6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Apr 15, 2021 at 5:23 PM
    #1741
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    What size are your tires? I'm actually getting ready to lift the wife's trd sport . Been thinking dropping to 18s and 295 70r18
  2. Apr 15, 2021 at 8:33 PM
    #1742
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Agreed need to know what size tire! I just picked up some rock warrior 17” wheels like these and stuck between 285/70 and 285/75 or something I’m not thinking of?
    Berdine[QUOTED] likes this.
  3. Apr 16, 2021 at 8:40 AM
    #1743
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    285/75r17 , so about a 34" by 11.25" tire.
    I will probably go with a 305/70r17 next. Same height, but ~3/4" wider.
  4. Apr 17, 2021 at 5:17 AM
    #1744
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    What model tire is it? I must say your set up looks incredible. How does it ride with the 285’s? I assume some power loss or at least a little feeling of gearing change? Any rubbing issues or spacers used with the rock warrior wheels? Sorry for all the questions but I really appreciate the insight! I looked at 305/70/17 and didn’t find many options and they were all E load and heavy but I guess that’s what you get with larger tires.
  5. Apr 17, 2021 at 9:10 AM
    #1745
    MSU Tundra
    Mississippi
    Great questions and thanks for the compliment. These tires are BFG KO2s which I’ve had several sets of along with the original KOs. They are a phenomenal tire that wears really well if you can get them balanced properly. However, my tire guy who I trust told me that the KO2s in various sizes have been very difficult for him to balance over the past year or so.
    With that said, I will likely go with another type of tire the next go around (probably Toyo or Nitto). With a 34” tire you will experience minimal power loss and around a 2mpg loss (ymmv), but nothing you don’t get used to real quick. I ran a 35x12.50 tire for a while and the difference was much more dramatic so I think the 34” diameter is the sweet spot on a stock Tundra/Sequoia.
    Wider width won’t affect power or shifting as much as it will give more mpg loss, but will tend to handle better. This is the reason I’m going with the 305 next go around because in my experience with the 285 width and 34” height, it tends to be a little less stable than desired because IMO the sidewall height is a little too much for the narrower width at highway speeds. But the “pizza cutter” look does look good to me.
    Also I prefer the E rated because I’m hard on tires and it gives you a thicker sidewall with more plies to protect against punctures (I’m around construction sites and such a lot).
    As far as the RW wheels, they actually have a bit more offset than factory which helps prevent rubbing with taller/wider tires so typically no spacer needed. This plus the strength and light weight of the wheel is why so many people like to run them.
    Hopefully my rambling helps you out!
    equin and Barrett50 like this.
  6. Apr 17, 2021 at 12:01 PM
    #1746
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    This is all extremely helpful and the answers I was looking for! Sometimes people are too general or short in answers assuming you won’t want to dive too deep into detail. Not me, all the detail and nerdy information I will gladly absorb and use! I was actually thinking nitto terra grappler or the toyo open country AT 3.
    Good to hear there isn’t any rubbing, I have an aftermarket bumper but even my 275/60/20(33x11) rub my sway bar a bit on full lock so hopefully the RW wheels will be better. I will seriously ponder 305’s for the more confident handling as I drive mountain roads a lot. Thanks again for all the help!
  7. Apr 17, 2021 at 1:21 PM
    #1747
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I appreciate all of this information. I currently have a set of cooper xlt in 305/70 17 in my garage next to my rebounds (+25) Not much info on that size on this site. I'm gonna give it a go with about 2.5 lift up front and keep stick uca. Hopefully just moving plastic and pulling flaps. Still a couple weeks out on the install. Always nerve racking when you can't find much info in advance.
    MSU Tundra likes this.
  8. Apr 17, 2021 at 4:43 PM
    #1748
    MSU Tundra
    Mississippi
    No worries, anytime. Worst case scenario is you may have some rubbing on the skid plate. A simple fix is to remove the outer “wings” on it which I’ve done on two different Tundras of mine. For the Sequoia I opted to splurge on the TRD skid which gives more clearance, and a bonus is it makes oil changes much quicker with its filter access panel. FC30C1D9-6690-4E86-9658-0FD60F999A9F.jpg894C38D4-3796-471C-ADAB-F39771A78CC0.jpg
  9. Apr 17, 2021 at 4:45 PM
    #1749
    MSU Tundra
    Mississippi
    Go for it. You’ll have plenty of clearance for that wheel/tire with a 2.5” lift.
  10. Apr 17, 2021 at 5:18 PM
    #1750
    cain0725
    cain0725 New Member
    ordered 6112 and 5100 combo and said it was in stock at shock surplus. Do they come set at a certain height and or can i adjust them?
  11. Apr 17, 2021 at 5:18 PM
    #1751
    cain0725
    cain0725 New Member
    oh said they were pre assembled as well
  12. Apr 17, 2021 at 5:19 PM
    #1752
    cain0725
    cain0725 New Member
    so ow i assume i need something for the rear like shackles , anyone have a link
  13. Apr 17, 2021 at 5:19 PM
    #1753
    cain0725
    cain0725 New Member
    also do the 5100 come with root guards
  14. Apr 19, 2021 at 4:39 PM
    #1754
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Is it normal to get 3 1/8” in the front set on 3rd/1.9 setting? 1.9 both sides 1CB shim DS. Also fit 1 7/8 with +2 shackle. Not complaining, just curious if others have had similar outcomes. Thanks. (275/70/18 cooper at3 xlt)A84DD88A-60ED-453E-9172-70924EA2F5CB.jpg083FE494-5C85-472B-AEBF-AB6C13A10AE9.jpg
  15. Apr 19, 2021 at 5:27 PM
    #1755
    SAGE63
    San Diego County
    Coachbuilder
  16. Apr 19, 2021 at 6:24 PM
    #1756
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Can someone explain to me why you would need shackles? I was looking at the 6112 in front and 5110 in the rear with SPC Upper control arms. So would shackles be necessary? I'm a total noob when it comes to suspension.
