6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Sep 19, 2020 at 8:55 AM
    #1321
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I am wondering if the shop installed them correctly. The directions say that you remove 2 of the stock leafs but when I went to pick it up they gave me only 1 leaf (from each side). And the 1 leaf was fairly short, thick and heavy. It seems like it is the very bottom one when you look at the last page of the ICON installation sheet. Would it make sense if they just took out the overload leaf? I am going to talk to them on Monday.
    The reason I bring this up is that I really didn't get any lift. I was at 40.5 before and now am at 40.5. It rides really good, I just need to get clarification on what that 1 leaf they took out was and why they didn't do as the instructions say. Unless this way is to give a better ride which I would rank higher than giving a lift but I really wanted both as that is what ICON says this pack will do. I need the rake for when I put my 2 dirt bikes in the back. Maybe I'll add a 1" shackle in back to get me an additional 1/2" of rake.
    My other thought without regards to $$ would be 6112's up front set at 1.9 and add 2 coachbuilder shims on the driver side and 1 on the passenger side (already have them at home), 516o's in back and the RXT or Deaver (sp) leaf pack and shackles. Or the Toytec lift :goingcrazy:
    Edit - It appears that Deaver may have a leaf expansion pack and per their instructions they remove the factory overload leaf. My OCD is giving me a headache :laughing::laughing:
  2. Sep 19, 2020 at 12:57 PM
    #1322
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    I keep looking for replacements for my 6112/5160 combo and can’t find the right thing. I love the aluma series toytec, but the candy red on black is a no go. Fox are prone to issues, and king’s rust quick.
    Dobinsons will get my money when their IMS comes out. Til then, these work great on washboard fire roads.
    J&ATundra, Muleycrazy13 and equin like this.
  3. Sep 19, 2020 at 4:30 PM
    #1323
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    Yea, the red or the Toytecs is what I really like about them as I have the Barcelona red truck.
  4. Sep 20, 2020 at 4:08 PM
    #1324
    Maxtor
    Maxtor New Member
    Mark
    6112’s 1.9” with 1/2” drivers shim. 5160 on rear and added firestone airbags for towing.
    Big shout out to Boss 4x4’s ... awesome customer service and arrive in 3 days
  5. Sep 20, 2020 at 4:45 PM
    #1325
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    you guys are killing me! I’m buying Toyo OV AT3’s and Now 6112’s are on the list. It’s gonna be an expensive October.
    How big of a tire can I go if I do 1.3 on the 6112’s?
  6. Sep 21, 2020 at 1:27 AM
    #1326
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    all depends on your rim. but 33's will fit without any lift. maybe you can get 285/70/18's (34's) in with some cutting on the 1.3 setting.
  7. Sep 23, 2020 at 6:28 AM
    #1327
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Looks good. Any shackle/block in the rear?
  8. Sep 23, 2020 at 6:57 AM
    #1328
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    With the Deaver pack - you remove the big thick overload leaf at the bottom, with the icon pack you remove the two secondary springs just above that overload leaf and replace those 2 with the icon set (3 leafs).
    This way icon advertises as “maintain factory tow capacity” because that overload spring is key
    Edit: I got 1.5” of lift when I installed the icon pack...
    pvn.beluga and equin like this.
  9. Sep 24, 2020 at 12:02 AM
    #1329
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    Yea, I talked to the installer and he said he's done that the same way all the time. Taking out the overload....I said, well, that's not the way ICON says to do it. It's going back in next week so they can do it the right way. Trying to figure out if I want to take this opportunity to upgrade from the 5100's all around.....
  10. Sep 24, 2020 at 6:28 AM
    #1330
    CaptainGrumpus
    Maine
    You need to reverse your buying list. Fronts, exhaust and then rear shocks. Maybe even go exhaust first because @dirtydeeds is have a GB right now.
    KTMRider[QUOTED] likes this.
  11. Sep 24, 2020 at 7:14 AM
    #1331
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    ^Agree. Recommend to get the front dialed in and then determine what you will need for rear in terms of height. I ended up with DD 8" system first and then did fronts and ended keeping rear stock height with 5160s- turned out well for my uses.
    KTMRider likes this.
  12. Sep 24, 2020 at 9:23 AM
    #1332
    mrburns05
    Jacob
    Menifee CA.
    awe yea! I’d get 5100’s or even wait if needed and get 5160’s, they’re so easy to change you don’t even have to worry about doing it at the same time.
  13. Sep 24, 2020 at 11:01 PM
    #1333
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    I currently have 5100's all around. Wondering if there is a better street driving/occasional offroad shock that is better suited if I go up the 1 1/2" in the back than the 5100's. I'm kinda drawn to the Toytec Aluma series (red is a plus). I think the 2.0 would suffice for me.
  14. Sep 25, 2020 at 5:38 PM
    #1334
    mrburns05
    Jacob
    Menifee CA.
    I don’t have experience with the others, just stock, fox 2.0, and waiting for my icon 2.5” rear shocks to arrive in the mail. There’s so many contradicting conclusions on what is best for this or that kind of driving I really just wanted a bigger better shock and figure any of the big name brand would suffice, I was not impressed with the fox 2.0 in the least bit.
  15. Sep 25, 2020 at 5:47 PM
    #1335
    mrburns05
    Jacob
    Menifee CA.
