6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Mar 25, 2020 at 8:16 AM
    #991
    Lynch Mob
    Lynch Mob Lynch Racing
    2014 Toyota Tundra Platinum
    TRD Dual Exhaust, 2 1/2" Lift, TRD Rear Sway Bar, Custom Painted Wheels, Nitto Terra Grappler A/T 305/55/20, Fender Flares, Extang Solid Fold 2.0 Tonneau Cover, Spray On Bedliner, Tinted Windows, LED Puddle Lights
    Thanks for posting this, those look a lot like mine except they are closed and not open ended.
  2. Mar 25, 2020 at 6:16 PM
    #992
    recomr
    recomr New Member
    Got my spidertrax 1.25 on. I have a post a little further up detailing my set up. Rubbed only on the fender liner and mud flaps. Heat gun fixed it! Nice!
    Had to move furniture and rolled the Softopper down. I like how it looks without (at least on my white truck) but it’s so useful.
  3. Mar 26, 2020 at 4:28 PM
    #993
    RelentlessFabrication
    RelentlessFabrication relentlessfabrication.com Vendor
    Sparks, NV
    Thanks for choosing our CMC plates. Great progress on the build!
    Relentless Fabrication
    www.relentlessfabrication.com
    Lynch Mob[QUOTED] and Rica25 like this.
  4. Apr 4, 2020 at 7:45 AM
    #994
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Finally going to get my 6112/5160 installed along with shackles set at 1.5", SPC UCAs, Fuel Vector 20x9+20, Nitto Terra Grapplers 35x11.50 (true size 34.53x11.42) and looking for anyone who has installed the 6112 on a 4x2 Tundra. What setting did you use? What height did you actually get? Do I need to install any shims in order to clear this tire size? Not wanting to do a BMC just plastic trimming. Thanks
    Found this chart at @Toytec Lifts
    equin likes this.
  5. Apr 4, 2020 at 8:07 AM
    #995
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Honestly you might have wanted to set yours at the 2.1 setting not the 1.5 if you are already worrying about clearance issues. I am not too familiar with the 4x2 though. I think the questions you are asking may should have been asked before you purchased your lift in order to get exactly what you needed or wanted in order to fit the tire size desired.
    Boerseun likes this.
  6. Apr 4, 2020 at 8:08 AM
    #996
    cmiller219
    Nashville, TN
    This looks great. Appears to sag a little in the rear but not bad. Good looking truck
    AK-in-MI[QUOTED] likes this.
  7. Apr 4, 2020 at 8:21 AM
    #997
    YotaTruckLtd
    2014 MGM Limited CM
    the shackels are set at 1.5 not the 6112s. thanks though.
  8. Apr 5, 2020 at 2:12 PM
    #998
    JOrnelas
    JOrnelas New Member
    2020 Black Tundra TRD Sport
    Any rubbing on this set-up?
  9. Apr 5, 2020 at 6:01 PM
    #999
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    19 dc limited non trd
    6112’s at 1.9
    Stock rear with 5160’s.
    Currently have 285/65r18 ko2’s on trd pro wheels. I see that stock pros can fit a 295/70r18 with 2” front lift....can I fit those as well? I know 275/70r18 is the safe bet but I’ve ran those on a stock 16 trd in the past. Also tossing around the idea of camburg UCA’s.
    Rica25 likes this.
  10. Apr 7, 2020 at 9:43 AM
    #1000
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would suggest that you measure your rake before anything is installed. These trucks are all different. Once you have your baseline, and you know where you want to be, it would be easier to make the decision.
    i.e. if you want to level you will probably have to be at one of the top settings, since standard rake is in the 1 to 1.5" range, so on top of the 1.5" shackle you need to add whatever your rake is to get to the final front setting. If you want to keep your rake the way it is but want to add lift, then the front need to be set to as close to the shackle's 1.5" as you can get, either the 1st or 2nd setting.
    Rica25 and YotaTruckLtd[QUOTED] like this.
  11. Apr 7, 2020 at 8:20 PM
    #1001
    huboverland
    huboverland New Member
    2019 Tundra Platinum 4x4
    6112s at 1.9, 5160s with Coachbuilder shackles 1”. 285/75r 17 on Icons.
    Had to remove front flap on stock bumper, no other rubbing.
  12. Apr 18, 2020 at 4:40 AM
    #1002
    Stig
    Stig New Member
    As far as how much work is needed to fit 295/70/18 on +25, is there a big enough difference between 1.9 lift plus 2 shims driver and 1 passenger, versus 2.5 with just one shim driver?
    Trying to decide 6112 setting. I don't mind having to do some work on the plastics or skid plate. Just wondering if I can expect about the same amount of work for these two options or if that extra .3 inches would make it way easier.
  13. Apr 18, 2020 at 5:24 AM
    #1003
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Just finished installing my leveling kit from @BOSS4x4s. Really happy with how it turned out. I had a 2” rake before and now have a 1” rake. Ride is much better than stock - more assured handling, less shaking and bounce, less brake dive, and the rear end doesn’t squat on takeoff. Corners great.
