6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Apr 3, 2021 at 8:20 AM
    #1711
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    From what I have learned-
    Assuming the front are already installed I would first correct the lean either by a (spacer/shim); this will entail removing driver side shock and reinstalling... I went a different route with correcting the lean by staggering settings (1.9/1.3) it worked great for me.
    Anyway, after the front is good get it aligned and drive it for a couple weeks to let is settle. Once settled take your measurements of all 4 on a flat surface from center of wheel to wheel well. The difference will tell you the amount you will need to lift rear for the rake you want. I went that route and in the end left rear stock height for .75" rake. I don't plan on towing/hauling loads. Hope this helps.
  2. Apr 6, 2021 at 11:32 AM
    #1712
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
  3. Apr 7, 2021 at 9:21 AM
    #1713
    woodlandFF
    woodlandFF New Member
    2019 SR5 Cement Tundra CrewMax 4x4
    Black Rhino 20s
    Missed it by a damn cunt hair! Oh well, maybe the 2022 will be here by the next round of stock haha. Thanks though
  4. Apr 7, 2021 at 9:59 AM
    #1714
    Kanobi13
    Kanobi13 New Member
    Seems like a bit high installed correctly? Did you get 1/2 spacer or 1 inch spacers?
  5. Apr 7, 2021 at 3:17 PM
    #1715
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Yeah it’s right. Shims are 1/2”. It has settled after alignment and some miles. I’m going to remove a shim on each side this weekend.
    2wd This is 6112/5100. The front set at lowest clip with 2 shims DS 1 shim PS 1/2” I’ll post another pick when I remove a shim
    TheGreyTundra28 likes this.
  6. Apr 7, 2021 at 3:24 PM
    #1716
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I got an email from Bilsteinlifts.com that they have 6112s back in stock. Never ordered from them though. Online feedback is a little iffy
  7. Apr 7, 2021 at 3:31 PM
    #1717
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Try shocksurplus. I had great service there! They emailed me yesterday saying they got more in stock. Call first!
  8. Apr 7, 2021 at 3:45 PM
    #1718
    JimboSlice413
    Bakersfield
    I've heard good things about them. I went an entirely different direction, just throwing it out there in case someone is looking.
  9. Apr 7, 2021 at 3:59 PM
    #1719
    Kanobi13
    Kanobi13 New Member
    If the spacer is 1/2 thick that will give you inch of lift.
    Rodtheviking likes this.
  10. Apr 8, 2021 at 6:58 AM
    #1720
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Yep. 1/2” = 1”. 1/4” = 1/2”.
    I have the 1/4 that give you 1/2”
  11. Apr 12, 2021 at 5:41 PM
    #1721
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Bilstein 6112's at 1.9" up front and 5100's in the rear at stock height.
  12. Apr 13, 2021 at 9:08 AM
    #1722
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    This looks factory to me but im sure the ride is a little better than stock
  13. Apr 15, 2021 at 12:23 PM
    #1723
    woodlandFF
    Black Rhino 20s
    Berdine and cdavi060 like this.
  14. Apr 15, 2021 at 12:43 PM
    #1724
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    Nice! In the same boat. Just waiting on my CB shims and +3's!
  15. Apr 15, 2021 at 1:09 PM
    #1725
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Unless you guys are just f’ing with each other...then wouldn’t (2) 1/2” shims on drivers side and (1) 1/2” shim on passenger side over compensate?
  16. Apr 15, 2021 at 1:43 PM
    #1726
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    Set at 1.9 with 1/4” shims. Net gain 3” over stock height.
  17. Apr 15, 2021 at 1:47 PM
    #1727
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    It's to compensate for driver side lean that most tundras have.
  18. Apr 15, 2021 at 1:48 PM
    #1728
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Nice rig!
  19. Apr 15, 2021 at 1:49 PM
    #1729
    AZBoatHauler
    So.Arizona
  20. Apr 15, 2021 at 2:14 PM
    #1730
    MSU Tundra
    Mississippi
    Thanks!
    Casper3[QUOTED] likes this.
  21. Apr 15, 2021 at 2:17 PM
    #1731
    ScenicRoute
    Yes I know. But I’m led to believe it’s a 1/2” lean. I’m reading here that 1/2” shim = 1”. Logic would say that (2) 1/2” shims = 2” and with one shim on passenger side then you have a 1” difference.
    like I said maybe those guys are just f’ing with each other??
  22. Apr 15, 2021 at 2:31 PM
    #1732
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    In that case maybe they're compensating for something else. :D
  23. Apr 15, 2021 at 2:41 PM
    #1733
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    .5in shim = .5in lift you are right
  24. Apr 15, 2021 at 3:17 PM
    #1734
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Actually the CB shims are 1/4” = 1/2” lift. I assume the 1” of lift are 1/2” thick, only have seen the 1/2” of lift ones.
  25. Apr 15, 2021 at 3:19 PM
    #1735
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    It’s 1/4” thick62DBB051-0A63-4D31-AE8F-78851B2A6B15.jpg
  26. Apr 15, 2021 at 4:20 PM
    #1736
    ScenicRoute
    Clear as mud.
  27. Apr 15, 2021 at 5:23 PM
    #1737
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    What size are your tires? I'm actually getting ready to lift the wife's trd sport . Been thinking dropping to 18s and 295 70r18
  28. Apr 15, 2021 at 8:33 PM
    #1738
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Agreed need to know what size tire! I just picked up some rock warrior 17” wheels like these and stuck between 285/70 and 285/75 or something I’m not thinking of?
    Berdine[QUOTED] likes this.
  29. Apr 16, 2021 at 8:40 AM
    #1739
    MSU Tundra
    Mississippi
    285/75r17 , so about a 34" by 11.25" tire.
    I will probably go with a 305/70r17 next. Same height, but ~3/4" wider.
  30. Apr 17, 2021 at 5:17 AM
    #1740
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    What model tire is it? I must say your set up looks incredible. How does it ride with the 285’s? I assume some power loss or at least a little feeling of gearing change? Any rubbing issues or spacers used with the rock warrior wheels? Sorry for all the questions but I really appreciate the insight! I looked at 305/70/17 and didn’t find many options and they were all E load and heavy but I guess that’s what you get with larger tires.
