6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jul 6, 2020 at 5:32 PM
    #1171
    AZBoatHauler
    So.Arizona
    Truck looks amazing. Well done.
    :101010:
    JDHolliday27[QUOTED] likes this.
  2. Jul 6, 2020 at 5:33 PM
    #1172
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Bad ass how is the ride?
  3. Jul 6, 2020 at 6:30 PM
    #1173
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Looks great!
    JDHolliday27 likes this.
  4. Jul 7, 2020 at 6:35 AM
    #1174
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    Early impressions are good so far. I can definitely tell a difference between the P-rated stock Michelin's and stepping up to a 10-ply LT tire. The truck feels solid going down the road, but the ride is noticeably more firm.
  5. Jul 8, 2020 at 10:19 AM
    #1175
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
  6. Jul 8, 2020 at 10:26 AM
    #1176
    Quicksand_Tundra
    Jon
    The TRD Center Cap makes the SCS SR8 wheel look awesome. :D
    316KS_Runner likes this.
  7. Jul 8, 2020 at 12:22 PM
    #1177
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    what setting do you have for the front and rear? tire size?
  8. Jul 9, 2020 at 8:01 AM
    #1178
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Mine took some time too break in. I drove about 2500 highway miles and the front end was extremely harsh. I was very disappointed. Went on a weekend trip to the ranch where I was able to stretch the legs. After that the truck rides like OEM again but handles bumps and obstacles a lot better.
    I’m currently shopping for a 2020 platinum and plan to add Bilsteins to it also
  9. Jul 9, 2020 at 9:21 AM
    #1179
    JDHolliday27
    2018 CM
    Thanks, yea I've had the Bilsteins on for over a year now and they've been great. I just recently replaced the stock wheels and tires, so my post was in relation to the ride quality after upgrading to an LT tire.
  10. Jul 9, 2020 at 12:40 PM
    #1180
    Quicksand_Tundra
    Jon
  11. Jul 9, 2020 at 12:47 PM
    #1181
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    1st gen tundra 6112 up front 5120 rear. What setting should the 6112 be at for stock height? Do I need driver/passenger different settings as well?
    Thanks. (thread too long to read!)
  12. Jul 9, 2020 at 1:08 PM
    #1182
    AZBoatHauler
    So.Arizona
    Do they make 6112 for 1st gen? Pretty sure they only fit 2007+.
  13. Jul 9, 2020 at 2:13 PM
    #1183
    robabeatle
    AZ
    They work for the 1st gen. I think this is it:
  14. Jul 9, 2020 at 2:17 PM
    #1184
    AZBoatHauler
    So.Arizona
    In that case, not sure if it is different for 1st gen but all settings provide some lift for 2nd and 3rd gens. I believe lowest is +.75", second lowest is +1.3", second from top is +1.9" and top setting is +2.5". You should set both sides to the same height.
  15. Jul 9, 2020 at 2:34 PM
    #1185
    robabeatle
    AZ
    Most what I read and from the chart above has two different setting due to the gas tank being on the drivers side, creating a difference in suspension load that can be "remedied" by having different setting on each side.
    I know nothing about 2nd and 3rd gen but pretty sure my info on 1st gen is correct. But now I'd love a confirm from someone.
    Also, I was going to have a friend put these on as he has a full shop. It wouldn't be free. But since I am buying the coilovers assembled, it seems that this is a job that a shadetree mechanic could do. Looks like the hardest thing up from is to get out the lower bolt that holds on the coilover. Thoughts? I haver jackstand, jack, breaker bar, sockets.
  16. Jul 9, 2020 at 2:46 PM
    #1186
    AZBoatHauler
    So.Arizona
    I used a Coachbuilder shim on the driver’s side to compensate for the lean but I also have the 38 gallon tank. Smaller tanks probably don’t need the shim. Does your truck sit level side to side now?
    I’ve only seen one person on here set the coil overs at different heights...
  17. Jul 9, 2020 at 2:51 PM
    #1187
    robabeatle
    AZ
    I just measured and it is level. Frankly, the vendor is assembling the coilover and on the phone we discussed and he said #3 and #1 setting which agrees with all that I am seeing. And I decided to just let my friend put these on as there can be tricky parts here and there and it is too dang hot here to work outside for hours on suspension.
    So looking forward to getting rid of the crappy monroe shocks and going right to the 6112/5120. Hoping for a big improvement in ride quality.
  18. Jul 10, 2020 at 5:32 AM
    #1188
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    @robabeatle I was having similar thoughts and uncertain on how to counter the lean on my 2017 crewmax. I ended up setting drivers side at the 1.9 setting and passenger side at 1.3- It worked out great for me. @dirtydeeds is a buddy and explained the reasons best and walked me through it. Recommend you give him a call to discuss - his knowledge and experience run deep.
