6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Feb 6, 2021 at 4:21 AM
    #1591
    KWC
    KWC New Member
    Conroe, Tx.
    2017 Toyota Tundra
    6112's, 5160 + 1
    Exactly correct!
  2. Feb 6, 2021 at 5:58 AM
    #1592
    willx
    willx New Member
    will
    2020 tundra sr5 crewmax
    I have 6112 @ 1.9 and 5100 with 1in shackles in the rear and I have a pretty heavy driver side lean. I’m considering bumping up to 2.5 front. Could I raise to rear and get rid of the lean with just a few shims?
  3. Feb 6, 2021 at 12:52 PM
    #1593
    TeamGoose
    TeamGoose Threat Level Midnight, Michael Scarn
    Temple, TX
    2020 Tundra TSS 4x4 Cement
    OEM LED Headlights, TRD Shifter, Interior LEDs, 6112(1.9) & 5160 reg. height
    I’m not sure if they’re in stock or not, but I placed an order and awaiting an email let me know my fate.
  4. Feb 6, 2021 at 12:55 PM
    #1594
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    That's where I ordered mine from in November. I'm still 31st in line to receive a set
  5. Feb 6, 2021 at 1:26 PM
    #1595
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
    @willx
    I have mine set at 1.9” with 2 CoachBuilder shims on the passenger side and 1 CB shim on the driver’s side.
    It took a while to settle buts it’s even now. Approx total front lift should be around 2.4”.
  6. Feb 6, 2021 at 1:43 PM
    #1596
    TeamGoose
    Temple, TX
    That’s about right lol
  7. Feb 10, 2021 at 12:06 PM
    #1597
    SAGE63
    San Diego County
    20210210_075255.jpg Fish creek dusty tundra. 6112's at 2.5 5160 rear. Built Right UCA's. TRD Offroad wheels and stock 275/65r18 tires. Still deciding on next Tire size to run with no chopping... keeping the TRD wheels.
    Yes, i did smack and flatten the front tube step support before the new suspension...oops lol
    drobb likes this.
  8. Feb 10, 2021 at 12:18 PM
    #1598
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Here's an update on mine ... 6112s at top setting & finally installed with SPC UCAs. I already had 5160s in back with Toytec shackles @ 1" setting. There's a Decked unit in the bed as well. Not liking the angles on the CVs even with the diff drop I installed a long time ago when I put the 5100s on. They should settle in with some more miles. Method Roost + WildPeak 295/65/20
    71216E54-3599-439F-8240-5441DAF18AA3.jpg 85E593A6-053D-426B-B5C2-2F350F20A2D5.jpg
  9. Feb 10, 2021 at 1:03 PM
    #1599
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    Are you planning on new bump stops? Looks like you are missing the little “extensions” that come with the 6112s.
  10. Feb 10, 2021 at 1:19 PM
    #1600
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    I can check with Shock Surplus on that; they don't mention any bump stop spacers/extensions as part of the 6112 kit. Not a big deal right now, but I'll probably replace the OEMs with something else eventually.
    drobb[QUOTED] likes this.
  11. Feb 10, 2021 at 8:47 PM
    #1601
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Mine came with washers to use on top of the OEM bumpstops.
  12. Feb 11, 2021 at 7:18 AM
    #1602
    TeamGoose
    Temple, TX
    I was creeping on the for sale page on here and happen to find theses 40 mins down the road from me and picked the up.. 5160s on order now, just waiting for the shop to get to me!!
    JimboSlice413, Shuffler and jpod like this.
  13. Feb 11, 2021 at 7:58 AM
    #1603
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Huh. Sounds like my shocks were missing those spacers, or the shop guys didn't know what to do with them (doubtful). No biggie ...
    equin[QUOTED] likes this.
  14. Feb 11, 2021 at 2:21 PM
    #1604
    equin
    Ed
    DFW, TX
    Yeah, they probably didn’t know what to do with them. Anyway, I looked into the Wheeler’s bumpstops and lfound this old thread:
    https://www.fjcruiserforums.com/thr...ith-wheelers-offroad-front-bump-stops.406346/
    I’m still not exactly sure why or how that happened to the FJ, and I don’t remember reading about anyone on this forum that experienced a similar issue. But I noticed on their site they also say they sell washers to go with them to adjust the height:
    “Optionally, we have 1/4" and 3/8" spacers available for bump stop height tuning.”
    Maybe to also prevent bottoming out if they still squish all the way to stock height? I don’t know. You may want to call and ask them about that just to make sure.
    Shuffler[QUOTED] likes this.
