6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jul 8, 2021 at 4:20 PM
    #1801
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Thanks. Mine is currently 1.375” rake. I just switched my 6112 to the 2.5 setting. Go big or go home right.
  2. Jul 8, 2021 at 4:59 PM
    #1802
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    Exactly
  3. Jul 10, 2021 at 12:29 AM
    #1803
    cain0725
    cain0725 New Member
    i was at 2.5 on 6112 but hated ride. dropped to 1.9 , much smoother on bumps and potholes.
    AlaskanAssassin likes this.
  4. Jul 10, 2021 at 12:44 AM
    #1804
    shdwkeeper
    Can't clear 35" at 1.9
  5. Jul 10, 2021 at 7:36 AM
    #1805
    cain0725
    cain0725 New Member
    i have 29560/r20
  6. Jul 10, 2021 at 9:06 AM
    #1806
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    You can with the right offset. I ran a 2" lift on my truck for a few months until my current Eibachs got installed. No issues clearing 35s
    equin likes this.
  7. Jul 10, 2021 at 9:08 AM
    #1807
    shdwkeeper
    My tire is over an inch taller and wider and I'm on +20 offset rims, and the Ridge grapplers. I was scraping the inside plastic fender well and the skid plate. Easy fix, but no cutting. But, I also love the look, so why change.
  8. Jul 11, 2021 at 2:10 AM
    #1808
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    Still loving your GFC? Is it V1 or V2?
  9. Jul 11, 2021 at 5:31 PM
    #1809
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    What size tires did you go with and what wheel offset? Looks great!
  10. Jul 18, 2021 at 8:18 AM
    #1810
    pursuit2550
    pursuit2550 New Member
    I just picked up a set of 6112/5160. They are set on the top setting. Someone posted and I also saw it on the Toytec website that the lift heights are different for the 4x2(3.3) vs 4x4(2.5). My truck is 4x2. So is this true and verified. Anyone have a 4x2 set on the top setting and got 3.3? Want to make sure so I don’t have to do all the work twice.
  11. Jul 18, 2021 at 8:25 AM
    #1811
    JeffMac
    Jeff
    South Florida
    I cant confirm but here is the specs. Someone with 2wd would have to chime in.
    splitfuse likes this.
  12. Jul 18, 2021 at 8:29 AM
    #1812
    pursuit2550
    That’s the specs I saw. If I leave it at the top settings then I would most likely have to do uca and a bigger rear lift shackle. If I drop it then no uca and a 1- 1.5 shackle.
  13. Jul 18, 2021 at 8:36 AM
    #1813
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    U need carrier bearing spacer too,
  14. Jul 18, 2021 at 9:16 AM
    #1814
    shdwkeeper
    You can always ask @Coachbuilder1 as well, just for verification, but those specs are probably right.
  15. Jul 18, 2021 at 10:14 AM
    #1815
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Yes it is true. I contacted bilstein directly and got the same info. Mine settled at 3.25 of lift in the front. Really like the look with a 1.5 inch lift with the shackle in the rear. I have maybe 1/4 in of rake.
  16. Jul 19, 2021 at 12:24 PM
    #1816
    SK_MACHINE
    SK_MACHINE New Member
    Wompy
    CA
    2021 DC TRD 4WD
    Scratches on paint, coffee stain on seat, nail in tire, dog saliva on rear windows
    Hi y’all !! Do the 6112’s require an extended bump stop at highest setting ?? Thinking about adding a 1/4 spacer as well as SPC atms real soon.
  17. Jul 19, 2021 at 2:29 PM
    #1817
    pursuit2550
    They come with 4 washers to use as bump stop extension .
  18. Jul 19, 2021 at 10:31 PM
    #1818
    DodgerBlues
    DodgerBlues New Member
    Ryan
    Parker, Colorado
    2018 Cement TRD Offroad Tundra CM
    de-badged, 6112/5160 Bilstein’s 295/70/r18 toyo r/t Kmc 544
    back and forth between the toyo R/T or the wildpeak at3’s. How’s the R/T’s?