    Installed 6112s @ 1.9” with 2 shims on driver side and 1 shim on passenger. 5100 rears, ToyTec shackles on 1” setting and new poly bushings. TRD Pro wheels with 275/70R18 Falken Wildpeak AT3s.
    My measurements from wheel hub to fender:
    Front: 22-1/2” before, 24-1/2” after.
    Back: 24-1/2” before, 25-1/2” after.
    Overall very happy. The install was fairly straight forward. Removing the rubber bushings from the leaf springs was a pain even with renting a ball joint press. Just had an alignment and drives great.
    B587DF92-7B46-4A96-A63F-9E83282D4CA5.jpg EDECE329-4CC4-4DD1-9DD6-3D7DD53C9CD0.jpg
    Ronsofury, dpast88, samdubie and 4 others like this.
  14. Apr 20, 2020 at 6:36 PM
    #1004
    YotaTruckLtd
    2014 MGM Limited CM
    Finally got my setup installed today.
    6112s set at 2.5 with 1 @BOSS4x4s shim on drivers side.
    5160s with @BOSS4x4s shackles set at 1.5.
    20x9 Fuel Vectors +20 offset with Nitto Terra Grappler G2 35". SPC UCAs.
    Ride is great compared to stock.
    20200420_192335.jpg 20200420_192554.jpg 20200420_192404.jpg 20200420_192445.jpg
  15. Apr 20, 2020 at 6:54 PM
    #1005
    AZBoatHauler
    So.Arizona
    Looks great! What headlights are those? 2018 Black version or chrome LED?
    Rica25 likes this.
  16. Apr 20, 2020 at 7:01 PM
    #1006
    YotaTruckLtd
    2014 MGM Limited CM
    Just checked my order from Toyota of Cool Springs and they are the 2018 Black housing LEDs. Part# 811100c210 and 811500c210
    Rica25 likes this.
  17. Apr 20, 2020 at 11:48 PM
    #1007
    mightyowl
    mightyowl New Member
    Does your 275/70/18 rub at all with the 1.3 setting?
    How come you didn't go 1.9?
  18. Apr 21, 2020 at 7:58 PM
    #1008
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    My initial setup: Getting ready. Will post up before and after photos soon. These are custom Bilstein.
    -Bilstein 6112 @ 1.9in
    -Bilstein 5160
    -TRD style clamps
    -Coachbuilder Shackles +2 (1.25 in) lift
    -Coachbuilder Shim (0.5 in) for Driver Side
    -Coachbuilder Front Bumpstop Extension
    -SumoSprings BumpStop
    -Zone Offroad UCA
    -TRD Front Sway Bar
    -Toyota Tundra Quicksand CM
  19. Apr 21, 2020 at 8:51 PM
    #1009
    AZBoatHauler
    So.Arizona
    Good choice. I’m set the same minus the sway bar and UCAs. Love the ride and stance.
    Rica25 likes this.
  20. Apr 21, 2020 at 9:48 PM
    #1010
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    :thumbsup:
    When did these start coming with Toyota markings?! Nice touch bilstein!
    Rica25, Bakelite and Big J like this.
  21. Apr 22, 2020 at 11:39 AM
    #1011
    Quicksand_Tundra
    Jon
    Wait till these are installed. I have a surprise to finish it off. :)
    Rica25 and Flyinryank like this.
  22. Apr 22, 2020 at 6:37 PM
    #1012
    Glorified_G
    Glorified_G New Member
    2015 SR5 CM TRD
    I don't have the answers to your questions, but I just have to say that your wheel, tire, fender flare setup is exactly what I've been looking for. What is your offset on those wheels? Are those Bushwacker flares?
    Rica25 likes this.
  23. Apr 23, 2020 at 8:02 PM
    #1013
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    Looks really good!! Can you share some pics from the front/back? Looking to see how far the tires stick out.
  24. Apr 23, 2020 at 8:08 PM
    #1014
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    Any rubbing with those 35s????
    TRDblvd likes this.
  25. Apr 24, 2020 at 3:15 AM
    #1015
    YotaTruckLtd
    2014 MGM Limited CM
    No rubbing or cutting at all. Just removed front and rear flaps.
    toyota tom likes this.
  26. Apr 24, 2020 at 11:49 AM
    #1016
    itsBryantP
    itsBryantP New Member
    B
    just a little bit of rubbing on the front mud flaps & fender liner. .
  27. Apr 24, 2020 at 1:39 PM
    #1017
    Tibetan Nomad
    Tibetan Nomad New Member
    That color combo works so niceeeee! :):hattip:
  28. Apr 24, 2020 at 1:54 PM
    #1018
    Tibetan Nomad
    Whats the spring that comes with 6112 for Tundras, rated at?
  29. Apr 24, 2020 at 4:09 PM
    #1019
    AZBoatHauler
    So.Arizona
    My recollection is 600. I believe the stock Toyota coils are 700.
    Tibetan Nomad[QUOTED] likes this.
  30. Apr 25, 2020 at 6:29 PM
    #1020
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    It depends on the manufacturer, Nitto and Toyo 295/70/18 are true 34.3 inches!
    CCLJ03 likes this.