  15. Feb 12, 2021 at 3:54 PM
    #1605
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    exactly, it's so you use your bumpstops as they're intended, instead of using your shock as a bumpstop and ruining your shocks. ideally, you cycle your suspension and measure everything out, then you can figure how much (if any) to adjust your bumpstops. having said that, throw away those stock bumpstops and get something else to replace those rocks.
    equin[QUOTED] and Shuffler like this.
  16. Feb 12, 2021 at 4:22 PM
    #1606
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    These new ones will go toward the rear of the lower control arms (per Wheelers) so the ones in front (pictured) remain in place. I saw some other options from Timbren but they were $225 :eek2:
    kuokoa likes this.
  17. Feb 12, 2021 at 7:25 PM
    #1607
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    I ran Wheeler's super bumps on my Tacoma and they were nice. granted, we don't do any jumping or high-speed wheeling in Hawai'i, but they soften the hits if you put your truck in a rut. I actually have my Tacoma super bumps on my Tundra now (even though Wheeler's said there's "stiffer" rear ones for Tundra's), but haven't hit them hard yet. I couldn't justify the Timbren price either, but I'm sure they're worth it. you can get a full Wheeler's super bump set for the half the price of a Timbrens set :bananadead:
  18. Feb 14, 2021 at 5:03 PM
    #1608
    DigB
    DigB New Member
    Winnipeg, Manitoba
    2008 CM, Salsa Pearl Red
    Mods Imminent
    Coachbuilder spacers, are they really necessary? I've got an '08 CrewMax, I'm putting 6112's @1.9 with 5100's in the rear with CB +2 shackles. I've heard lots of differing opinions. Is the lean really that noticable?
    equin likes this.
  19. Feb 15, 2021 at 8:05 PM
    #1609
    rjsimz
    rjsimz New Member
    Rob
    2015 SR5 CrewMax 4x4
    anyone thinking about upgrading their set up in the foreseeable future before I go in on a new pair?
  20. Feb 15, 2021 at 8:46 PM
    #1610
    equin
    Ed
    DFW, TX
    When I measured, the lean was 1/4” to 1/2”, depending on how level the ground was. But I could never tell, meaning the lean was never noticeable to me.
    DigB[QUOTED] likes this.
  21. Feb 16, 2021 at 9:53 AM
    #1611
    DigB
    DigB New Member
    Winnipeg, Manitoba
    Mods Imminent
    That's good to hear. I don't think it will be noticable enough to query about it. I asked coachbuilder about it but I haven't heard back yet.
  22. Feb 17, 2021 at 1:31 PM
    #1612
    Burdturger
    Burdturger New Member
    It would be nice if someone could compile a checklist for parts for this set up and make a sticky. I got the 6112/5160 on top setting. I went ahead and got UCA's (may or may not be needed), toytec shackles (hopefully will have a slight rake) and might get the 3 shims for the driver side lean and also the carrier drop kit (also may not be needed). Am I missing anything?
    cdavi060 likes this.
  23. Feb 18, 2021 at 2:35 PM
    #1613
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    So I have mine set at 1.9" and no shims or anything to the rear besides 5160. I'm currently running 275/70r18 Trail Grapplers on stock TRD OR wheels. I'm wanting to step up to 295/70r18 anybody run this size at 1.9"? Also contemplating SCS Ray10 (+25) or Methods (+18).
    tonynw318 and AlaskanAssassin like this.
  24. Feb 19, 2021 at 11:54 AM
    #1614
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Are they sold? I'm interested.
  25. Feb 19, 2021 at 12:04 PM
    #1615
    COTundra23
    COTundra23 New Member
    Yup... they gone.
  26. Feb 19, 2021 at 3:22 PM
    #1616
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    you won’t be seeing Ray 10s for a while
  27. Feb 19, 2021 at 3:38 PM
    #1617
    SAGE63
    San Diego County
    why is that rocket
  28. Feb 20, 2021 at 4:03 AM
    #1618
    R0CKETMAN
    NGAMTNS
    zero indication from Vin they’re even on deck.
    Have you shopped for 18x9 Ray 10s in the last 12 months?
  29. Feb 20, 2021 at 5:40 AM
    #1619
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    I’m going thru my checklist as well right now and am totally new to upgrading suspensions.
    I will say that yes the carrier bearing drop is necessary for anything +2 or higher. I also ordered new bushings and cushions for back shocks cuz new ones don’t come with them.
    Curious if I’m missing something as well. What UCA you go with? I went with JBA, cheapest and simple.
  30. Feb 20, 2021 at 6:20 AM
    #1620
    Burdturger
    got a bf deal on the camburgs turned out to be cheapest option at the time. are you getting shims as well? how are you lifting the rear?