  19. Jul 21, 2021 at 10:01 PM
    #1819
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Just wanted to give an update. I upgraded my 285/75/17 tires (roughly 33.8”) with 315/70/17 BFG ATs (roughly 34.4”). I’m on 2 year old 6112s with close to 50K miles on the 1.9” setting, so it’s possible the coils may have settled to slightly less height over time (maybe 1/8”?). Anyway, only slight rubbing in reverse - not sure exactly where at the moment, though.
  20. Jul 21, 2021 at 10:55 PM
    #1820
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    And shackles to life the rear? Any other cutting?
  21. Jul 21, 2021 at 11:21 PM
    #1821
    equin
    Ed
    DFW, TX
    Haven’t installed the shackles yet. No BMC up front. I think it’s hitting the mud flaps when turning in reverse.
  22. Jul 22, 2021 at 7:29 AM
    #1822
    shdwkeeper
    Definitely remove the mud flaps
    equin[QUOTED] likes this.
  23. Jul 22, 2021 at 8:23 AM
    #1823
    equin
    Ed
    DFW, TX
    I should’ve clarified that I removed the front bumper plastic piece long ago before I installed these tires. I’m reluctant to remove the front mud flaps behind the tire for fear of throwing up excess rocks and dirt. I may try using a heat gun or cutting some of it, though, if that’s where the rubbing is occurring.
  24. Jul 22, 2021 at 1:51 PM
    #1824
    DodgerBlues
    Ryan
    Parker, Colorado
    Got 2 different quotes and just wondering what the best direction is.
    both for the 6112/5160 set up, with KMC 544 Mesa wheels 18"
    one with Falken Wildpeak at3w's and the other with the Les Schwab Open Range both at 295/70/r18
    one comes with SPC UCA's, as well as a 1/2 spacer to get to the full 3", a rear bearing drop and the Icon ADD.
    the difference is about $1400.
    My question is: is the UCA, spacer, drop and Falken over open range, worth $1,400? or is this a pay once cry once and get it all? What can I do without, and what is absolutely needed?
  25. Jul 22, 2021 at 7:29 PM
    #1825
    JeffMac
    Jeff
    South Florida
    SPC uca are nice I just put some in last week but you don’t need them for 6112 top setting. If you’re not lifting the rear you dont need carrier bearing drop. Everything I’ve read about Icon leafs was squeaking regret. Personally I’d save the $1400. If you’re handy you can get shackles and put them in yourself.
  26. Jul 22, 2021 at 8:12 PM
    #1826
    equin
    Ed
    DFW, TX
    Another update - They were rubbing the part of the mud flap that covers the body mount. That part of the mud flap actually sticks out towards the tire. Not sure why they designed it that way. Mind you, the rub is only in reverse and at full turn. The tires are still a good distance away from the actual body mount at full turn. Easy fix by either cutting that part of the mud flap off or using heat to push it in.
  27. Jul 23, 2021 at 5:45 AM
    #1827
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    @equin your tires/wheels look badass. I have a different wheel/tire with 0 offset and rubbed in same location in hard reverse - I let rub and the plastic on the flap whittled down after a while. It is also funny to watch people freak out when I back out sometimes and they hear the noise:eek:. I left the flaps on for the same reason- minimize the rock chips...
    equin likes this.
  28. Jul 23, 2021 at 7:09 PM
    #1828
    equin
    Ed
    DFW, TX
    Thanks! I actually cut that little piece off, but now that you mention you left yours on and let the tires rub it down, I wish I would’ve gone that route!
  29. Jul 24, 2021 at 7:08 AM
    #1829
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    You could always go with aftermarket flaps in the future. Take care.
    equin likes this.
  30. Jul 24, 2021 at 8:29 AM
    #1830
    equin
    Ed
    DFW, TX
    I hadn’t thought about that! Great idea. Thanks!