    I’m doing an odd mix of 6112/Icon 2.5” rear.... here is 6112 on lowest setting, but I have maxtrac spindles so a total of 4.25” lift, the rear has icon leaf expansion & coach builder +1” shackles for a total of I think 2.25” lift, the fox shocks are still on there, I’m not off roading or testing the 6112’s “properly” until my new icons get here
  16. Sep 27, 2020 at 8:17 PM
    #1336
    Nickj619
    Nickj619 New Member
    Nick
    San Jose, ca
    2014 tundra trd crew max
    6112/5160 setup, 2 cb shims driver side 1 ship passenger. Spc uca, cb +3 shackle, installed today by @dcsleeper408
    Method 18x9+25 with 275/70 falkens
  17. Sep 27, 2020 at 8:41 PM
    #1337
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    What setting are the 6112's at?
  18. Sep 27, 2020 at 10:06 PM
    #1338
    Nickj619
    Nickj619 New Member
    Nick
    San Jose, ca
    Top setting
  19. Sep 30, 2020 at 9:19 AM
    #1339
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Here is my dilemma... I have been slowly piecing together my lift. I have some 6112s at the 3rd clip and some Camburg 1.5" shackles... My problem is that I am of course anxious to get everything on the truck, however I won't be able to get my desired larger tires for several more months :(. I was planning on doing the 6112s no matter what so I would essentially be leveling out the front and I wouldnt think that would look too funny with stock tires for a bit. Should I also throw the shackles on while I am in there and doing everything? Or would that be too goofy to ride around with a 1.9" lift in the front and 1.5" in the rear with stock rubber? The alternative would be to install the shackles months down the road when I can get my hands on some new tires. What to do, what to do....
  20. Sep 30, 2020 at 9:50 AM
    #1340
    AZBoatHauler
    So.Arizona
    I’d suggest doing the front and shackles at the same time to increase the likelihood of keeping the TSS happy. Some shops offer decent money for stock tires with decent tread - have you explored that option? Took me 35k miles to wear my stock tires enough that I didn’t feel bad tossing them.
  21. Sep 30, 2020 at 10:20 AM
    #1341
    Hartsy8
    Max
    2020 MGM 1794
    Yeah that is also a factor to consider for sure. I am more just wanting to do it for convenience sake of already have the rear shocks off and everything! I just dont want to look like a doofus running around with that much lift and no tires :p although I guess its not that much.
    I have seen a lot of people have done that. Do you happen to know which places are open to that kind of thing? It may just take calling a few places like big'o or discount as im sure its not advertised. The stockers only have like 1500 miles on them and I can't stomach getting rid of new tires :/
  22. Sep 30, 2020 at 10:21 AM
    #1342
    TX_Inferno
    TX_Inferno New Member
    Randy
    Dallas, TX
    2018 Inferno Tundra SR5
    Bronze Method NV 17x8.5 +0 Nitto Ridge Grapplers 35x12.5 Bilstein 6112 3"/5160 1" RetraxPRO MX Tonneau Cover Rhino rock sliders Fender flares TactilianUS - US and TX flag magnets TRD shifter
    Sorry if this has already been discussed and asked before - I recently got an estimate to do Bilstein 6112's and 5160's in the rear, add a leaf, diff drop, etc..I was wondering if it is recommended to replace the stock control arms while doing all of this or will they be fine? 2018 with 47k miles, mostly highway, and planning to do some very light off-roading and camping with the truck.
    Thank you!
  23. Sep 30, 2020 at 10:22 AM
    #1343
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Sell them on Facebook marketplace! You will get better value then a tire shop. Or sell with your rims and upgrade everything all together.
  24. Sep 30, 2020 at 10:24 AM
    #1344
    Hartsy8
    Max
    2020 MGM 1794
    What would be a good price point for those guys?
  25. Sep 30, 2020 at 11:00 AM
    #1345
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    It really depends on how much lift you go with because that will limit the stock UCA during your alignment. At 1.9” you will be fine. At 2.5” you will be on the bubble whether or not you’ll need new arms but most people don’t. If you go up to 3” there’s a greater chance of needing new arms in order to get a proper alignment. Hope this helps
    TX_Inferno[QUOTED] likes this.
  26. Sep 30, 2020 at 11:27 AM
    #1346
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    If they are the standard TRD rims and tires I would put them up for $1000, if just tires maybe $400 or $500. Check FB local to your area and you will see what others are selling them for
    Hartsy8[QUOTED] likes this.
  27. Sep 30, 2020 at 11:42 AM
    #1347
    Heatjay
    Heatjay New Member
    2018 TUNDRA PLATNIUM MG
    I am looking to purchase the 6112 and the 5160 set up. Can anyone tell me a good place to purchase this already assembled? And the corresponding part numbers. I just realized that there a few different models?
  28. Sep 30, 2020 at 12:01 PM
    #1348
    AZBoatHauler
    So.Arizona
  29. Sep 30, 2020 at 12:04 PM
    #1349
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    @BOSS4x4s is the best place to purchase. Best prices best customer service. Give Darren a call or send an email and he will answer all your questions.
    HammockYota likes this.
  30. Sep 30, 2020 at 2:55 PM
    #1350
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Got mine from Keith. Great dude and great service.
    AZBoatHauler likes this.
