6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jan 10, 2020 at 12:22 PM
    #781
    Primalbryan
    Primalbryan New Member
    2019 Limited Tundra Off-Road TRD- White
    TRD dual exhaust
    How much weight do you think that is in the rear? Because right now you’re more than likely already sagging a good inch or two from stock, you might need to add 1”shackles to get level even with the 1.3 setting. I have between 500-600lbs constant load, the AAL got it level and I’m still going to add 1” shackles for a slight rake
    Rica25 likes this.
  2. Jan 10, 2020 at 12:45 PM
    #782
    Stig
    Stig New Member
    It's rear high with stock suspension but definitely sagged a bit with the cap and fridge. I'll just have to measure before setting the snap ring. I'm hoping 1.3 will leave some rake.
    I forget what the cap is supposed to weigh but I probably have 250-300 lbs in total
  3. Jan 10, 2020 at 1:25 PM
    #783
    Primalbryan
    TRD dual exhaust
    Nice. Thankfully the shackles are easy to install after all the other suspension work is done. I’d recommend just getting everything on at 1.3” and then adding shackles after if you need it, which you probably will. I’m surprised at how sensitive the tundra rear end is to weight.
  4. Jan 10, 2020 at 1:40 PM
    #784
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    OP here, I started this post after buying my 2017 but traded a couple of weeks ago for a 20. I just placed my order for 6112/5160 set at 1.9"!! I forgot to order a shim for the drive side or possibly two and one for passenger :facepalm:but I've got time as it'll be a little bit before install and I still have to make up my mind on tire size. I had 275/70 Ridge Grapplers on stock OR wheels and stock suspension with the 17. More than likely go that route but contemplating 285/70 (damn they're expensive) or 295/70 with bumper shims and Bora 1.25" spacer we shall see. Thanks for all who have contributed to this thread and those who will in the future. Don't know why it took me this long but I'm pretty excited now.
  5. Jan 11, 2020 at 6:28 AM
    #785
    Stig
    Stig New Member
    I looked up the weights, I have closer to 350 lbs all the time in the bed. Maybe a new leaf pack is in order
    Rica25 likes this.
  6. Jan 11, 2020 at 9:15 AM
    #786
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    6112 up front at 1.9” with 5100’s in the back. Found some brand new 20x9 fuel ripper’s (not sure what offset) on Craigslist for a great price. 275/60 falken wildpeak. Would like to bump up to a 285/60r20 60392A3E-5FDA-4F41-A6A7-FAE82E95A434.jpg738FD651-E5C5-480B-9253-DF21C20E015C.jpg 9C020A0D-3DF0-41DE-99C7-16E995318013.jpg
  7. Jan 11, 2020 at 9:22 AM
    #787
    Cpa757va
    Cpa757va New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    EF359BCB-D4C9-44B7-B6F7-0D973F227359.jpg 80783FBE-0921-41E3-91DD-8276FAFACD5C.jpg D00A822E-37E8-432F-A075-128DA358550D.jpg Pulled the trigger and got 6112’s installed yesterday. Didn’t want anything drastic so i went 1.9” in the front and put 5100s on the rear. Next up is tires and rims. Thinking of running 295/60/20 with a +25 offset method NV and hope i don’t need to do anything drastic other than some minor trimming.
    Rica25 and drobb like this.
