6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Aug 3, 2020 at 8:29 AM
    #1231
    Bascott1
    Bascott1 New Member
    2018 White TRD sport
    What size tires are you running?
  2. Aug 3, 2020 at 2:38 PM
    #1232
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I have my 6112 at the top setting 2.5" lift with stock UCA. Alignment was done with no issues. I am happy with it.
  3. Aug 3, 2020 at 8:15 PM
    #1233
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    I don’t. But I’d like to do that mod.
  4. Aug 3, 2020 at 8:18 PM
    #1234
    BigLoggerhead
    Thanks. Wheels are +25mm with 6.00” backspacing. I took the little front flaps in front of the tires off. There was minor rubbing in reverse at full lock but I also installed the Coachbuilder bumper shims to get rid of that.
    toyota tom[QUOTED] likes this.
  5. Aug 5, 2020 at 4:24 AM
    #1235
    MAN N BLK
    MAN N BLK New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    I ordered 6112’s set at 1.9 for my 2015 crew max. Do I need to just go ahead and order shims? What about top mount or isolators? And I’d like to run 295/70 wildpeak at3 on stock TRD OR wheels.
    AlaskanAssassin likes this.
  6. Aug 5, 2020 at 4:40 AM
    #1236
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I’d probably order atleast one shim for the driver side. I’m gonna do the same as you in a couple of months so make sure you post some pics when you get it all done :thumbsup:
  7. Aug 5, 2020 at 6:13 PM
    #1237
    Bascott1
    Bascott1 New Member
    How was the fit with those tires? Think 275/65/20's would fit?
  8. Aug 5, 2020 at 8:52 PM
    #1238
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    whats the stock offset on the trd or rims do you know?
  9. Aug 5, 2020 at 9:57 PM
    #1239
    AZBoatHauler
    So.Arizona
    +60
    Allrsdup[QUOTED] and COTundra23 like this.
  10. Aug 6, 2020 at 3:13 AM
    #1240
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    With the offest I have, I think i would need to trim or heat the front bumper fender to prevent rubbing for 275/65's to fit.
  11. Aug 9, 2020 at 3:47 AM
    #1241
    Bascott1
    Bascott1 New Member
    Thanks. Trying to see what will fit with my stock 20’s and bilsteins set at 1.9
  12. Aug 9, 2020 at 4:27 AM
    #1242
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    -60 would make them stick wayyyyyy out they are deff not in the negatives they are +60 most likely
    Allrsdup and Boerseun like this.
  13. Aug 9, 2020 at 5:25 AM
    #1243
    AZBoatHauler
    So.Arizona
    You got me!
    cmiller219[QUOTED] likes this.
  14. Aug 9, 2020 at 5:37 AM
    #1244
    cmiller219
    Nashville, TN
    Plus negative equals damnit wrong button haha. I know you meant well and knew the answer just chose the wrong symbol haha
    AZBoatHauler[QUOTED] likes this.
  15. Aug 9, 2020 at 6:10 AM
    #1245
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    597FE6C6-4829-4782-B60B-989DAED50564.jpg 5100’s up front set at highest setting. Method NV 18x9 wheels with Falcon 305/65/18 tires. Since I put 2 dirt bikes in back, thinking about rear shackles to give it a slight rake.C57CECC4-B3C5-47B3-BCD6-0168D3C4FC91.jpg
  16. Aug 9, 2020 at 3:22 PM
    #1246
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    You should be able to fit 275/65’s you could also fit a 285/60
  17. Aug 9, 2020 at 6:24 PM
    #1247
    Allrsdup
    Allrsdup New Member
    Joe
    looks great! for carrying the dirt bikes i would just do an add a leaf
  18. Aug 9, 2020 at 8:35 PM
    #1248
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    Great, I will look into that option. I have the TRD Red&Blue Bilsteins in the back and the 5100's in the front. Is there a "best" shock for the back once the add a leaf is added?
  19. Aug 9, 2020 at 8:58 PM
    #1249
    grichg
    grichg New Member
    rich
    Im getting my 6112 installed the 20th by Westcott in AZ with 295/70/18 Wildpeaks
    MAN N BLK and AZBoatHauler like this.
  20. Aug 9, 2020 at 9:03 PM
    #1250
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    What are you doing to the back, if anything?
  21. Aug 9, 2020 at 9:05 PM
    #1251
    grichg
    grichg New Member
    rich
    Jeff recommended just 1" spacers in our 1st stage talks but I think we need to chat more about that. I had Deaver Built AAL and Fox w/res. on my tacoma before. Just got a Tundra last week so building up.
  22. Aug 9, 2020 at 9:13 PM
    #1252
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    I'm in the same boat, just got mine last weekend. I went with 5100's up front and running the stock TRD Bilsteins (red and blue) in the back. Looking for the best option to raise the back a bit so when I put 2 dirt bike in the back it is pretty much level.
  23. Aug 9, 2020 at 9:15 PM
    #1253
    grichg
    grichg New Member
    rich
    You cant go wrong with Deaver and they can tailor the build to what you need. If your in So Cal I would go buy and chat with them..
    I carried a load in the bed with a moto on a Joe Hauler alot
    KTMRider[QUOTED] likes this.
  24. Aug 11, 2020 at 4:05 PM
    #1254
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Still can't decide between 6112s and Kings....wish I could test both...lol
    pvn.beluga likes this.
  25. Aug 11, 2020 at 8:15 PM
    #1255
    BigLoggerhead
    Coachbuilder rear shackles are another option. They have 3 different lift heights. I’m currently running the +2 which provides 1.25” of lift.
  26. Aug 11, 2020 at 8:32 PM
    #1256
    grichg
    grichg New Member
    rich
    quite the range
    COTundra23 likes this.
  27. Aug 13, 2020 at 6:17 AM
    #1257
    RollTide82
    Michael
    2019 Tundra 4x4
    Does anyone have a winch/bumper with this combo....guess that is a difference maker for me also...
  28. Aug 13, 2020 at 1:36 PM
    #1258
    melonfan123
    melonfan123 New Member
    I have a friend in Huntington Beach that is selling a Deaver set up - leaf springs with new bushings, shackles, U-bolts etc. He's a fellow dual-sporter as well. Will raise 1" or so and supposedly a much better ride than stock.
  29. Aug 13, 2020 at 1:39 PM
    #1259
    melonfan123
    Here’s mine. 6112 at top setting, 5100s in rear, 18x9 Methods on 295/70 Falken Wildpeak A/Ts
  30. Aug 13, 2020 at 2:05 PM
    #1260
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Nice! What offset are those Methods?
