6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jul 29, 2021 at 8:30 PM
    #1831
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Hopefully the last update. The rubbing continued, so I took the mud flaps off. Continued rubbing some more til I figured out it was rubbing the passenger front bumper. About a year ago my wife had accidentally hit another car and dented the front bumper ever so slightly inward - just enough to cause that tire to rub. I pulled it out using arm strength and no rubbing anywhere now, even while doing some mild off-roading in Colorado.
  2. Jul 30, 2021 at 10:11 AM
    #1832
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    (I know this is random) how thick are the washers? Is that thickness for a 3” lift?
  3. Jul 30, 2021 at 3:00 PM
    #1833
    pursuit2550
    pursuit2550 New Member
    I haven’t installed it yet so I haven’t looked at the instructions. I am not home so I can’t measure them but I would say they are between 1/16-1/8 inch thick. I am sure Bilstein has instructions online.
  4. Jul 30, 2021 at 5:27 PM
    #1834
    joseph_womack
    Joe
    Louisiana
    I just went ahead and ordered some extensions for a 2-4" lift, thanks!
  5. Aug 3, 2021 at 12:06 PM
    #1835
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Ok so after reading damn near every page, I’ve decided I’m going to be going with the 6112/5160 for my 2017 Crewmax.
    I want to run 285/75/18 or 295/70/18 on (stock TRD wheels for now)
    my plan is run the fronts at 1.9 with a .50 CB spacer on the driver side and a .25 CB spacer on the passenger side.
    aftermarket UCAs (undecided which brand yet)
    I also plan on adding the CB front bumper spacer to help with front clearance.
    For the rear I was thinking of going CB+1
    sound about right to everyone, or will that tire size be an issue? I’m open to running wheel spacers as well if need be.
  6. Aug 3, 2021 at 1:06 PM
    #1836
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    Tire size will probably push the limits with +60 (stock) backspacing. +25 ish is the sweet spot for clearance. Some folks run wheel spacers so maybe keep that option in mind if you have excessive rubbing. My tires are 285 75 17 (smaller than what u propose) and with +25 on my wheels I had to trim mudflaps for complete clearance. Every vehicle is different as well as tires. So it might work great!
  7. Aug 3, 2021 at 5:04 PM
    #1837
    DodgerBlues
    DodgerBlues New Member
    Ryan
    Parker, Colorado
    2018 Cement TRD Offroad Tundra CM
    de-badged, 6112/5160 Bilstein’s 295/70/r18 toyo r/t Kmc 544
    Can finally add to this thread. 6112/5160 top setting. Toyo open country R/T 295/70/r18 KMC 544 Mesa
    D561F28D-A25B-4BFB-80E7-0E9F496FC30E.jpg ADA60367-6C76-467B-BA04-2B144A7D8BAD.jpg
  8. Aug 5, 2021 at 10:04 AM
    #1838
    fireman02
    fireman02 New Member
    20 SR5
    Second truck I have in this thread. My old 18 white platinum is on page 7 I believe. Similar setup on my current truck which is a 1794, 6112’s @ 1.9, 5100’s, Coachbuilder +1 shackles, bronze Icon rebounds w/ Toyo At3 285/75/17’s.
  9. Aug 10, 2021 at 10:23 PM
    #1839
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    Front 6112 @ 1.9”, 2 CB driver side shims, 1 CB passenger side shim.
    Rear 5160’s and CB +3 shackles.
    Stock tires until winter when I’ll probably go Toyo Open Country AT3’s in 295/70R18 or 285/75R18. I also have CB front bumper spacers that I’ve yet to install.
    BEFORE:
    AFTER:
  10. Aug 12, 2021 at 10:36 PM
    #1840
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    I see a lot of members with 18” wheels so I have a question
    I truly do like my factory rims where I live is literally the only tundra with those rims but they’re 20”. I’d like to lift the truck but nothing crazy I just HATE how that front looks so much lower than the back.
    A lot of people seem to run the 6112/5160 but for me I’d like to know the best set up would be if I just wanted a nice leveled square look? I don’t tow I don’t off road currently I am thinking barely getting into off road I just don’t think I’ll ever do anything crazy. Also since I mentioned that I want to keep my 20” rims would I need any spacers? I am planning on going from 275/55/20 to 285/60 R20. Any suggestions would be great or other thread reads. Thank you everyone in advance!
  11. Aug 12, 2021 at 10:44 PM
    #1841
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Did you ever run the 6112s on top setting? I'm unsure on to run 6112s at top, or at 1.9 with shims such as your setup. Besides perceived coil preload, what are the other pros and cons?
  12. Aug 13, 2021 at 3:42 PM
    #1842
    fireman02
    20 SR5
    Both times I’ve ran this setup I’ve only ran the 1.9 height so I can’t comment on the top setting. From what I’ve read the 1.9 setting tends to ride better.
  13. Aug 15, 2021 at 8:56 PM
    #1843
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Good to know. I got the Ok from the wife to get new wheels when I go with the 6112/5160. I am looking at 18x8.5 with a 0,18 and 35mm offset. What wheel should I get to easily fit a falken AT3 295/75?
  14. Aug 16, 2021 at 4:56 AM
    #1844
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    For comparison- I have 295/70/17 with 0 offset and they rub the flaps in reverse and had to modify the wheel well liners. If you don't want to have to potentially cut and trim I would not go with 0 offset.