  8. Jan 11, 2020 at 2:12 PM
    #788
    BrennanC0212
    BrennanC0212 New Member
    Brennan
    Atlanta, GA
    2014 Toyota Tundra Platinum - White
    Just installed the 6112 at 2.5” with one CB shim drivers side and 5160 in the rear! Tires are 35x12.5x18 Nitto Ridge Grapplers on 18x9 SCS Ray 10s
  9. Jan 12, 2020 at 9:49 PM
    #789
    Subydude007
    Subydude007 New Member
    Washington
    2017 MGM CM Platinum 4X4
    -Tint -TRD Pro shifter -2018 TRD Pro LED headlights -Morimoto fogs -Remote start -6112s plus shims in front, 5160 plush shackles in rear -Diff drop -CB drop -Icon 6speeds -BFG KM3 315/70-R17
    • 6112s, top setting, 2 shims drivers side, 1 shim passengers side
    • 5160s
    • SPC UCAs
    • Diff drop
    • CB drop
    • Icon 6 speed 17” wheels
    • BFG KM3s 315/70R17
    Before:
    After:
  10. Jan 13, 2020 at 6:35 AM
    #790
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Where did you take it for an alignment? I made the mistake of taking mine to big box stores and they got it wrong both times. On my third attempt I went to my local 4x4 shop and they got it right. They even fixed a seized cam bolt I had for dirt cheap. Make sure to go to a specialty 4x4 place since they know what the hell they are doing.
    Rica25 likes this.
  11. Jan 13, 2020 at 9:38 AM
    #791
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looks awesome. No cab mount chop needed?
    COTundra23 and Rica25 like this.
  12. Jan 13, 2020 at 6:00 PM
    #792
    Subydude007
    Washington
    Equin,
    No BMC needed. I modified the front mud flaps, pushed the front fender liner forward, and bent the skid plate flange closer to 90 degrees near the sway bar.
    All is good so far!
    body mount without mud flap
    mud flap mod
    1/2” clearance to mud flap
  13. Jan 14, 2020 at 11:05 AM
    #793
    Rngr188
    Chad
    Harrison AR
    So reading the TRD PRO 295/70R18 thread it seems that tire will fit the Pro which is 2" taller than stock. I've got 6112 at 1.9 being shipped, if I did the 2 driver one passenger shim and 1-1.25" Bora or Spidertrax wheel spacers along with a 0.5" bumper shim would I be able to run this size tire on stock TRD OR wheels with no major trimming or modifications?
    https://www.tundras.com/threads/let’s-see-pics-stock-height-pro-with-295-70r18.31428/
  14. Jan 14, 2020 at 11:18 AM
    #794
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Im sure I've already posted it in here somewhere, but here is mine with the 275/70/17 Ridge Grapplers on stock wheels, 1.9. Its the perfect balance of size without loosing too many MPG.
    misfit, Spitfire, Rica25 and 4 others like this.
  15. Jan 14, 2020 at 11:23 AM
    #795
    AZBoatHauler
    So.Arizona
    You have good taste, my friend!
    Rica25 likes this.
  16. Jan 14, 2020 at 11:39 AM
    #796
    Rngr188
    Chad
    Harrison AR
    Nice truck, mine is MGM as well and as I mentioned I had 275/70 Ridge Grapplers on my stock 17 and will more than likely go back to that size. I have no plans for the rear besides the 5160's unless I need a little rake for the TSS system then I'll only do a 1" CB shackle.
    Rica25 likes this.
  17. Jan 14, 2020 at 11:53 AM
    #797
    Rngr188
    Chad
    Harrison AR
    Judging by your screen name I can only assume you haul a boat as do I, 18'8" Ranger with 175 Yamaha. I also see you are running 1.9" with the CB +2 shackle and 275/70 Ridge Grapplers. I will be running same setup but wasn't planning on doing anything to the rear would you recommend a rear shackle to prevent squat when pulling my boat?
  18. Jan 14, 2020 at 12:04 PM
    #798
    AZBoatHauler
    So.Arizona
    I chose to run the CB +2 shackle to avoid the possibility of being nose high when loaded and towing. I think it came out perfect as I’ve eliminated about 1” of the rake and it looks dead level when towing with the bed loaded.
    I tow a 5,000 lb wake boat (we can still be friends ;)) so with a fishing boat you would probably be ok with a CB +1?? Depends on how much rake you want to leave.
    Nice thing about the shackle is you can do the front first hook up the load and see what you need, if anything, by taking some measurements.