    Thanks
    Edsel
  17. Apr 19, 2021 at 6:29 PM
    #1757
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    There’s lotsa post about shackles, but basically it can improve ride and they raise the rear to desired height, to keep desired rake or keep level etc.
    Damie Street[QUOTED] likes this.
  18. Apr 20, 2021 at 11:02 AM
    #1758
    wvtriple
    wvtriple New Member
    2010 Super White RW CM
    IMG_5275.jpg I currently have 6112's on the top setting with CB shim both sides, no double on the driver side for lean. 5100's rear with CB 3+ shackle. I am going on 145,000 miles on this setup. No issues. I do light off-roading on a regular basis, and vacation to the outer banks each year and spent the week driving on the beaches. Those are the conditions this setup has had to endure. Tires are 35x12.50/17's, I have had to push the fender liner forward about 3/4 of an inch, to resolve rubbing at full lock in reverse. That being said I would like to replace them with a fresh new set with only a few exceptions, 6112's still up front, but with JBA UCA's, switch over to 5160's in the rear. I need new leaf springs, my truck has a total of 175,000 miles and with the addition of a new cap, the additional 200+ lbs has really taken its toll on the stock leaf springs. I plan on going with the Dobinson's. They have garnered good reviews, wont break the bank and best of all don't squeak. Adding the Dobinson's will negate the need for the CB shackles. So this is how she sets now, hopefully later on this year the parts will arrive. I am on a few wait lists hopefully its sooner than later, but we shall see.
  19. Apr 20, 2021 at 11:21 AM
    #1759
    Elduder
    Elduder New Member
    Im not sure if something changed, but I just swapped my OEM OR skid out for the Pro skid as well. I was surprised to see the skid on my 21 no longer had the side coverage, "wings".
  20. Apr 20, 2021 at 4:44 PM
    #1760
    FLdub
    FLdub New Member
    24 Limited 4x4 Nightshade
    My setup will be as follows:
    6112 on top setting with 2 CB shims driver / 1 CB shim passenger
    5160s out back with +2 CB shackles
    1.25" Bora spacers
    CB bumper shims
    285/75r18 Falken Wildpeaks on OEM TRD Pro wheels.
    No photos yet but does anyone have a similar setup to show some photos?
  21. Apr 20, 2021 at 5:05 PM
    #1761
    COTundra23
    COTundra23 New Member
    I used to run a similar setup..
    6112 at 1.9" with shims (2/1)
    Toytec 1" shackle
    Spidertrax spacers
    Falken 285/75
    B7071F31-26CB-49C4-BA79-CFE860BE297A.jpg 47CAB589-BA00-4421-9B81-FA85B4A8BAC4.jpg
  22. Apr 20, 2021 at 5:10 PM
    #1762
    FLdub
    FLdub New Member
    Curious what made you change it up?
    I figured I would need to remove mud flaps, maybe some plastic heat molding.
    COTundra23[QUOTED] likes this.
  23. Apr 20, 2021 at 5:22 PM
    #1763
    COTundra23
    I had an opportunity to buy an icon kit from a friend.. which I ran for a while.. and now I'm onto OME. Some may say I have a problem..
    Rodtheviking likes this.
  24. Apr 20, 2021 at 5:42 PM
    #1764
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    I just did 1.9 with 1 shim ps and +2 shackle and it’s almost perfectly level. I do have a topper tho. And the front will settle a little, maybe. Gained almost 3” in front and 1 7/8” in back 916D707E-92EA-4D96-A152-BCF3C883803A.jpg
    fuzzamungus and AlaskanAssassin like this.
  25. Apr 21, 2021 at 11:35 AM
    #1765
    MSU Tundra
    Mississippi
    Interesting. I would like to think they're helping out those that they know will run a bigger tire, but probably just another quick cost savings measure.
  26. Apr 21, 2021 at 12:11 PM
    #1766
    Elduder
    Elduder New Member
    Probably right. I was just surprised when I saw it was the same width as the pro skid. Especially since my primary reason was the width issue. Oh well, the pro one is about 3x the weight, should hold up for me.
  27. Apr 22, 2021 at 10:41 AM
    #1767
    MSU Tundra
    Mississippi
    Yeah the Pro one is a really nice unit and well worth the money IMO. The fit/finish/detail is superb to just be a plate of metal on the underside.
  28. Apr 23, 2021 at 8:09 AM
    #1768
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    Any running or cutting? Looks awesome!
    Damie Street likes this.
  29. Apr 25, 2021 at 1:05 PM
    #1769
    COTundra23
    I rippled the front inner liners out but that was it
  30. Apr 25, 2021 at 2:43 PM
    #1770
    CoryShap09
    Cory
    2020 CM XP
    Do you mind telling me how to do that?