    DeesCrewMax likes this.
  15. Aug 16, 2021 at 6:09 AM
    #1845
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    384FB292-5A7A-43E4-91AA-4F632ED067F0.jpg 7280CD59-CFBE-46CD-A2A8-742F2B78008C.jpg
    6112s/5160s leveled, 1.9, 2nd setting from the top I believe. I love the stance. 275/70
  16. Aug 17, 2021 at 1:25 PM
    #1846
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    After a year on the Bilstein setup 6112/5160 set @ 1.9" front w/ 0.5" CB shim DS; I keep thinking it's not high enough. But I just like the simplicity of the look and wanna keep it a functional truck.
    New add ons:
    -TRD Dual Exhaust w/ Black Chrome tip.
    -Air Design Tailgate Applique (Line-X w/ TRD Emblem)
    -Air Design Spoiler (Line-X)
    -XTP LED License Back up light
    -TuffSkinz Mudflap 4WD logo in Quicksand
    Inspiration? Copycat? Please leave any comments. You know Toyota came out with this color theme first.
  17. Aug 17, 2021 at 2:06 PM
    #1847
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    It only doesn’t look like enough height cause you got them big bumpy tires :thumbsup:
  18. Aug 17, 2021 at 3:36 PM
    #1848
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    What tire size you running?
  19. Aug 17, 2021 at 6:22 PM
    #1849
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    @Quicksand_Tundra Looks Killer! I ask myself daily- 3/1 35's? I will swap current 33's with 35's when ready and leave at 1.9; gonna be cutting... gonna lose HP... gonna jack shift points up... but gonna be happy. Maybe just run with nannies off. All good.
  20. Aug 17, 2021 at 8:03 PM
    #1850
    DeesCrewMax
    Deric
    The struggle is real. Most folks in this thread have spent more time than they care to admit contemplating this very choice. Ultimately I went with (and have loved) the 34” 285/75/17 with lighter than stock wheels. The tire weight of the 35” turned me away…for now. It cost me 9lbs per corner for a much sturdier, beefier, capable tire. Little to no noticeable power loss.
    Autom8ed and joseph_womack like this.
  21. Aug 17, 2021 at 8:07 PM
    #1851
    DeesCrewMax
    Deric
    Quicksand looks great. It wasn’t even on my radar and they had one on the lot when I was buying. Stuck with my cement and love it, but really like quicksands with dark windows and tasteful upgrades like yours. Well played.
  22. Aug 18, 2021 at 2:09 AM
    #1852
    Quicksand_Tundra
    Jon
    295/70/18r
    Ktate and tonynw318[QUOTED] like this.
  23. Aug 18, 2021 at 2:13 AM
    #1853
    Quicksand_Tundra
    Jon
    Thank you. Just trying to keep it simple.
  24. Aug 18, 2021 at 2:34 AM
    #1854
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    I'm on the same Bilstein setup and if you went to the top clip on the 6112's, you'll be slightly front-high (assuming your rear is stock). that's how mines ended up before I added the Icon AAL. I like how the 295's look on the 1.9" tho.
  25. Aug 18, 2021 at 9:53 AM
    #1855
    Quicksand_Tundra
    Jon
    Agree. I think the 295’s is the sweet spot for these truck. For sure did not want to go 35”, which I would have to do more modifications to make it fit.
    I added Coachbuilder shackles +2 in the rear, giving me 1” lift.
    Ktate, kuokoa and AZBoatHauler like this.
  26. Aug 20, 2021 at 4:51 PM
    #1856
    Ktate
    Ktate New Member
    2007 RCSB SR5 TRD 4x4
    I just finished installing Bilstein 6112 with springs (setting 3, 1.9) and 5100 on my 2007 RCSB 4x4. All measurements were taken from the center of the hub to the lip of the fender.
    Stock measurements were:
    Driver front 21.5 inch. Passenger front 21.5 inch
    Driver rear 24.25. Passenger rear 24.5
    After Bilstein 6112/511 install:
    Driver front 24 inch. Passenger front 24.25 inch
    Driver rear 24.25. Passenger rear 24.75
    joseph_womack and AZBoatHauler like this.
  27. Aug 24, 2021 at 7:23 AM
    #1857
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    Bilsteins 6112 at the 1.9 setting on the front with (2) shims on the Driver's side and (1) on the passenger and Bilsteins 5160s on the rear with CB +2 shackles.
    Debating between a 285/75/18 or 295/70/18 on the TRD rims. From all my measurements I should be able to fit either without any trimming.
  28. Aug 24, 2021 at 8:15 AM
    #1858
    Quicksand_Tundra
    Jon
    Go 295/70/18. Will have to remove front small mud flap. Better stance IMO. But post pics with whatever size you go with.
    joseph_womack likes this.
  29. Aug 24, 2021 at 8:21 AM
    #1859
    Nubby
    Nubby New Member
    AZ
    2021 TRD Army Green
    I think 285x75x18 is better unless you are looking for your tire to pop outside the body. If that’s the look your going for, 295’s will pop more. Personally, I’d rather have the height over width.
  30. Aug 24, 2021 at 8:34 AM
    #1860
    AlaskanAssassin
    David
    Alaska
    Nearly the identical setup I installed a couple of weeks ago but +3 CB shackles. I also installed the CB front bumper shims just in case. I’m also torn between taller 285 or wider 295.
