6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Mar 7, 2019 at 12:54 PM
    #121
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I agree. I think that should work great.
  2. Mar 7, 2019 at 1:09 PM
    #122
    JPritch
    JPritch New Member
    Josh
    17 TSS Crewmax
    What exactly do shims and shackles do? I've begun looking into front leveling, and looking hard at 6112's....but all this talk of shims/shackles...is that necessary if all I want to do is level the front?
  3. Mar 7, 2019 at 1:32 PM
    #123
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Shims help with tundra lean and/or give you an extra 1/2” or so of front lift. New adjustable Shackles are to raise the rear.
  4. Mar 7, 2019 at 1:46 PM
    #124
    equin
    Ed
    DFW, TX
    Shims look like flat discs. A 1/4" thick shim should provide about 1/2" of lift. They're usually placed on top of the coilover's top hat and just under the top shock mount (as opposed to a spacer which can go in between the coil spring and top hat). Many Tundras lean slightly on the driver's side because of the added weight of the gas tank and driver. To compensate, some folks will add one shim on the driver side to level it up with the passenger side. I've never used shims. A 1/2" difference in height doesn't bother me, but that's just me.
    Shackles are an inexpensive way to lift the rear about an inch or two. They attach the rear part of the leaf pack to the frame. Another inexpensive (probably cheapest) way to lift the rear is to use blocks, which go in between the leaf pack and spring perch on the axle. I've never seen it happen, but have heard of blocks spitting out from the spring perch, which can be dangerous. An add-a-leaf (AAL), which is an extra leaf spring placed within the stock the leaf pack (usually on the bottom), is another way to achieve lift and sometimes can add a bit of extra spring rate. AALs sometimes provide a harsher ride. True performance for the rear comes with brand new leaf packs that can add lift, cargo carrying capacity, or greater flex, depending on your needs, but new leaf packs are more expensive. Hence, the more affordable and popular way to achieve modest lift in the rear is with shackles.
    You don't need to lift the rear if you want to keep it level, and you can still easily fit bigger tires without lifting the rear. But by leveling the truck, the rear will sag lower than the front once you haul a load in the bed or tow something heavy. So most folks like to add a 1" or 2" lift in the rear to compensate for that, especially if they go with more than 2" of lift up front.
  5. Mar 7, 2019 at 5:20 PM
    #125
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Check out my build below vvv
    bowtieman55 and JPritch[QUOTED] like this.
  6. Mar 7, 2019 at 7:00 PM
    #126
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    You will most likely need UCA to get into proper alignment specs you will be pretty close to 3in. I have done TONS of research and the consensus is YES get them because if you don’t you will pay for an alignment then 6 months down the road buy UCA anyway and pay for another alignment. Pay once do it right the first time.
    r1-superstar likes this.
  7. Mar 8, 2019 at 7:16 AM
    #127
    matrdguy
    matrdguy New Member
    Pete
    'The Notch' Western MA
    MGM 2016 Tundra Platinum 1794 Edition
    18" TRD Wheels, Falken Wildpeak AT3 275 75 18, Westin Bed Rug with Linex, Window Vents, TRD Sway Bar, Bilstein 6112/5100 CB +3 shackels, CB Shims, Chrome Tailgate Letters. More To Come....
    Anyone running 6112's at TOP setting AND adding CB Shims ( both for additional 1/2") ???
    I have the 3+ shackles for the rear already but was wondering if there were any pics out there ( or did i miss them cause I think I have viewed every Tundra in the US)
    If you did add 2 shims to top setting on 6112's any issues with alignment ?
    Thanks in advance
  8. Mar 8, 2019 at 11:33 AM
    #128
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    @matictundra
  9. Mar 8, 2019 at 11:37 AM
    #129
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    If you go that route, go ahead and buy UCA's as well. Once you get around the 3" mark, you get close to needing them, so anything over and you will most likely have to have them.
    Think it was @r1-superstar that found out he needed after he installed his at the higher setting with shims.
  10. Mar 8, 2019 at 12:21 PM
    #130
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    6112 top setting with a 1/4" CB shim for 3" front lift and Toytec shackles set at 1.5. I do have JBA UCA.
  11. Mar 8, 2019 at 1:06 PM
    #131
    matrdguy
    matrdguy New Member
    Pete
    Thank you... I really dont want to get into UCA change... so I will stick with Top setting
    Thanks to all
  12. Mar 8, 2019 at 1:18 PM
    #132
    Berdine
    Binghamton, NY
    Better get it washed!
