6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Nov 16, 2019 at 12:15 PM
    #691
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    I put the 6112s at top and I measured all around and was 7/8” higher in front. Added 1.5” to the back. To put it where I like it. You’re truck looks good.
  2. Nov 16, 2019 at 4:28 PM
    #692
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Thanks ! You too. The ride is awesome. Very happy with the 6112/5160 setup
    BarcelonaSX[QUOTED] likes this.
  3. Nov 17, 2019 at 6:07 AM
    #693
    Stocky Balboa
    OC , CA
    How are you liking your tire/wheel size setup? I’ll be looking to do something like that.
    My wife’s 4runner has G2’s and they’ve been great. 30k mikes on them.
  4. Nov 17, 2019 at 5:26 PM
    #694
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    That's what those are for! I bought mine second hand had no idea what they went to. :confused:
  5. Nov 23, 2019 at 8:49 AM
    #695
    BarcelonaSX
    The thing rides Awsome. It’s aggressive enough looking. I commute 50+ miles a day so I needed something that rides fairly nice. These are Awsome. The wheels are just the stockers that came on the SX. I believe they’re the same style as the 15+ pro model. I just added the trd cap to match. Love the whole thing.
  6. Nov 24, 2019 at 6:53 AM
    #696
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    I love the look of those wheels. What name/brand are they?
  7. Nov 24, 2019 at 6:56 AM
    #697
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    Stealth Custom Series - Ray 10
  8. Nov 24, 2019 at 7:02 AM
    #698
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    Nice, setup looks perfect!
  9. Nov 24, 2019 at 7:14 AM
    #699
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    One more question. Do you have a pic from the front or back? I am curious how far the wheels stick out?
  10. Nov 24, 2019 at 9:04 AM
    #700
    CementTurdOffRoad
    Andrew
    Maryland
    0A1D064B-15E8-47B1-B119-127435785133.jpg 80728BA9-B0A7-43FA-A6B6-194863674829.jpg
  11. Nov 25, 2019 at 12:42 PM
    #701
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    I just came across your post, Id love to go over your install along with measurements to see why you're not sitting correctly. Have you added weight anywhere on the truck?
    Feel free to give me a call if you'd like :). 801.635.4872
  12. Nov 25, 2019 at 12:52 PM
    #702
    Coachbuilder1
    David
    Salt Lake City UT
    https://www.shopcoachbuilder.com/co...ilder-strut-coilover-shim-provides-50-of-lift
    We build all kinds of suspension tuning items specifically for the Tundra. Let me know if you need a hand with anything. David 801.635.4872
    bigalsnow likes this.
  13. Nov 26, 2019 at 2:13 PM
    #703
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    6112’s top setting 2 shims on drivers side, one shim on passenger side. 5160’s in the rear with 1.5 AAL pack. Spc UCA, 1.25 spider trax wheel spacers, and 285/65/20 on platinum wheels. Removed front mud flaps and still rub at full lock, ordered .5 bumper shims and then I should be good to go.
  14. Nov 26, 2019 at 7:19 PM
    #704
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    Looks good, what tire brand/name are those?
  15. Nov 26, 2019 at 7:27 PM
    #705
    AZBoatHauler
    So.Arizona
    They look like Nitto RGs with the less aggressive side mounted out. They look great.
    19TundraPlatinum likes this.
  16. Nov 26, 2019 at 8:50 PM
    #706
    19TundraPlatinum
    Maryland
    Nitto ridge grapplers
  17. Nov 27, 2019 at 9:10 AM
    #707
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    Ver
    Very nice! I thought that is what you were running. I am debating about 275/65/20 or 285/65/20 Nitto RG once I get the 6112/5160 on.
    Looks good!
  18. Nov 27, 2019 at 9:20 AM
    #708
    19TundraPlatinum
    Maryland
    Thank you, my bumper shims are coming today I’ll update you on if they still rub at full lock. Incase that plays a factor in your decision.
    toyota tom[QUOTED] likes this.
  19. Nov 27, 2019 at 9:22 AM
    #709
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Is the top setting borderline too much preload on the spring?
  20. Nov 27, 2019 at 5:14 PM
    #710
    19TundraPlatinum
    Maryland
    UPDATE: I just installed bumper shims, no rub with 285/65/20 now. Bumper shims and front mud flap delete was necessary.
    toyota tom[QUOTED] and Kwe1982 like this.
  21. Nov 27, 2019 at 5:30 PM
    #711
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    Good to know, appreciate you sharing!
  22. Nov 28, 2019 at 7:12 AM
    #712
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    Any rub or trim with this setup??
  23. Nov 28, 2019 at 7:23 AM
    #713
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    6112s come with a spring designed to be used with the shock. You will get a slightly more firm ride as you increase height level but it is still a more compliant ride even at top setting than stock shocks are
    equin likes this.
  24. Dec 1, 2019 at 1:20 PM
    #714
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I’m wanting 3” of lift to run 35’s but do not want the ride to be harsh. Will I notice a difference in ride quality with a 1.9” setting with CB 1” & .5” shim on driver and a 1” on the passenger VS a 2.5” setting with CB 1” shim on driver & .5” shim on passenger?
  25. Dec 1, 2019 at 2:32 PM
    #715
    Danman34
    Danman34 New Member
    Danny
    you can’t put 1.5” of shims on the front. You’ll run out of thread to actually bolt the assembly up. Just go top notch with 2 shims driver, 1 passenger.
    Bakelite, equin and MAGDADDY like this.
  26. Dec 3, 2019 at 5:09 AM
    #716
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    So this happened about a month ago. 6112's @ 1.9 with 5160's in the rear. No shims up front as of yet, but will be adding one to the drivers side. Staying with the stock TRD OR wheels for now and will be moving to gunmetal Ray 10's next summer, all sitting on 275/70R18 Falken Wildpeak AT'3. The only rubbing I had was on the stock skid, and after a little bit of bending up the corners no more rub. I waited to post to see after a month of driving how I felt with this setup. My initial reaction was I absolutely love this setup and my current feeling is still the same, and I highly doubt it will change. Especially after the fair amount of snowfall we had. The Falken tires handled like a beast!! Only question I have for those running this is what setting do you put your headlight adjuster on? I currently have it on 3 and I still feel like I am blinding the cars in front of me and oncoming traffic.
  27. Dec 3, 2019 at 6:05 AM
    #717
    Danman34
    Danman34 New Member
    Danny
    sitting at 1.9. Headlights on 0. Never touched them after lift and have never had an issue.
    Bakelite and 316KS_Runner like this.
  28. Dec 3, 2019 at 6:22 AM
    #718
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Finally ordered my wheels. Now just waiting until Christmas for my Camburg UCAs. Hopefully with the lift, shims and shackles I won't have to do too much cutting. I also will have installed the CB front bumper shims and bump stop. Worried about how much rubbing there will be, but we shall see. Wheels and tires will be 35x12.50R18 with +6 offset on the wheels.
    316KS_Runner likes this.
  29. Dec 3, 2019 at 1:58 PM
    #719
    COTundra23
    COTundra23 New Member
    Since it seems that shackles are perceived as a "cheap but acceptable" option for rear lifts, what are the negative side effects of using them?
    dannysmith604 likes this.
  30. Dec 3, 2019 at 4:24 PM
    #720
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    At a +6 you will need a Body Mont Chop (BMC). At ) offset I needed to do an aggressive BMC.
    Bakelite[QUOTED] likes this.
