6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Aug 13, 2020 at 2:39 PM
    #1261
    grichg
    grichg New Member
    rich
    exactly what I am getting although getting 305 NV bronze !
    melonfan123[QUOTED] likes this.
  2. Aug 13, 2020 at 2:49 PM
    #1262
    melonfan123
    melonfan123 New Member
    Here’s mine. 6112 at top setting, 5100s in rear, 18x9 Methods on 295/70 Falken Wildpeak A/Ts
    +18
    Allrsdup and equin[QUOTED] like this.
  3. Aug 13, 2020 at 3:43 PM
    #1263
    COTundra23
    COTundra23 New Member
    Added shims (2 on drive side and 1 on non) and bumped tire size up to 285/75
    really happy with how it turned out
  4. Aug 13, 2020 at 4:04 PM
    #1264
    Kanobi13
    Kanobi13 New Member
    Looks nice 1.9 or 2.5 height? And of course any rub?
    COTundra23[QUOTED] likes this.
  5. Aug 13, 2020 at 4:07 PM
    #1265
    COTundra23
    1.9 with shims.
    renoved front and rear mud flaps an front well liner.. so, no rub anymore. Lol
  6. Aug 13, 2020 at 5:05 PM
    #1266
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    If you can’t decide between the two, then i recommend to create a list of requirements. 6112 and Kings are not in the same category of performance - and price.
    pvn.beluga and Elduder like this.
  7. Aug 13, 2020 at 5:09 PM
    #1267
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I went 6112s & 5160s- woulda went Kings for sure if it was in my (wifes) budget! HAHAHA. Im probably gonna drive this Tundra until the wheels fall off and will go Kings next go-around( about 30k from now).
    pvn.beluga and equin like this.
  8. Aug 14, 2020 at 8:53 AM
    #1268
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I just added the 5100's in the back. Gonna give it a few trips before deciding if I want to do anything else....
  9. Aug 14, 2020 at 1:10 PM
    #1269
    60av8tor
    60av8tor New Member
    Pa
    2014 MGM TRD CM
    Finally got the 6112s/5160s put on - I’ve had them since the beginning of June. My Tundra came with a spacer lift and actually sat very slightly nose high, which I really disliked. Installed at 1.3 with 1 DS shim, stock height in the back. I like the stance - wanted a slight rake (have about .5”-.75”) - and the ride is much better:
  10. Aug 15, 2020 at 5:37 AM
    #1270
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I drive on the road 99 percent of the time. Just want the best ride street wise and plan on adding an aftermarket bumper. Most offroading i do is the boat ramp...
  11. Aug 15, 2020 at 10:01 AM
    #1271
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    just get the 6112 amd 5160 then. unless you have money to burn the kings would be a waste.
  12. Aug 16, 2020 at 3:12 PM
    #1272
    RollTide82
    Michael
    2019 Tundra 4x4
    Should I do the 1.9 with shims or 2.5 and maybe drivers side shim? Much difference in ride?
  13. Aug 17, 2020 at 7:59 PM
    #1273
    Zero One Actual
    Bilstein 6112’s on top setting, no shims needed (for this truck), 18 inch Method 315’s (+18 offset), Total Chaos UCA’s, CB +2 shackles in the rear and I didn’t use 5160’s but went with the Icon reservoir rear shocks due to them having more travel. I also have firestone airbags in the rear to support Leitner cargo system and @DECKEDUSA system as well.
    Tires are Toyo AT III in 285/75R18. Zero rub anywhere in any direction. I strongly suggest people look at the Cooper AT3 XLT and Toyo AT3 285/75R18 if they are worried about rubbing or trimming. The 12.5 inch wide tire causes too many issues with this setup and the 285/75R18 is the way.
  14. Aug 18, 2020 at 7:40 AM
    #1274
    Cofeemud
    Cofeemud New Member
    Nathan
    Just ordered 2020 SR5 4x4 crewmax with TRD Sport package which will be here next week on 8/27. I am thinking about upgrade front shocks to 6112 for the 100% on road drive that I am doing. I am not into off-road nor will ever do any kind of trailers towing etc... Tires are stock 275/55R20. What settings to you suggest for me to have installer set for the 6112 shocks for what I want to do (keeping the truck as stock as possible without any kind of modification as I think modification/adjustment can be costly, also voiding warranty as it's a new truck. I am not mechanical capable nor having big pockets. Also not into lifting/jack up the truck) I will keep rear shocks "stock" for now as I think they are made by Bilstein and will eventually change its out to 5160 when they're worned out. Though, if you think I should change rear shocks to 5160 to achieve that nice pleasant car like ride, I will do so as I would prefer to upgrade shocks all at once and call it done.
    I picked the sport model for that cool look but all I really want is a nice, comfortable ride - I am not known for being able to tolerate harsh, bumpy ride; I get dizzy very easily. In summary, I just want a basic truck to travel to work and once in a while, put fishing gears on the back to go fishing, camping with family, get a few bags of soils, mulch for the wife's garden, and maybe helping out friends with hauling large household items once in a while. Your help is greatly appreciated.
  15. Aug 18, 2020 at 8:04 AM
    #1275
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    My advice to you is to drive it for a while with the stock suspension to see how you like it. The 6112's are not going to give you a "car like ride". The best way to describe how the 6112s are better over stock is how they perform on a wash board road when driving at a higher rate of speed. In this scenario they absorb the bumps much better than stock suspension and are more responsive. In most other cases they don't feel much different than the stock TRD Off-road suspension. You may be better off finding someone that has changed out their new Platinum or 1794 suspension for a lift and getting a deal from them on their takeoffs.
    Boerseun likes this.
