DanTundra
    DanTundra Danny
    Wilmington, NC
    What is the offset on your ray10's? Mine are the TRD rims which are a +60 offset so you may not have to cut as much. On the skid plate I took a cutting wheel and cut about 2 inches off of each "wing" on the factory skid plate.
    The mud flaps I took my multi-tool which has a saw blade and just started cutting the rear corner of the mudflap. Drove around and felt more rubbing so I cut some more. I had to cut some more after this picture, but it will give you an idea of where I was rubbing on both sides.
    kuokoa[QUOTED] and kleiker0303 like this.
  14. Sep 17, 2021 at 10:48 AM
    #1904
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    6112s @ 1.3 and TRD Pro rims with Ridge Grappler 275 70 18s. 5160s on the rear.
  15. Sep 17, 2021 at 11:06 AM
    #1905
    AZBoatHauler
    So.Arizona
    BoxersBrew[QUOTED] and Barrett50 like this.
  16. Sep 17, 2021 at 5:51 PM
    #1906
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    they're +25.
  17. Sep 19, 2021 at 1:52 PM
    #1907
    COTundra23
    Anyone have hub to fender measurements for the 2.5” setting?
    thanks!
  18. Sep 19, 2021 at 1:56 PM
    #1908
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    I think mines is 24-1/2", center of hub to fender (no shims). fwiw, I also have Icon AAL's in the rear (25" hub to fender).
    COTundra23[QUOTED] likes this.
  19. Sep 19, 2021 at 1:58 PM
    #1909
    COTundra23
    excellent. Thank you!
    kuokoa[QUOTED] likes this.
  20. Sep 22, 2021 at 6:08 PM
    #1910
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Went to install my front assembly and when I placed the coachbuilder shims on the top, I noticed that they don’t sit flush. Is this normal?
  21. Sep 22, 2021 at 7:29 PM
    #1911
    Zachp
    Zachp New Member
    Zach
    2016 tundra SR5 TSS 5.7
    6112 at top setting
    1” toytec shackle in back
    Running 35x12.18 Bfg ko2
    trimmed off the front bumper end caps to clear space-
    No diff drop
  22. Sep 22, 2021 at 8:56 PM
    #1912
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    are those stock upper shock mounts? curious, cause I was about to order these and my 6112's reused the factory uppers.
  23. Sep 23, 2021 at 6:53 AM
    #1913
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Well I’m guessing that they are aftermarket since CB said they’ve never had a problem with factory uppers. They are what came from wheelers off-road. I’ll probably just end up grinding the inside of them down until they clear and fit flush. No not deal.
  24. Sep 29, 2021 at 10:11 AM
    #1914
    amjonesy27
    amjonesy27 New Member
    Atlanta, GA
    2020 CM Platinum
    Retrax Bed Cover
    Finally settled on 6112 setting for up front and they aren't available anywhere. Anyone heard of timing to get things back in stock??
  25. Sep 29, 2021 at 12:49 PM
    #1915
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    did you try Wheeler's? they don't have any messages saying it's out of stock or backordered, so maybe they have some in stock?
  26. Sep 29, 2021 at 3:56 PM
    #1916
    amjonesy27
    Atlanta, GA
    2020 CM Platinum
    Retrax Bed Cover
    Website said yes, phone call confirmed no, out of stock :(
  27. Oct 4, 2021 at 5:48 PM
    #1917
    tundrafez
    tundrafez New Member
    fez
    Massachusetts
    2001 3.4 v6 manual - 2017 tundra trd off road 5.7l
    I ordered some from wheelers back at christmass , just received them about a month ago. Maybee they didnt get a huge shipment ?
  28. Oct 5, 2021 at 2:16 PM
    #1918
    amjonesy27
    Atlanta, GA
    2020 CM Platinum
    Retrax Bed Cover
    Christmas and you just got them?? Wow...still waiting on the email from Shock :fingerscrossed:
  29. Oct 7, 2021 at 10:37 AM
    #1919
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I guess I got crazy lucky, local 4 Wheel Parts had 6112's in stock. 5160's and Bilstein UCA's took about 3 days to get from them, too.
  30. Oct 15, 2021 at 1:18 PM
    #1920
    Buytheballs12
    Buytheballs12 New Member
    James
    2014 Grey Tundra 1794
    Working on the lift and tires now
    Has anyone had an issue where the swag bar is not connecting after bilstein are install in the front? Mechanic is working on my truck now and getting that issue
