6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jun 25, 2020 at 6:20 AM
    #1141
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Anyone run 6112’s up front and stock TRD offroads in the rear? Was thinking of doing that. Probably gonna only set the 6112’s at 1.3 so it will still fit in the garage.
    TelemarkTumalo and georgiey22 like this.
  2. Jun 25, 2020 at 1:05 PM
    #1142
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    crazy how a 3" lift on Tundra's make 35's look small. I had a fully built '14 Tacoma before my current Tundra, and I had to saw all kinds to allow my suspension to fully cycle on 33's.
    should be fine if you don't modify the rear suspension with AAL/shackles. but if you're getting 6112's, you'll definitely notice a difference even with a cheap upgrade to 5100's in the rear (and no additional lift).
  3. Jun 25, 2020 at 1:12 PM
    #1143
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    your truck has a nice stance though. I had the Icons on my Tacoma before swapping out the whole pack, and I loved it. I see so many mixed reviews on the Icon mini pack, from bad fitment into the stock pack to 0"-0.5" of lift or >1.5" of lift. I'm guessing it's just due to the blanket fitment (i.e. 2007+) and the differences in weight of each model. if I can get 1" rear lift on my CM, I'd be happy.
  4. Jun 25, 2020 at 1:23 PM
    #1144
    COTundra23
    COTundra23 New Member
    If you don’t want the mini pack, I went with Toytec shackles and have been happy. Currently set at 1” but have a 1.5” as well. This is at the 1.9” up front and 275/70. Not the best photo since it’s on a down slope but gives you an idea of the rake which is close to 1” after measuring
  5. Jun 25, 2020 at 4:43 PM
    #1145
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Ha. I heard that about the garage door clearance. I had similar concerns. Fortunately, mine is having no clearance issues in height. I just wish my garage was 14 ft. wider and 10 ft. deeper. I don't see any problem with running the stock TRD sport shocks in combo with the 6112's. The height will be the same. If the rear feels soft afterward, you can always add 5100's or 5160's later. I think the benefit is in the 6112's up front.
  6. Jun 25, 2020 at 11:13 PM
    #1146
    Kanobi13
    Kanobi13 New Member
    Are the 6112 directional? I am having issues getting bottom bolt installed
  7. Jun 26, 2020 at 3:53 AM
    #1147
    CaptainGrumpus
    Maine
    I literally have 4 inches to the roof and probably 10 inches in the front after I back into the garage. I do have a workbench in the back that I’m gonna move to get more space but I can’t do much about the height.
  8. Jun 26, 2020 at 7:31 AM
    #1148
    TelemarkTumalo
    Mark
    Bend, OR
    For comparison, I have standard 7' garage door opening. With the 6112's set at highest setting (2.5") and with the 285/70 R18 tires, my 2018 has a max height of 80". So, I have 4" clearance for entering the garage. The Falkens added about 1" to the height over the OEM Michelins. I didn't record the height of the truck before adding the Icon MiniPack to the rear springs. But, it increased measurement between the top of the tire and the fender by 1.25".
  9. Jun 26, 2020 at 7:53 AM
    #1149
    TheHansen
    TheHansen New Member
    19 MGM TRD off-road Limited
    Seriously. It looks more proportional in person though. I wouldn't go any bigger without a cab mount chop and moving or replacing the front bumper. Right now I'm still rubbing the front inner fender just barely while backing up and turning and I'm getting very close (about a half inch) to the cab mount. This truck won't see any level of off-road like i did with my tacoma though. So just needs to be enough to not rub on road.
    Also my 295/70/18 spare fit snugly under the bed. Just had to bend one of the brackets that guide the spare up. Used a jack and a stack of lift spacers to just jack up on the bracket to bend it.
    My 05 tacoma on 285s had to have lot's cut up to not rub too. Ended up with all pro bumpers in the end (and because of a deer...) Never seemed to have issue with being close to the cab mount at all. Maybe i got lucky. It's at .85 front lift now still with the 285s. Had to put the spc arms adjusted all the way forward. I'm sure my alignment sucks but it barely leaves the backroads now.
  10. Jun 26, 2020 at 8:20 AM
    #1150
    TRDOBSESSED
    TRDOBSESSED New Member
    2017 metallic gray SR5 TRD Offroad
    6112's at 1.9 . Two CB shims driver , one passenger . 5160's. Toytech one inch rear shackle . Cab mount chop and trim skid plate wings . 285/75/18 Wildpeaks . Truck looks bigger then i thought it would turn out . Very happy !
  11. Jun 26, 2020 at 10:20 AM
    #1151
    CaptainGrumpus
    Maine
    thanks for the info/feedback. I’m gonna measure my garage opening again when I get home. My door hangs a little low so maybe I’ll take to a garage door installer that I know about trying to fix that. I’d really like to add a couple inches up front to even level out the truck.
  12. Jun 26, 2020 at 12:29 PM
    #1152
    E_Shaw88
    E_Shaw88 New Member
    Evan
    Tulsa, OK
    2020 Black Tundra TSS Off-Road
    Need everyone's advice. I am looking to install 6112/5160 combo at top setting, shim on each side, shackle on the back, and upgraded UCA's.
    I was quoted ~$1,000 for install and alignment. This is my first truck so I am unsure if this is a fair price, seems a little high to me as its just for labor.
    I am unsure if I can do the install of everything myself, mainly due to limited tooling and not a tremendous amount of experience on vehicles other than brakes.
    Is this a decent quote for install or continue to look around? This shop really is the only option for correct alignment but others out there in my area to call for install.
  13. Jun 26, 2020 at 12:39 PM
    #1153
    RobertD
    Robert
    DFW, Texas
    I know in the DFW area most places charge about 100 an hour, but just doing 6112s/5160s shouldn't take them long. I would expect 4 hours max plus cost for alignment.