  16. Aug 18, 2020 at 8:27 AM
    #1276
    AZBoatHauler
    So.Arizona
    How it comes from the factory will be best for on road handling - especially if you don’t want to increase the height up front.
    Boerseun and Cofeemud[QUOTED] like this.
  17. Aug 18, 2020 at 8:27 AM
    #1277
    Cofeemud
    Cofeemud New Member
    Nathan
    My truck will be with TRD Sport suspension. I tested drove the TRD Off-Road and almost vomit after the test drove. So it's not possible to have a car ride from Tundra? Or at least Lexus GX460 ride like?
  18. Aug 18, 2020 at 8:43 AM
    #1278
    MSU Tundra
    Mississippi
    The leaf springs in the rear are always going to prevent you from having a car like ride. Best thing you can do is grab some Platinum suspension takeoffs from someone that added a lift, and add a couple hundred pounds of weight in the bed of your truck with sand bags or something.
  19. Aug 18, 2020 at 8:49 AM
    #1279
    Cofeemud
    Cofeemud New Member
    Nathan
    "grab some Platinum suspension" - are you referring to rear suspension or front. Just suspension or suspension/leaf springs - keeping my stock's Sport shocks Billstein
  20. Aug 18, 2020 at 8:59 AM
    #1280
    Allrsdup
    Allrsdup New Member
    Joe
    Sooo your buying a truck and want it to drive like a car..
    Elduder likes this.
  21. Aug 18, 2020 at 9:01 AM
    #1281
    Cofeemud
    Cofeemud New Member
    Nathan
    Yup. Need storage space on the back. Sorry if I ask for the impossible.
  22. Aug 18, 2020 at 9:21 AM
    #1282
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have a TRD Sport and I think the ride is great. But it is not a car-like ride. Never will be. Never intended to be. But if you complain about the ride of a stock TRD Sport I think the problem is not with the truck.....just saying.
    Mdjamesd and Allrsdup like this.
  23. Aug 18, 2020 at 9:26 AM
    #1283
    Boerseun
    Ferdie
    Sarasota Florida
    In all seriousness - If you need a truck for the bed but want a car-like ride, I would suggest canceling the order and get a RAM (with extended warranty, but that's a different story). The RAMs have coil springs in the back and have a much better ride than most other trucks. If you upgrade to Laramie trim you get air suspension that will be closer to the Lexus GX460 ride, although not quite there; still a truck.
    Then there is also the Honda Ridgeline option - reliable and comfortable, with a bed, although most on this site don't acknowledge it as a truck. Screw them - it will give you the ride you want.
    Saltyhero13 likes this.
  24. Aug 18, 2020 at 9:26 AM
    #1284
    Cofeemud
    Cofeemud New Member
    Nathan
    "I have a TRD Sport and I think the ride is great. But it is not a car-like ride. Never will be. Never intended to be. But if you complain about the ride of a stock TRD Sport I think the problem is not with the truck.....just saying."
    LOL. When you get older, it's harder on this old body. It will be different 30 years ago for me... Please don't get me wrong - Sport is probably best ride out of all the trims, I just want more....
  25. Aug 18, 2020 at 9:27 AM
    #1285
    Boerseun
    Ferdie
    Sarasota Florida
    I understand.
  26. Aug 18, 2020 at 9:43 AM
    #1286
    Cofeemud
    Cofeemud New Member
    Nathan
    "In all seriousness - If you need a truck for the bed but want a car-like ride, I would suggest canceling the order and get a RAM (with extended warranty, but that's a different story). The RAMs have coil springs in the back and have a much better ride than most other trucks. If you upgrade to Laramie trim you get air suspension that will be closer to the Lexus GX460 ride, although not quite there; still a truck.
    Then there is also the Honda Ridgeline option - reliable and comfortable, with a bed, although most on this site don't acknowledge it as a truck. Screw them - it will give you the ride you want."
    Great suggestion - though Honda Ridgeline is kind of boring looking, the RAM always have little problems here and there. The Tundra had the look that I am very fond of and the reliability that you can count one . What's the guy to do... Suck it up and just put 200 lbs worth of sand bags on the back ???
  27. Aug 18, 2020 at 9:54 AM
    #1287
    MSU Tundra
    Mississippi
    To clarify, there are a lot of folks that buy a new Platinum or 1794 Tundra and immediately add new suspension to lift it (front struts and rear shocks). My suggestion is to be on the look out for someone doing this and ask them to sell or donate their old shocks to you. This will give you a little softer suspension than the ones your new TRD Sport will have. The only other easy thing that you can do to get a softer ride is to add some weight to the bed of you truck.
  28. Aug 18, 2020 at 10:02 AM
    #1288
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I've never ridden in a TRD Pro, but I understand its suspension supposedly makes the Tundra ride more smoothly. But the Pro suspension is kind of pricey. Other ways to smooth out the ride are to go from 20" wheels to smaller wheels (18" or 17"), lower the tire pressure a bit, maintain good alignment and tire balance, but you probably already know about those.
  29. Aug 18, 2020 at 10:04 AM
    #1289
    Cofeemud
    Cofeemud New Member
    Nathan
    If that's all it takes, I don't mind buying new OEM shocks to put in - replacing Sport shocks. Do you suggest front or rear shocks - or both?
    I can also change out to 17" wheels if that had been proven as optimal for soft comfortable ride.
  30. Aug 18, 2020 at 10:04 AM
    #1290
    equin
    Ed
    DFW, TX
    Oh, and every truck I've ever ridden in feels like a "truck." Not sure why, but my old, leaky, dented '93 full-size Ford Bronco actually rode better and more smoothly than my 1st gen Tacoma, 4Runner and Tundra ever did. Too bad it wasn't that reliable, though.