  13. Mar 8, 2019 at 1:30 PM
    #133
    matictundra
    Franco
    AZ
    HAHAHA. Lasted one day being dirty.
    Berdine[QUOTED] likes this.
  14. Mar 8, 2019 at 1:42 PM
    #134
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    6112s at 1.3 setting. Stock wheels and 275/60/20 Falken Wildpeak AT3.
  15. Mar 8, 2019 at 2:00 PM
    #135
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    What's the general opinion on best UCA for the $ for the 6112 top setting plus shim setup?
  16. Mar 8, 2019 at 4:38 PM
    #136
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    Nice looking truck. Are those Fuel Vectors?
  17. Mar 8, 2019 at 5:08 PM
    #137
    r1-superstar
    DB
    UTAH
    bowtieman55 likes this.
  18. Mar 8, 2019 at 7:54 PM
    #138
    matictundra
    Franco
    AZ
    Yes
  19. Mar 9, 2019 at 3:21 PM
    #139
    r1-superstar
    DB
    UTAH
    Yes, I purchased SPC UCAs from @BOSS4x4s .
  20. Mar 10, 2019 at 12:30 AM
    #140
    cmiller219
    Nashville, TN
    Need to contact Boss. Need to get my order in ASAP
  21. Mar 10, 2019 at 5:19 AM
    #141
    Danman34
    Danman34 New Member
    Danny
    Be careful going down that rabbit hole. Lol.
    cmiller219[QUOTED] and Berdine like this.
  22. Mar 10, 2019 at 2:47 PM
    #142
    cmiller219
    Nashville, TN
    anyone know how to get ahold of Darren at Boss?
  23. Mar 10, 2019 at 3:00 PM
    #143
    neirbot
    neirbot New Member
    I've always emailed him and he responds very quickly.
    Jmad1997 and r1-superstar like this.
  24. Mar 10, 2019 at 3:23 PM
    #144
    Berdine
    Binghamton, NY
  25. Mar 10, 2019 at 6:35 PM
    #145
    r1-superstar
    DB
    UTAH
    Email him, he responds very quickly!! Pricing is AWESOME!!!
  26. Mar 11, 2019 at 9:06 AM
    #146
    MiYota
    MiYota New Member
    evan
    2014 super white tundra
    Well after driving on 2 blown rear shocks for about a month or so I finally have the time and weather to install my 6112's and 5160's. So excited to have them on the truck. I have the passenger front side almost done and it only took me about an 1-1/2 hours to get it done. Will post up some pics once it's all installed. Thanks to all the guys posting on this thread it has really helped me decide on how to set the front shocks up.
    cmiller219 and equin like this.
  27. Mar 11, 2019 at 9:14 AM
    #147
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Finally taking the plunge this week on my lift and wheels/tires. Getting Fuel Assault 18s +1, and 5" backspace. BFG 305/65 tires. If I have to do the lift, I'm going with 6112 at the top setting and 5100 in the rear. So I'll report back.
    Some great looking trucks on this thread!
    Silverghost and cmiller219 like this.
  28. Mar 13, 2019 at 11:34 PM
    #148
    cmiller219
    Nashville, TN
    Think my plan is to get the 6112 top setting, UCA (haven’t decided brand) 5110 and coach builder shackles +2.
    Anyone any issues I may have? Too much lift in rear? Want level or slight forward rake
  29. Mar 14, 2019 at 5:32 AM
    #149
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    I'm on the top setting with 6112's with no aftermarket UCA's . I didn't have any alignment issues. I do have the slight driver lean and have already purchased a shim for the driver side but haven't committed yet. I'm iffy whether my alignment will allow for it without UCA's :confused:
    I went with Toytec Boss Rear shocks purely because they were spec'd for 0-3" of rear lift. I also went with Toytec shackles and ended up on the middle hole. Supposedly the 5100's were only good for 0-1" of rear lift. Just wanted my options for rear lift in the future if I decided to go with more rake. Just my 2 cents :cool:
  30. Mar 17, 2019 at 11:05 AM
    #150
    Hyperlite33
    Hyperlite33 FN-2187
    2018 White Platinum 4x4
    This is the exact setup I'm going with although I'm going to do just the front 6112 rear 5110 and then use a jack to determine if the 2" CB shackles are going to be the correct choice. I want a slight rake just for light towing and hauling.