  14. Jun 26, 2020 at 12:45 PM
    #1154
    E_Shaw88
    E_Shaw88 New Member
    Evan
    Tulsa, OK
    The guy quoted 3 hours for the front and 3 for the back, which seemed like a lot but wasn't real sure. Not sure if that's due to the UCA's, diff drop kit, and shackle. He mentioned it could be difficult to get the bushings out but since it was a brand new truck he hoped it wouldn't.
  15. Jun 26, 2020 at 12:53 PM
    #1155
    Racingpug
    Racingpug New Member
    Hi! Just wanted to share the 6112 at 1.3 setting with no shim. Got a 1/2 inch lean tought. Removed mud flap and pushed the front liner but no rub on body mounts. Stock uca and 295 70 18 on 18×9 et 25 methods. Rear is stock no lift but with pro comp 2.5 resi instead of 5160. Wanted a rear 2.5 without breaking the bank.
    Elduder, 68 RS/SS, dpast88 and 3 others like this.
  16. Jun 26, 2020 at 1:09 PM
    #1156
    E_Shaw88
    E_Shaw88 New Member
    Evan
    Tulsa, OK
    What did you do with the rear setup? Did you do need to do the Diff drop, carrier bearing drop kit, and bump stop extensions?
    Your truck is exactly what I am looking for and would prefer to not have to put new UCA's on just yet.
  17. Jun 26, 2020 at 2:47 PM
    #1157
    cmack
    cmack New Member
    AZ
    2018 Burrito
    5160s in the rear with toytec shackles set at 1.5” for a rake, which I prefer for towing and hauling and to keep all the sensors happy.
    Haven’t bothered to do bumpstops yet, but I’m sure will replace at some point. No drops either
  18. Jun 27, 2020 at 7:37 AM
    #1158
    TelemarkTumalo
    Mark
    Bend, OR
    Looking good.
    TRDOBSESSED[QUOTED] likes this.
  19. Jun 28, 2020 at 5:24 AM
    #1159
    COTundra23
    Looks good! Any rubbing up front? I’ve been running 275/70 but want to bump up to 285/75..
  20. Jun 28, 2020 at 6:31 AM
    #1160
    TRDOBSESSED
    Thanks man ...Had to take mudflaps off ...cab mount chop and trim skid plate ...totally worth it
    COTundra23[QUOTED] likes this.
  21. Jul 3, 2020 at 11:17 PM
    #1161
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Silver Tundra Crewmax Limited 4x4
    question with 37x12.5R20 what kind of fuel economy you get? That looks sick! Do you notice any power loss?
  22. Jul 4, 2020 at 12:21 AM
    #1162
    hammockking
    hammockking New Member
    Scotts Valley, Ca
    2012 Tundra Platinum 4x4
    Workin' on em
    Got my 6112/5160 set up on with SCS Stealth Custom SR8 wrapped in 285/75r18 Goodyear Duratracs. I got new top hats for the 6112s at 1.9, and got 1.5” uniball camburg UCAs above that. Slapped on two CB .5” shims on driver side and one CB .5” on passenger side. Rear is also sitting on a deaver mini pack.
    Carrier drop, diff drop and SDHQ body mount chop to get it all running right.
    Plan was to install it all before a big birthday trip, but ran short on time and went to a local, reputable shop.
    When I picked her up, I got these parts back and am now wondering if they forgot to put the new top hat bushing on top of the strut assembly when putting the new 6112s together. Or, are these extras? Can’t figure out how that’d happen, or how I wouldn’t have noticed by now, but also can’t ignore that these are sitting right in front of me.
    First some glamour shots, then some height and alignment numbers, and finally the parts I need help with.
  23. Jul 4, 2020 at 8:38 AM
    #1163
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    It’s been awhile since I did my install but those look like the parts for the 5160 bushings in the rear to me. Will send photos shortly for reference.
  24. Jul 4, 2020 at 8:50 AM
    #1164
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Those parts belong to the rear shocks
  25. Jul 4, 2020 at 10:51 AM
    #1165
    hammockking
    Scotts Valley, Ca
    Workin' on em
    The rear? Where would those bushings and washers go?
    Better pics of the parts and mounted rear shocks for reference.
    8F671A44-E4A8-4933-A731-D9349B098785.jpg A019898C-0CED-499B-9DCA-9DDD906F35DE.jpg 88F8A499-D028-4069-894E-85F60DE68B5E.jpg
  26. Jul 4, 2020 at 11:06 AM
    #1166
    AZBoatHauler
    So.Arizona
    At the top. We should see them in your last pic.
  27. Jul 4, 2020 at 12:48 PM
    #1167
    hammockking
    Scotts Valley, Ca
    Workin' on em
    9B91C7EC-13C7-4E3A-97C4-71729552A669.jpg 658A7332-1D8A-4ED3-81DA-C1A6BE35B6C5.jpg
    Does it look like they reused the old ones or is it missing all together?
  28. Jul 4, 2020 at 1:56 PM
    #1168
    WestexSBK
    The top. They reused the old ones. How many miles were on the original shocks? I wouldn’t sweat it unless your truck had high miles
    hammockking and georgiey22 like this.
  29. Jul 4, 2020 at 2:22 PM
    #1169
    georgiey22
    They used the old ones.
    hammockking likes this.
  30. Jul 6, 2020 at 5:30 PM
    #1170
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    Finally got around to replacing the stock wheels and tires. SCS SR8 with Cooper AT3 XLT 275/70/18. Front is 6112's @ 1.9" setting with 1 CB shim on driver side and 5160's with CB +2 shackles in the rear.