  19. Jan 14, 2020 at 12:24 PM
    #799
    Rngr188
    Chad
    Harrison AR
    My boat is definitely not as heavy as yours but I'm really digging your stance. Think I will try nothing out back first then see what happens form there. Thanks!!
    Rica25 and AZBoatHauler[QUOTED] like this.
  20. Jan 14, 2020 at 12:28 PM
    #800
    Bakelite
    Bakelite New Member
    Sam
    That background! Beautiful!
  21. Jan 14, 2020 at 2:19 PM
    #801
    equin
    Ed
    DFW, TX
    Good to know! I’m thinking of going up to 315/70/17s with my Icon Rebounds and was wondering if a BMC is needed. Your experience shows it may not be, but I understand each truck is different.
    Rica25 likes this.
  22. Jan 14, 2020 at 5:44 PM
    #802
    Subydude007
    Washington
    Really depends on the wheel width and offset. Assuming they are the same as the Six Speed’s than you should be good.
    equin[QUOTED] likes this.
  23. Jan 14, 2020 at 9:05 PM
    #803
    Big J
    Big J New Member
    2020 4x4 crewmax
    Icon rebound wheels are the same width and offset as the 6 speeds. The only difference is they are hub centric instead of lug centric. (which is like the OEM wheels). :thumbsup:
    equin, Rica25 and Subydude007 like this.
  24. Jan 14, 2020 at 11:05 PM
    #804
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Am I the only one with Bilstein 6112s in the front @1.9, with 275/70/18 BFG K02s that rub in the front?
    I haven’t fully checked what exactly the tire is rubbing on, but it sounds like metal.
    I think my next upgrade is some 1.25 spacers. 40F6A317-F23F-4AEF-A2F8-0E57695F12C2.jpg6D4C9957-2BEA-4FE1-BEA0-A1E04C9FB378.jpg
    dannysmith604, Spitfire and Deafmate like this.
  25. Jan 14, 2020 at 11:40 PM
    #805
    AZBoatHauler
    So.Arizona
    You are not alone. I had to trim the stock “skid” plate due to rubbing. Bending it up out of the way is also an option.
    Subydude007 and newguy[QUOTED] like this.
  26. Jan 15, 2020 at 4:15 AM
    #806
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    It might be 2 things, the front mini mid flap or your sway bar when in full lock position. I run 275/65/20 which is 0.2” smaller than yours. I removed my front mini mud flap and it doesn’t rub when turning the wheel. BUT it rubs the front sway when I turn my steering wheel around 1 5/8 turn which is at full lock.
    equin and newguy[QUOTED] like this.
  27. Jan 15, 2020 at 6:49 AM
    #807
    Subydude007
    Washington
    Once I cleared front fender liner and the mud flap, I heard the metallic rubbing as well. There’s about a 1” flange that sticks out at a 45 degree angle towards the tire. You can either bend or trim. I chose to bend that flange up to about 90 degrees. That was enough to clear at full lock to lock. You can access without removing the tires so very quick and easy mod. You could always trim later if bending doesn’t work.
    newguy[QUOTED] likes this.
  28. Jan 15, 2020 at 11:40 AM
    #808
    equin
    Ed
    DFW, TX
    Yes, I have Icon Rebounds, which should be the same width and offset as the Six-Speeds. But even so, I remember reading on here how similarly equipped Tundras may still experience differences, with one having rubbing issues while another has no rubbing. I’m not sure why that is, though, assuming the claims are accurate.
    Subydude007[QUOTED] likes this.
  29. Jan 16, 2020 at 1:26 PM
    #809
    COTundra23
    COTundra23 New Member
    Same setup with 1.25 spidertraxx. Rub on the front mud flap in reverse.
  30. Jan 18, 2020 at 5:50 PM
    #810
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    6112 @ 1.9 and 5160’s CB +2 CB going on Monday, 275/60/20 ridge graps going on Tuesday. I will post some pics once every everything is done!
    drobb likes this.