    I had initially set both at the 1.3 setting and had 3 CB shims on standby in my garage. I did not install shims and did have a very noticable lean. I went with adjusting the drivers side to the 1.9 setting although I could have adjusted the passenger side to the .75 setting for similar results. I ended up not needing to left the rear (CB shackles) as the truck leveled with .75" rake and that was my goal. I have since installed 17" wheels with 295/70r17s (Mickey Thompson ATZ - 33.3 x 12). I love the wheels (Method 701) and the tires are great on the highway and the light trails I have run on. I can feel the additional weight though and MPG dropped to about 13 or so but well worth it in my opinion. Good luck man.
    robabeatle likes this.
  19. Jul 11, 2020 at 8:10 AM
    #1189
    Kanobi13
    Kanobi13 New Member
    6112 1.9. 2 CB shims driver 1 passenger +3 CB rear. 275 70 Wrangler ray 10s20200711_075035.jpg
  20. Jul 13, 2020 at 10:20 PM
    #1190
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Silver Tundra Crewmax Limited 4x4
    any rubbing?
  21. Jul 13, 2020 at 10:38 PM
    #1191
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Toyota Tundra Crewmax Limited 4x4
    Looking for advice...
    I am thinking Bilstein 6112/5160
    +2 Shackle (I want to roughly keep factory rake)
    Some say to do driver side CB shims just don't know what size (I have 38 gallon gas tank and don't want it to lean)
    Im hung up between 18x9 or 17x9(Input welcome)
    With that size rim and a approximate 3" lift what tires would fit without rub and won't destroy mileage.
    are is there a negative to setting shock at highest setting?
    I do tow a 6,000lbs trailer so I don't want to have it effect towing. (input welcome)
  22. Jul 14, 2020 at 1:51 PM
    #1192
    robabeatle
    AZ
    I guess I can join this thread now: 6112 up front 5120 out back. 2002 access cab, Stock height
    I set the preload to #3 on drivers side and #1 on passenger side and I am getting every opinion under the sun about whether that is the right way or to put in a shim on the driver side and get the preloads the same.
    Thought that the shim idea was a minority opinion. Reached out to coachbuilder and got a call back, but missed it. David left a voice mail saying that a shim is the way to go.
    Wow. Confused.
  23. Jul 15, 2020 at 5:20 PM
    #1193
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    Just installed my 6112's this past weekend after having them sit in the box in my living room for over a year.
    Love the ride, but now my 275/65/18 look a wee bit small.
    I'm currently at 1.9" and would prefer to stay there. Wondering if anyone is running.rhem at 1.9 with a 285/75/18 on factory 60 offset?
  24. Jul 15, 2020 at 6:54 PM
    #1194
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    That is a picture of how it sits right now with the lift? That looks nice! I want the same thing but I might run it higher with 285s but with 2” shackles in rear
    TOYOTARIG likes this.
  25. Jul 15, 2020 at 7:49 PM
    #1195
    Mdjamesd
    Mdjamesd New Member
    Yup, 6112 at 1.9", 5160 in rear on 275/65/18.
    I'm still considering shackles in the rear, but waiting for.front to settle before I do anything else.
  26. Jul 16, 2020 at 8:07 AM
    #1196
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    I did have some rubbing, yes. Had to trim/push out plastics but no rubbing on cab mount or anything like that. Also only rubbed in reverse.
  27. Jul 16, 2020 at 10:29 AM
    #1197
    Maxtor
    Maxtor New Member
    Mark
    Thanks to everyone who has contributed to this thread, a lot of reading but has been very helpful. Going to go with the 6112/5160 combo. One question I did not see in the past 41 pages... is anyone with this combo using the firestone (or equivalent) airbags? I may be more inclined to keep it close to level but am concerned about it pointing to the sky when pulling my trailer. Some rake would be ok but would like to reduce the amount it has now.
    Thoughts?
    COTundra23 likes this.
  28. Jul 16, 2020 at 11:57 AM
    #1198
    COTundra23
    COTundra23 New Member
    I personally am not running airbags but instead decided to go with Toytec Shackles. Airbags are adjustable on the fly (with an air compressor) and probably a better option if you are towing a lot of weight. My 1" shackles hold up fine for the dirt bikes, four wheelers and boat. That is just my personal experience and have been happy. have about a 1-1/2" rake and currently setup at 1.9" up front and 1" in the back.
  29. Jul 16, 2020 at 6:51 PM
    #1199
    Maxtor
    Maxtor New Member
    Mark
    That is exactly the setup I was going to put in... thank you. The 5160’s may help some. I’m pulling 7-10k lbs and sometimes get more on the hitch than I should. Was just worried about getting it too level and making the front end poke up even more. Trying to stay away from a diesel for my DD since I also do a lot of town driving and like the size of the tundra vs a 3/4 ton.
    COTundra23[QUOTED] likes this.
  30. Jul 16, 2020 at 7:15 PM
    #1200
    Mdjamesd
    Mdjamesd New Member
    I can't think of any reason you couldn't run airbags. As long as you use them as an " overload spring" of sorts. I would think that you could.even pair airbags as an overload, with shackles for lift. Just make sure you don't over-extend the 5160's. And as I've read on here numerous times, you may be better served running the Daystar cradles with the airbags to allow you greater leniency with air pressures
